Wanted 2 Carb Float Bowl Mikuni BS33
Discussion in 'For Sale, Trade/Swap, Wanted' started by MaxRodax, Sep 17, 2017.
  1. MaxRodax
    MaxRodax New Member
    Rochester hills, Michigan
    Friends; a stripped drain plug and a severely neglected fuel system have me looking for this parts.
    My bike is an 85 XJ700X with Mikuni BS33 CV carburetors.
    Please contact me if you have them available; or at least one.
    Thanks!
    have you asked your local machine shop to remove the screws?
  3. MaxRodax
    MaxRodax New Member
    my main concer is varnish removal, the idle port is plugged. I can deal with the drain issue but the varnish buildup is a pain in the butt. I want to be ready just in case. I could probably remove the drain bolt at work... shhhhhh!
  4. XJ550H
    clear idle port using a high e gutiar string or small wire sewing needle ect and a propane torch to heat the bowl at those points this will burn the varnish . have you soaked them in a gallon of carb cleaner?
    it takes a few soaks but it does work compressed air is also helpful
    be careful of fire when you torch them
  5. MaxRodax
    MaxRodax New Member
    I tried the guitar string but it is not a straight port (I believe). I cleaned the jets with the string nicely. I am not giving up! Just in case I want to see if there is something out there, then I can freely try whatever comes to mind. I will share my findings. Thanks for the tips!
  6. chacal
    We should have a good used set of bowls, send us an e-mail and tell us which carbs (#1, 2, 3, or 4) you need the bowls for (actually, #1 and 2 use the same bowl and #3 and #4 use the same bowl).
    MaxRodax likes this.
  7. XJ550H
    3 and 4
  8. chacal
    Yeah, that's what I meant!................
  9. XJ550H
    I know and most of us would too .
  10. MaxRodax
    MaxRodax New Member
    Thanks both! I didnt notice the difference until I read Chacal's. Then I realized that 12 and 34 are match!
