2 Cylinders
Discussion in 'XJ Technical Chat' started by granitize, May 5, 2019.
  1. granitize
    granitize Member
    Canada - East Coast - Prince Edward Island
    Hiya..
    Had my '83 XJ550 Seca 550 checked out at the local shop.
    Running like a top!
    Then I put a couple of old OEM flashers on...
    During testing the flash didn't work for a second, and then the engine went down to 2 cylinders.
    Disconnecting the flashers/putting previous ones back on don't help!
    Any thoughts?
    I am an electrical donkey ...but do own a tester.
    The two events are unrelated, unless there is a fault in the wiring and the wires were moved when you changed the flasher relays out.
    Pull one spark plug at a time, lay the plug on the head, start the engine and check for spark.
    Which two are not firing?
    Cylinder order is (from left to right as you sit on the bike) 1, 2, 3, 4.
    Also check to see that the primary wires (small with spade terminals, under the fuel tank just below the frame backbone) to the coils are still hooked up (do that first).
  3. granitize
    granitize Member
    Hi k-moe.
    The connectors in the attached pic.?
    Thick wire from the harness?
    I see only one spade connector on the right side...
    Doesn't look like I ever had one on the left coil(?).
    No spark on cyl 1 and 4.
    The outside cylinders... both of which connect to the left coil.
  4. XJ550H
    ohm out the pickup coils, ohm out the ignition coils
  5. granitize
    granitize Member
    Any instructions written with pics for that?
  6. XJ550H
    the connector on the tci with black gray orange wires is to the pickup coils. left side connector.
    pickup coils
    get ohms reading from black wire to gray wire then from same black wire to orange wire.
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    ignition coils
    ohm from spark plug wire 1 to spark plug wire 4
    ohm out the primary connector should be red/white wire and orange or gray wire
    XJ550 models:
    Pick-up coils:
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    ohm primary ohm secondary the caps have been removed from secondary so you should get a reading of 11k ohms add 10 if caps are installed
    for primary 2.5 ohms.
    Timbox likes this.
  7. granitize
    granitize Member
    Wow... Thanks!
    Will have to do that tomorrow night though.
  8. k-moe
    Sorry about my mixup with the primary side connectors. I've been futzing around with a Virago and it has some PO wiring done to it.
  9. granitize
    granitize Member
    k-moe...
    I don't know any better! :)
    So only one primary connector is OK?
    Gonna see if I can figure out the ohm bits from Xj550H.
  10. granitize
    granitize Member
    Umm... Just call me stupid K?
    Some confirmation.
    Unplug first and use the female end?
    ignition coils
    ohm the actual wires?
    Pop off the caps and ..red in wire 1, and black in wire 2?
    Directly in the primary plug... OK.
  11. XJ550H
    unplug first you can test connector from back side where wires go into the connector
    yes on the ignition wires from 1 to 4
    you can leave the caps on you will add value of caps to reading
    I like to take caps off and test them individually
    granitize likes this.
  12. granitize
    granitize Member
    If I did it correctly...
    ohm @ pickup coil connector looks OK.
    Not a digital multimeter...
    but it's a bit above 50 @ x10 so that's marginally over 500 (~ 520?)
    Same plugged/unplugged ...and same on both orange and green -> to black.
    Just under 5 ... so maybe too low?
    Just under 2... so Maybe to low.
    This was the same on both sides.
  13. k-moe
    The ring terminal you circled is the ground, and there only should be one.
    The primary side connectors are circled in XJ55oH's post.
  14. XJ550H
    your meter is set to volts. set black knob to RX1K for plug wires and RX1 for the primarys (to the left of off)
    you also have a red thumb wheel to set it to zero before you start
  15. granitize
    granitize Member
    Thanks,
    What makes it be in volts?... I think I'm in ohms... but I don't really know.
    The whole dial turns eh?
    The "off" would move to the little white dot to turn off.
    - 1 click clockwise for RX1K
    - 3 clicks clockwise to RX1
    but yeah... inconsistent in the selections.
    The "set to zero" was off too.
    Will update tomorrow.
  16. k-moe
    You need this.
    how-to-use-a-multimeter-and-read-schematics-and-wiring-diagrams.68164
  17. granitize
    granitize Member
    Yes.. and a new digital mmeter as well!
  18. chacal
    Just be aware the digital MM's don't perform very well on low resistance values. Analog gauges are more difficult to use, but tend to read more accurately at very low resistance values. Of course, you do need to always remember to "zero" the ohms readings every time the meter is used, and every time the "ohms range" (e.g. X1, X10, X100, etc.) is changed.
    If that's an older model Radio Shack meter, it might be a pretty decent one, worth keeping.
    granitize and k-moe like this.
  19. k-moe
    You don't need a digital meter. What you have is perfectly fine for the work you'll be doing.
    I still use a $10 analog meter for most things, and I have what used to be a $400 digital Simpson meter at my disposal.
  20. granitize
    granitize Member
    Yeah - a very old RadioShack model - Put in a new battery so I could adjust to zero!
    That's better.
    Posting the results shortly - Question first.
    Whilst moving things around cylinder 4 came back to life.... ish...
    So I swapped the plugs between 1 and 2.
    2 stayed cold, while 1 had fire.... So plugs maybe too.
    I will get 4 new plugs but the question is:
    Would "failing" coils cause premature plug failure?
