20w50 oil
Discussion in 'XJ Technical Chat' started by Scottie1, May 12, 2018.
  1. Scottie1
    Scottie1 Active Member
    Columbia SC
    I have had my cam chain adjusted on my 1982 750 Seca but still have a bit of noise coming from it. I was told to try thicker oil I am running 10w40 at the moment would 20w50 be ok to use or can I add a quart of 20w50 to 10w 40 to thicken it a little bit. I live in South Carolina where it’s now hot weather when I ride.
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Fwiw, I live in Wisconsin and run 20w-50. Don't ride much when it gets real cold.
  3. Scottie1
    Columbia SC
    I didn’t want to run the wrong oil just Incase anything happens. I will try 20w50 see if that helps
  4. XJ550H
    you should be running 20w-40 by spec for your temps 10w30 is for under 60 degrees
  5. XJ550H
    DarbyC likes this.
  6. k-moe
    What does the noise sound like?
    A short video would be helpful.
    Oil won't make noises go away, and some noises are supposed to be there.
    kerriskandiesinc likes this.
  7. Jetfixer
    Clappy valves are happy valves. Noise in an aircooled engine is normal and will never go away completely. 20w40 is fine just do not use synthetic oil can cause clutch slippage and starter clutch problems . Kmoe has a good write up on oil read his thread. I have tried 20w50 and noticed no difference in noise but that is all subjective .
  8. Scottie1
    Columbia SC
    Here’s a video of the top half of engine where the noise is coming from
  9. Scottie1
    Columbia SC
    Ah it’s to large to post grrrr
  10. Scottie1
    Columbia SC
  11. kerriskandiesinc
    NY
    Doesn't sound normal, sounds a bit loud even for an air cooler.....the normal XJ whistle doesn't SEEM to be there.....
    Can you repost, and rev it off idle, up and down??
  12. Scottie1
    Columbia SC
    I will do it tomorrow and post it
