1984 xj750RL Neck Bearings
Discussion in 'XJ Technical Chat' started by RICKTOR, Aug 25, 2017.
  1. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Hey guys, I have a 1984 XJ750RL which has a small click in the center of the handlebar travel when the front tire is pointed forward. It is failing the safety here in Canada because of it. I need to source a new set of replacement bearings and races but no one seems to have access to any. Is there a replacement or cross reference/upgrade that will work on my bike. Thanks
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    XJ4EVER. Top right corner of this page. Start a conversation with chacal and he will be able to get you everything you need for your xj
    Lightcs1776 likes this.
  3. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Hey thanks
  4. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    is there a how to posted somewhere? I looked and didn't see anything
  5. 84-Seca-750
    84-Seca-750 New Member
    Winnipeg
    Hey Ricktor, I have the same problem with my xj750, I got my mechanically inclined brother to do all the hard work while I scrolled through this forum looking for cool mods for him to complete.
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  7. Jetfixer
    Go to upper right corner click on xj4ever .... I got the taper roller bearing upgrade...it is my fall project. Chacal is a great resource and fast service .
  8. John D
    John D New Member
    Valparaiso
  9. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    the 84 already came with tapered bearings if I remember correctly. It was a one off year... 83 was different and 85 was also different. I also believe the 1984 XJ750RL shares the 900 frame with the 750 motor. So that is why it isn't up there on allballsracing which leads me back to my problem ... nobody can find these bearings. Chacal hasn't got back to me yet and I hope he has good news :)
  10. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    @84-Seca-750 Thanks fella, I'm a aircraft mechanic so the mods are simple to do just impossible to find parts :)
  11. Toomanybikes
    Tsawwassen bc
    Welcome Riktor
    I have the Xj750rl as well and use
    yamahapartsnation.com to look up part numbers using the 83 xj900rk
    And the oem equivalent air filter from hi-flo # 4901 listed for 900
  12. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Hey thanks for the info... I'll take a look into it.
  13. MattiThundrrr
    Oh my. It seems that I have made an ass of at least one of us! In my defense, your bike is not so common, I forgot it was basically a 900 frame. These are the things that keep me from becoming a guru...
  14. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    NO - I think it is those pictures of you with that elderly couple that have been circulating on the internet.... I mean really to each his own but the fishing tackle, vultures and the polyester Nun outfits may have been a bit much. :oops:
  15. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    eeewww!!!!
