1986 Yamaha XJ700x - 10amp Fuse Blown
Discussion in 'XJ Technical Chat' started by Shelby Biggs, Jul 12, 2025.
  1. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Howdy - bike blows the 10amp fan fuse every time I switch the ignition switch from “off” to “run”. I stripped the bike to the frame, did a top end rebuild and did a little customization but all electrical is original minus a few led upgrades. Everything else on the bike works as it should. I thought maybe a starter issue before checking fuses but bypassing solenoid will turn starter no problem. Any ideas?
  2. Franz
    It could be a short circuit, overloaded circuit or a faulty component or connection. Check the wiring to the fan make sure you have a good connection. Do you have the original Yamaha fuse box? Change it for a blade one. @Rooster53 might chime in he knows a lot about electrical systems.
    Shelby Biggs likes this.
  3. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    It is the original fuse box behind the cluster panel but they are blade type fuses. Fuse terminals look to be in good condition but I’ll run through it again. What’s strange is the fan fuse terminal is only giving a reading of 10.8 volts when switched to run. Battery charge is at 12.5 and I’m getting a consistent 12.5v reading on other terminals. I unplugged the fan and thermoswitch but fuse still blows. I’ll check for other issues here in a minute. I did spill coolant on the connects when filling the system back up earlier yesterday. Maybe coolant got in a contact and is causing a short? I’ll look at that too.
  4. Rooster53
    Sounds like you are on tract to finding it - That fuse is dedicated to fan circuit only so I would suspect a pinched / chafed wire along the way since you stated fuse still blows with thermal switch and fan disconnected.
    Shelby Biggs and Franz like this.
  5. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
  6. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    I’ve basically pulled the entire harness to inspect and there is nothing standing out. I’ve got a copy of the wiring diagram and it looks power for fan also runs to the main switch, main fuse and starter relay. All areas are checking out. Could the short be coming from a joining wire? Looks like left and right front flashers/hot line tie into same junction at main switch.
  7. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    ***update*** I connected main switch, cluster wires and front blinkers back together as well as off/on switch and the fuse will now blow at the turn of main switch to on. Which has changed from main switch on, no issues, and then fuse blowing when kill switch turned to on. Should that be pointing me in a direction I haven’t picked up on? I test ohms on fan motor live wire from harness and I’m getting 0.0l so there is a dead short for sure but where is the question. I didn’t have this issue before I tore down and rebuilt the bike. I was able to use switches as they should and crank bike for compression testing with no issue. So whatever is going on it probably my fault but hard to find when everything looks alright.
  8. Rooster53
    That is either parallel or upstream to the fan fuse so that's not a good path to troubleshoot fan fuse blowing - unless you are mistaken on which fuse is actually blowing?? Are you sure you are not blowing the ignition fuse since you mentioned one time only with the kill switch set to run?
    Live wire to where? ground? wire color? And is the "0.ol" supposed to mean zero ohms? You have to be careful trying to ohm circuits particularly when they power light bulbs as the filament will read a very low resistance.
    If you disconnected the fan and the thermal switch and it truly is the fan fuse blowing then it just can't be anything else but a damaged wire shorting to chassis or to another wire.
    I can't remember if it is the XJ700 but one of the XJ's you can easily attach the wrong connector to the TCI and cause the ignition fuse to blow - check the TCI connectors if you had them off for any reason.
  9. Rooster53
  10. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    *Final Update* Found the issue. After removing 75% of the harness, testing all connects and ohms and volts to every possible component.. it was the kill switch. The moto shop I bought the bike from soldered a split wire in the kill switch before they decided to sell it as a parts bike and I guess when they reassembled the kill switch, they put the 3 prong copper contact plate in upside down so it was making constant contact with all three prongs wether off or on. Flipped it around and no more fuse blow. Le sigh
    chacal and Oblivion like this.
  11. Rooster53
    So just for clarification it was the "ignition fuse" that was blowing?
  12. Rooster53
    What is a "split" wire? Do you mean they "spliced" a wire into the kill switch wiring, and if so where did it go?
    Unless flipping that part removed a short from ground that switch shorts contacts to work, so it wouldn't blow a fuse no matter how it was assembled. It may not deactivate the ignition though, which would be a bad thing as it is part of the safety circuit.
  13. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    well - void all that bs/I debated deleting my account and never speaking of this but I did have the safety relay plugged into the TCI. But it was 100% blowing the fan fuse and not the ignition fuse. Unless they labeled it wrong in production. Fan fuse is the left and ignition is on the right of cluster and the left labeled fan fuse was blowing every time. My battery is too low now to test anymore so I’m throwing it on the charger and will come back with an update. I am assuming relay going where it needs too and ignition going to TCI will correct the problem but right now I’m only getting 8v to fuses with low battery.
    Oblivion and Rooster53 like this.
  14. Rooster53
    Thanks so much for posting that picture, I have looked far and wide to get a shot of that.
    I see what you are saying that if you were to flip the cover and mount it the fan fuse would be on the left. Maybe what Yamaha did was label it such that you wouldn't have to think too much and the fuses match what you see with the cover up - so ignition on the left. It looks like they thought ahead knowing it would be confusing so that if someone did use the wrong logic at least the 10 and 15 amp fuses would be appropriately fitted.
    Please don't delete your account, this is live and learn experience for us all, and although mistakes might have been made I always view that as a positive learning experience of getting to know the bike better.
  15. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    No problem - let me know if there are any other pics you need. I’m sure I’ve got them.
    Well if it is backwards - it sent me on a wild goose chase. Hopefully that’s the case and I’ve been actually blowing the ignition fuse. Will test once battery is charged.
    And I appreciate that. I rely too heavily on this forum to actually delete my account and yes once the bruised ego heals it is definitely a positive learning experience haha
  16. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    What you said just clicked - when looking at the cover while off, that will represent fuse lay out. Ignition is left. I was thinking it would be as the cover sits assembled.
  17. Dave in Ireland
    Ireland
    That's certainly what I would have assumed - assembled with the label corresponding to the fuse it is directly over and NOT mirrored.
    And that's the way any normal rational person would do it. The Japanese engineers were certainly that.
  18. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    *Update* I confirmed it is mirrored. So hunting down a short from fan was a waste of time. The relay to TCI and TCI to relay was blowing the ignition fuse and now doesn’t blow since corrected.
    *New Issue* Starter button does not crank the bike. No click from solenoid when attempting either. So far here are my test:
    • Starter button does not show voltage to the blue/white wire that connects when pressed
    • Cranking works when 12V is applied directly to the relay trigger wire (so the relay, solenoid, starter, and wiring to the starter seem to be fine)
    • confirmed and cleaned the button contacts, but the signal still dies when pressed
      Starter Relay, Starter Motor, and Battery: GOOD
      • Relay works when triggered directly with 12V
      • Starter spins when jumped
      • Battery shows healthy voltage (~12.6V+)
      • Neutral switch is working
      • Safety system likely not the problem as I bypassed this with no change.
        *Problem Area*
      • When I press the starter button, voltage drops to ~57mV when reading blue/white wire that also connects to starter solenoid down the line.
        Connecting wire at solenoid is reading proper voltage.
        What I’m thinking:
        • Not getting sufficient power in
        • Or internal resistance/failure under load
      I see that the starter button is not passing voltage at all. I don’t think the starter button is being fed proper 12V power to begin with but the kill switch is? None of the starter button wires show a voltage more than 50-200mv and they drop when button is pressed. Should I diagnose upstream or connect to a 12V ignition source and feed it straight into the starter button's input wire and see if it’ll crank? If it does I might just bypass and add a push button start somewhere else.. any ideas?
  19. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    *update* I placed a jumper wire from 12v supply with kill switch on and then to blue/white starter wire and the bike cranked. So is this telling bad starter button/contacts and that’s what I need to replace or repair? Picture attached: IMG_1259.jpeg
  20. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    *Final Update and step by step for anyone else that falls into my shoes*
    @Rooster53 thank you for the help and let me know if you see anything I need to correct below.
    1. Ignition Fuse Blowing
    • Thought my fan fuse (10A) was blowing — turns out the fuse box diagram was mirrored, and it was actually the ignition fuse that kept popping (photos above).
    • Root cause: I had accidentally swapped the TCI and side stand relay connectors — they use identical plugs and sit close together.
    • Once I corrected the plug locations, the ignition fuse stopped blowing completely.
    1-2. TCI and Side Stand Relay Swapped
    • The TCI unit and side stand relay have the same connector type, making them easy to mix up.
    • Swapping them caused a short or incorrect power routing, which was killing the ignition fuse and interfering with ignition system behavior.
    • After correcting the plugs, power stabilized and circuits began working as expected.
    3. Starter Button Not Triggering Crank
    • Pressing the starter button would cut the headlight, illuminate oil and fuel light (normal to conserve power for crank), but there was no crank and no relay click.
    • Voltage test showed:
    ◦ Yellow/white wire (input to switch): 11.6–12.5V
    ◦ Blue/white wire (output to relay): only 40 millivolts when button was pressed
    4. Weak Continuity Through Starter Button
    • Tested continuity across the starter switch — showed high resistance and poor contact.
    • Jumper test: Sent 12V directly to blue/white at the starter relay — starter cranked immediately.
    5. Final Fixes
    • Starter button is internally corroded or worn — not passing enough current to activate the relay.
    • Temporary solution: jumper wire bypass to crank the bike.
    • Permanent fix: replacing the starter button or installing a clean external momentary switch.
    Outcome
    • Ignition fuse issue resolved (caused by connector swap)
    • Starter system now working
    • Bike cranks reliably
    **for clarification the two red and white power lines running to kill switch I soldered separately, heat shrinked each and then wrapped together with electrical tape. Hard to tell that from the photo**
  21. Rooster53
    This suggests that there is a problem with the safety circuit starter cutoff relay or its controls, or the wiring.
    In normal operation one side of the starter switch (L/W wire) should be 12V via the starter cutoff relay closed contacts but only if the bike is in neutral OR the clutch is pulled in AND the side stand is up. When the starter button is depressed the switch grounds the L/W wire, which then energizes the starter solenoid
    So another area on the XJ700 that can be easily miswired is the solenoid - it should look like this:
  22. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Confirmed starter solenoid is wired properly and I tested safety mechanisms and all check out. Manual test and continuity testing while using jumper wire to crank bike over.
    Crank Or No Crank
    Neutral, stand down, no clutch
    ✅ Yes
    In gear, stand down, no clutch
    ❌ No
    In gear, stand up, clutch pulled
    ✅ Yes
    In gear, stand up, no clutch
    ❌ No
    Just to clarify how I’m seeing that it works on the bike:
    • The red/white (R/W) wire sends 12V into the starter button from the kill switch circuit.
    • The blue/white (L/W) wire sends 12V out to the starter cutoff relay when the button is pressed.
      • If all safety conditions are met, the cutoff relay passes 12V to the starter solenoid, and the bike cranks
    • So it’s not grounding L/W — it’s passing voltage to it (?)
    Here’s what I tested:
    • Got ~12V on R/W at the switch (so power coming in was solid).
    • Pressing the button gave me only millivolts on L/W — meaning the switch wasn’t passing power.
    • Ground path was clean (confirmed via continuity back to frame and battery ground).
    • I jumped 12V directly to the L/W wire (bypassing the switch) and the bike cranked immediately.
      But with my most recent jumper crank, the bike continued to crank until I turn keyed ignition off which tells me you’re right that the starter cutoff relay is bad/going bad/faulty or the solenoid is sticking… and if the relay is bad internally or not pulling current due to worn contacts, the starter button could seem dead even if it’s working. Which would make sense because the starter button was working before I disassembled the bike. I wonder if I damaged relay when having it plugged into TCI connector. I’m going to play on the safe side and replace solenoid, cutoff relay and switch here….
  23. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    @Rooster53 I am at a loss here - replaced relay and solenoid but still no crank with starter button. I haven't replaced the starter button as wiring and solder look to be intact. I cleaned up the copper contact plates and you can see it makes good contact since there are strike marks. Checked all wiring in headlamp housings and contacts are good - tested all grounds and they are reading as they should, tested all safety cutoffs and they are working as they should. I really don't know. Killswitch on --> oil light and fuel light illuminate --> press starter button ---> headlamp goes off and no crank, not a sound, nothin..
  24. Rooster53
    The only way touching the R/W wire from the kill switch to the L/W wire would work is if the kill switch is set to the open position and you touched the side that feeds the TCI to the L/W wire, or there is some creative re-wiring.
    An easy test is to touch ground to the low side of solenoid L/W wire - bike should crank
    Touch ground to L/W wire in right control that connects to starter switch - bike should crank if safety circuit is engaged
    If those two work then the starter switch is not working or ground is missing from the right control.
    Note on some of the right controls Yamaha did not provide a wire for ground, but relied on the metal contact of the right control to the bars and then the bar metal contact to the frame. Consequently, some bike require either a temporary jumper to ground the control or the control and bars to be mounted during troubleshooting.
    Franz likes this.
  25. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    The bike does not crank - but you can see it is grounding properly as it will cause the oil light, fuel light, head lamp to act accordingly. The right control has a ground wire that runs from the button on this bike.
    Alternatively, the L/W wire that connects to the solenoid is getting proper 12v and when starter button is pressed, it drops to 0v as expected. So it is grounding..
    • Expected Voltage on L/W
    • Key OFF ~0V
    • Key ON, Kill ON ~12.6V
    • Starter button pressed - Drops to ~0V
    The solenoid that I am using has this 4 tab configuration:
    FRONT:
    [ Tab A ] (always 12.4V)
    [ Tab B ] (always 12.4V)
    A--- B--- <------------------------------ Always reading 12.4 volts (A and B are internally bridged)
    C--- D--- <------------------------------ L/W wire is connected here to D tab (same response whether on C or D as they are internally bridge.)
    Bpost Mpost
    [ B ] ← Battery +
    [ M ] ← Starter motor
    REAR (closer to posts):
    [ Tab C ] (12V with key on / kill on; drops to 0V with starter button pressed)
    [ Tab D ] (12V with key on / kill on; drops to 0V with starter button pressed)
    I also connected 12v supply to D tab and ground to C tab to test solenoid and the bike cranked so the solenoid seems to be ok.
  26. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Ignore the solenoid layout - It didn't stay in place when I posted.
  27. Rooster53
    ? you mean the pictorial that is there?
    So this is the new starter relay replacing the Yamaha OEM ? Do you have a link for it?
  28. Rooster53
    Is the starter cutoff relay (combo unit on XJ700 with turn signal relay and auto cancel) still connected? It is not shown on the diagram and would be in series with the starter switch. And must have contacts closed so the starter switch will activate the starter relay.
    And you need a good kill switch and ignition fuse for it to operate, along with good safety switches
  29. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Yes this is the new starter solenoid and the diagram it came with.
  30. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Yes, if you are talking about the black box under the gas tank? I confirmed safety switches are good, and new ignition fuse is in and not blown. I can hear the black box under the tank click when I turn the kill-switch off or on.
  31. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    I figured that was just a flasher relay and the blue/black relay with the blue connector (4 pin) was the safety cutoff relay?
  32. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
  33. Rooster53
    That larger unit under the tank is the combo starter cutoff relay and flasher / auto cancel unit. It is good that you can here it clicking, but that doesn't mean the contacts are in good enough shape to close the starter solenoid.
    In a OEM setup, you could ground the L/W wires on that 41R-71 device connector and the starter should spin even with the ignition off. It looks like per your diagram above you would need to turn the ignition switch on and then ground L/W
    Combo unit with starter cutoff relay
    So the picture of the starter relay you just have the one terminal connected - guessing that was troubleshoot mode?
  34. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Trouble shoot mode yes BUT also the only other wire is a ground wire connected to battery neg - when this is connected to the C terminal or terminal to left in the photo, it constantly grounds. If left off, then the starter button grounds as it should when pressed. The two terminals in the front have a constant 12.6 voltage and connecting either wire will blow the solenoid fuse.
  35. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    I tested voltage to l/w wire running to cutoff relay and it’s getting 12v with kill switch on and drops to 0 when starter button is pressed. Tested continuity on the ground cable running in as well and got 0.1 ohm reading so that is good. The red/white is also reading 12v going in.
    I added a ground jumper wire from l/w that leaves the relay and it shows a constant ground when grounded. Touch jumper to ground point and oil light illuminates, fuel light etc.. but no crank with starter button.
  36. Rooster53
    I don't understand that - the kill switch is not part of that circuit. Are you saying you only have 12V on the L/W wire that runs from the solenoid to the starter cutoff relay when the kill switch is on?
    "In" what does that mean - should it read i tested the black ground wire at the starter cutoff relay and verified it does connect to ground? Same for R/W wire
    Connecting either wire? what is either wire from where to where? It looks like the 30 amp fuse per the pictorial you posted supplies battery voltage to those upper terminals?
    If i found the right diagram that 30 amp fuse would be the main fuse and that upper left terminal would be the charge wire - you shouldn't need any of that
    Are the two bottom terminals the internal coil on that new starter relay? Can you post a link on what bike it was intended for?
    I found the Yamaha Grizzly that looks similar, but would prefer to know just what was ordered
    Do you have 12V connected to one side of the coil?
    Grizzly diagram:
  37. Rooster53
    And this too, what does it mean when you say "either wire," and does that mean that 30 amp fuse, and where are the wires connected?
  38. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Okay sorry for the confusion - Let me try to clarify better. I've added some photos. The two terminals in the front are always hot and I don't connect any wire to those. If I connect either the blue/white wire or ground to either of those tabs the 30amp fuse will blow. The two bottom terminals are the internal coil for the solenoid. This solenoid setup was the same setup the bike had when I bought it - I did just order a solenoid from Caltric that is a direct replacement and is case grounded so there is no ground wire or four tab setup.
    This is what I currently have: https://a.co/d/eH5Ez6T
    This is what I ordered to replace it: https://caltric.com/i-30559265-caltric-starter-relay-re119.html
  39. Rooster53
    Do you already have the second one (Caltric) and plan on replacing the one pictured?
  40. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    The second one hasn't come in yet but should be in before the weekend. I plan to replace the current one with the Caltric coming in.
  41. Rooster53
    So you need to hook one side of the solenoid coil to 12V, terminal C I believe is the correct one - labeled below
    The 12V on the L/W on the output side of the starter cutoff relay would be normal because of the oil lamp circuit. Since you are grounding that with the starter switch and the oil light illuminated it should be just about the missing voltage at terminal C.
  42. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    Okay this paint's a much clearer picture. So I can take the lead that is connected to battery neg, move that over to battery pos + and connect to terminal C and then see if it'll crank while leaving l/w connected to terminal D. (?) I'll try that when I get home from work. I feel this explains why a 12v jumper to terminal C and ground to terminal D activated coil and cranked the starter during troubleshooting. What you are saying would do the same thing, just correctly using OEM controls as it would be providing the 12v to C terminal like it is needing.
    And I did have the l/w wire connected to the A and B terminals during troubleshooting and it did blow the fuse when I pressed the starter button... a couple times... fingers crossed no internal damages to relays. They should be rated at 30amp and 14v max.
  43. Rooster53
    Good to be optimistic, and they are still working so that is good.
    Much clearer now yes, my apologies for not getting it earlier on the 12v oil lamp circuit
  44. Shelby Biggs
    Shelby Biggs Member
    Austin, TX
    You have been a huge help - I don’t need an apology at all. Thank you very much. Just got home and added 12v lead to C terminal and that started the bike up with the starter button no problem. What a long winded conversation to be user error on my part and a backwards wire. Haha
    Rooster53 likes this.
  45. Donglord
    Donglord Member
    Arkansas
    Hello. I've got the same bike (86' maxim x 700xs) and I'm in the process of attempting to build a chopped wiring harness for only headlight, tail/brake light, possibly horn, and electric start. Do you happen to have a wiring diagram for this bike? I can't find the one I need for the liquid cooled engine
  46. Simmy
    this is for the Canadian 750-X but I can't see it being much different
    IMG_4931[1].jpg IMG_4932[1].jpg IMG_4933[1].jpg IMG_4934[1].jpg IMG_4935[1].jpg
