1985 XJ650 Maxim Refinish Complete
Discussion in 'XJ Technical Chat' started by Dan Gardner, Apr 4, 2021.
  1. Dan Gardner
    Minneapolis, MN
    Got the final cut and buff finished today. Installed emblems and seam trim.
    Black mirror achieved!
    Franz, jayrodoh and chacal like this.
  2. John Witherbee
    John Witherbee New Member
    Cato ny
    Mmmmm purty
  3. Max 700-X
    Max 700-X Member
    AL
    Nice work!
  4. Dan Gardner
    Minneapolis, MN
    For those of you playing along at home, I sat down and logged my procedure, materials, and time.
    Here is my task list:
    1. Bead Blast
    2. Body filler
    3. Block sand, 80 grit
    4. Primer - HoK KD3001, High build
    5. Block sand, 220 grit
    6. Primer, HoK KD3001, Medium build
    7. Sand, 600 grit
    8. Basecoat - HoK S2-25
    9. Clearcoat - HoK UC35
    10. Sand, 1000 grit
    11. Flowcoat - HoK UC35, about 10% over-reduced
    12. Sand 1000 grit
    13. Sand 2000 grit
    14. 3M 36060 Perfect-It EX AC Rubbing Compound
    15. 3M 06094 Perfect-It EX Machine Polish
    16. 3M 06068 Perfect-It Ultrafine Machine Polish
    17. 3M 05990 Hand Glaze
    **not counting** the bead blasting that I outsourced, or new the emblems I acquired from XJ4Ever, I spent $200 on materials and 30 hours of work.
    The bead blasting cost $65, but was well worth it in this case.
    I realize it is not Concours correct, but that wasn't my goal. Concours correct would probably be more $ for materials and less shiny overall.
  5. Dan Gardner
    Minneapolis, MN
    A look at the finished under side, with petcock installed:
    Some fresh fuel line and a fresh filter, and we are installed and ready to ride!!
