1985 XJ700 Maxim-X Parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by Dan Gardner, Mar 25, 2021.
Tags:
  1. Dan Gardner
    Minneapolis, MN
    I'm considering buying a 1985 XJ700 Maxim-X parts bike.
    Would anybody be interested in anything? A carb rack, for example?
  2. Dan Gardner
    Minneapolis, MN
    A look at the carb rack. Looks to be in excellent condition to me. A little dirty right now. The bike has 20k miles.
  3. Dan Gardner
    Minneapolis, MN
    The bike runs on starter fluid. Seems like it would be a crime to part out a good XJ700XN motor. Anybody within driving distance of Minneapolis want to make an offer?
    Intake runners are in good shape. Exhaust is in good shape. Have the rad & fan.
    Hogfiddles is getting the carbs. I suspect that the carbs may have been the reason this ended up being a parts bike. Dave says somebody has messed with them. Probably screwed them up. Once he is done with them I'm sure they will be good as new and could be reunited with the motor.
    Most parts still available. Would sure like to find a home for the motor.
  4. Max 700-X
    Max 700-X Member
    AL
    Are the air box and boots in good shape?
  5. Dan Gardner
    Minneapolis, MN
    I believe so. I will try to get some better pictures.
  6. ascarygorilla
    ascarygorilla New Member
    san jose
    Im interested in the whole carb set up. All 4, if you got them
  7. joe elliff
    joe elliff Active Member
    illinois
    I believe I could be swayed into buying a nice paint set. Send a PM if you’d like
  8. Dan Gardner
    Minneapolis, MN
    Sorry, carbs are gone. I will update post to start showing what I still have.
  9. Max 700-X
    Max 700-X Member
    AL
    Any update on air box and boots? Also, how do the intake boots look? Thanks
  10. Dan Gardner
    Minneapolis, MN
    Sorry. Must have gotten distracted by something shiny. I went out and snapped some quick photos of the airbox itself, airbox-side boots, and intake boots. I can't find any cracks in the intake boots and they feel rubbery to me.
    20210407_144119001_iOS (2).jpg 20210407_144129415_iOS (2).jpg 20210407_144146892_iOS (2).jpg 20210407_144152110_iOS (2).jpg 20210407_144351522_iOS (2).jpg 20210407_144407292_iOS (2).jpg
  11. Max 700-X
    Max 700-X Member
    AL
    Thx. -Message sent
  12. Elijah Vertsehovski
    Elijah Vertsehovski New Member
    South Carolina
    What about piston rings?
  13. Dan Gardner
    Minneapolis, MN
    Let me check. I believe I've got rings.
    Elijah Vertsehovski likes this.
  14. Elijah Vertsehovski
    South Carolina
    And I seen a picture of intake boots. That go between engine and carbs.
  15. Dan Gardner
    Minneapolis, MN
    The intake boots have been sold, sorry.
  16. Elijah Vertsehovski
    South Carolina
    Thats ok. Im more worried about piston rings. They are truly nowhere to be found.
  17. Dan Gardner
    Minneapolis, MN
    I will look for rings tonight and get pictures.
    Here's a list of what I have available as of 7/30/2021:
    Instrument cluster
    Headlight assembly
    Ignition module
    Forks
    Tail light assembly
    Signals
    Mirrors
    Rear Fender Stays "Maxim X"
    Exhaust (headers, collector, and silencers)
    Front Wheel with discs
    Final drive
    Swingarm
    Clutch cover / water pump cover
    Crank & Rods
    Stator assembly with Cover
    Oil pan
    Left side case cover
    Head with valves
    Cam case assembly (https://www.ebay.com/itm/184826843449)
    Oil pump assembly
    Output gear and shaft assembly
    Tranny and clutch basket
