1990 XJ600 front calipers
Discussion in 'XJ Technical Chat' started by Garfield Tait, Apr 12, 2025.
  1. Garfield Tait
    Garfield Tait New Member
    Scotland
    New to this forum. I have fitted front brake calipers from a 1990 XJ600 to a 1998 XJ600S Diversion.
    Does anyone know the torque setting for the bolts holding the front brake caliper halves together?
  2. Timbox
    Just did a quick search on youtube and found this for reference. Don't have a manual in front of me so.
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    1990 xj600 "pre diversion" has front twin discs, with one piston on each side of each disc
    1998 xj600s diversion has front single disc with twin pot caLliper,
    are you sure you will have enough stopping power with the single calliper with just one piston on each side of the one disc?
    caLliper mounting bolt torque is 35nm, calliper half bolts "or calliper bracket bolts" as the Haynes calls them are also 35nm
