30% of the way there...
Discussion in 'Hangout Lounge' started by Zoot_Suit, Jan 5, 2024.
  1. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    The one thing that really bothers me the most is, the fundraiser motorcycle runs for Veterans is 99% of the reason I decided to buy the bike and start riding again. Taking care of my fellow veterans and honoring the memory of those who didn't make it home is important to me. Otherwise, my riding days were behind me.
    But I don't know if I'm more disappointed with the bike not working, or my failure to get it working.
  2. Timbox
    Timbox Well-Known Member
    Take a much-needed brake from it. Do something else for a week. No fundraiser is worth your mental health. The amount of people that will work on these older bikes is down to just people that love them. Most of us do it just for the challenge and the accomplishment at the end. Finding someone in your area might be hard. I am close to 60 and not many younger people in my area will even look at an older bike.
  3. Zoot_Suit
    Detroit, Mi
    The front brake is still only 50% and I still don't have properly working turn signals. But I found a blown fuse that was giving me a false positive when I tested it. It had continuity, but wasn't passing enough juice through.
    But I FINALLY got a successful test run on a public road.
    Timbox likes this.
  4. Franz
    Never quit, nice one you on the road.
  5. Timbox
    Good find on the fuse, the ones that open only under a load at rare, and hard to find. Great job sticking with the project and then getting some riding time in. Wonderful.
  6. Zoot_Suit
    Detroit, Mi
    I took a longer ride yesterday, and she ran great. I don't know how well the front brake works though, I never had to use it. Many decades ago I was a truck driver, so anytime I'm driving a manual, I just automatically compression brake. So I barely even had to use the rear brake, and didn't even touch the front.
    Tried yet another turn signal relay, and no dice on that one either. I didn't want to convert it all over to LED, but it's looking like I'm going to have to.
    And I'm going to have to roll the dice and gamble on a fleabay speedo gear so I can hopefully get the speedometer working again.
  7. Timbox
    Put a RAM mount on it and use the phone GPS for speed. I use WAZE ap all the time, love it. I would guess with use and riding that the front brake will get all the bubbles to the MC, and it will start to work better. When you pull the handle, does it stop before it reached the bar?
    Do you have a "power probe" for test equipment? That would work great for isolating the relay. I am guessing you have a wire or something off. Do you have any other turn signals, 4 of them in a parts bin? If you do, that the time to lay them out on a table and make a working with relay turn system. Just a thought.
  8. Zoot_Suit
    Detroit, Mi
    I used my Garmin GPS for a speedo, it seemed to work fine. I'm not a crazy rider, so really unless someone cuts me off, I rarely ever touch the brakes. I just go out for a casual cruise. The front brake has about 50% power after reverse bleeding it a few times. The manual rear drum works 100%, perfect.
    The OEM relay allows the turn signals to turn on, but not blink, the other six relays I tried literally do nothing, at all. I've even de-pinned the leads from the connector and tried different configurations and still nothing from the aftermarket relays. I've tested voltage across the wires and they test good, 12+ volts. I've resigned myself to having to convert them to LED, which is something I was planning to do... one day. But I liked the idea that the bike still has the 42 year old factory bulbs, that still work. So I was hoping to keep them on for a year or two. But that's not looking likely. Converting to LED should be (in theory) a relatively fast and cheap upgrade.
  9. minimuttly
    minimuttly Active Member
    UK
    Be faster and cheaper to fix the one you have?
    Why not ask forum members in the states if someone has a good relay? Or post you oem one to someone to verify if it works? Are the lamps fitted the right wattage?
  10. minimuttly
    UK
    Timbox likes this.
  11. Zoot_Suit
    Detroit, Mi
    Something I've noticed while riding.
    The bike struggles to do 50 MPH... in 2nd gear... because she wants to run even faster. :D
    Seriously, you twist that grip, she wants to hook and cook!
    Franz and Huntchuks like this.
  12. Zoot_Suit
    Detroit, Mi
    Just re-fueled and took a short ride.
  13. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Ready for the dumpster now??
    Franz likes this.
  14. Dave in Ireland
    Ireland
    I've run Avgas in a few vehicles. Not one of them ever went faster.
    Smoother, yes, but not faster.
  15. Zoot_Suit
    Detroit, Mi
    Higher octane does in fact help to go faster. Not by much, but faster simply because it leaves more power in reserve.
    The speed gain is usually only 2-5 mph, rather insignificant, but faster nonetheless.
    I've tried yet another OEM turn signal relay, with no luck. I've checked the switch, it's good, I've checked voltage it's good, I've checked fuses they're good. I'm going to have to convert to LED.
    Any suggestions for lighting for it?
  16. Zoot_Suit
    Detroit, Mi
    Yesterday I took the bike for it's maiden voyage onto the interstate, and she ran fine. Especially in the higher RPM's... :D
    However, because of my height (I'm very tall), I acted as a wind sail, and the bike seemed to want to rotate backwards. The front end wanted to keep coming off the ground. At 55 mph it wasn't too bad, up around 70...ish the front end got a little light.
    Any thoughts on adding a fairing to negate some of that?
    I did some more parking lot laps today. :D
  17. Zoot_Suit
    Detroit, Mi
    Logical, right? :D
  18. chris123
    chris123 Active Member
    Benicia, ca
    So, you’re saying you did a wheelie going 120mph in a 25 mph zone?
    And you did it on that bike?
    I’m going to need to see some proof on this one…
  19. Zoot_Suit
    Detroit, Mi
    It was a hypothetical inquiry. lol
    However, I have pulled a wheelie on it. I've also watched a video on YouTube of someone doing it too.
    It's not an easy thing to do with this bike, and you'll shorten the lifespan of your clutch significantly.
    chris123 likes this.
  20. chris123
    Benicia, ca
    Oh okay. I believe the wheelie.
