1990 XJ 600 37kW --> 54kW
Discussion in 'XJ Technical Chat' started by GoCrazy, Sep 12, 2016.
Tags:
  1. GoCrazy
    GoCrazy Member
    Poland
    Hello forum users,
    I've been following this forum for some time now while rebuilding and modyfying my XJ600 and I have finally decided to come out :)
    I have this issue with my motorcycle - It is a stock version from Germany 37kW - 54hp, I would like to convert it to original 54kW - 72hp. While searching for clues how to do it I found a post on a forum for german speaking Yamaha drivers of a guy who did the conversion in a dealership. Below is the information from the invoice that he received afterwards:
    Intake manifolds:
    49A-13586-00 49A-1
    49A-13596-00 49A-2
    49A-13597-00 49A-3
    49A-13598-00 49A-4
    Needle Jet 1, 3, 4 51J-1490J-00 4CP3
    Needle Jet 2 51J-1490J-10 4CP7
    I've already installed the intake manifolds. Now I am in the middle to cleaning my carbs and I would like to buy the parts that I need but when I looked up the needle jets numbers in the carb parts section of this forum I was surprised to find out the they come from XJ550. I wouldd appreciate any help in verifying this information.
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Hmm 51J teh correct prefix is for XJ600. My suggestion would be to get a complete Mikuni BS32 carb rack from a UK model they can be had pretty cheap - especially if it's just for spares..
    Also what TCI do you have? They may have restricted the maximum rpm too..
  3. GoCrazy
    GoCrazy Member
    Poland
    I am not sure there were any different TCI's models for XJ600 / FJ 600. From the invoice the German guy received it's obvious Yamaha used different intake boots with airflow restrictions and a different carb set up. I drove the bike before I started disassembly process and it reved nicely on all gears.
    If it's just needle jets that I am missing, It'll be cheaper to source only these.
  4. a100man
    Bedford, UK
    Ok - at least you checked - might be worth posting a 'wanted' item on the for sale section here..
  5. Nico_Valentino
    Nico_Valentino New Member
    Warsaw
    Hi, it’s been a while.
    Did you finish your conversion?
    I also bought a 37kW version and I’m planning an overhaul during winter season.
