30% of the way there...
Discussion in 'Hangout Lounge' started by Zoot_Suit, Jan 5, 2024.
  1. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    Just polished the bare aluminum. I used the same 2K paint as I used for the fuel tank and side covers. It's supposed to be good up to 300°F, but time will tell.
    chris123 likes this.
  2. Zoot_Suit
    Detroit, Mi
    Just hand painted the side covers... with a dental pick. Snapchat-932867841.jpg
  3. Dan Gardner
    Minneapolis, MN
    That's really nice that you can bake the coating like that!
    What's the time/temp on a bake like that?
    Maybe a stupid question - but do you have to worry about heat effects on any gaskets or plastic chain guides or anything like that? (yes, I know they must be designed for heat since they are in an engine, that's why I said it maybe a stupid question).
    In the auto refinishing world, you can't use the same heat to bake as the OEM since there is typically a lot of stuff that would melt and disassembling would be cost prohibitive of course - so just curious.
  4. Franz
    That's why the cases are empty.
    Zoot_Suit likes this.
  5. Zoot_Suit
    Detroit, Mi
    There are no gaskets or plastics in the cases. I strip all of that stuff out when I hot tanked everything.
    I baked at 200F for 30 mins, cool for 30 mins, baked at 400F for 30 mins, cool for 30 mins, baked at 600F for 30 mins, then let cool.
    Dan Gardner and chris123 like this.
  6. Zoot_Suit
    Detroit, Mi
    Fleabay fail... again.
    At least the seller refunded my money and corrected the listing.
  7. Zoot_Suit
    Detroit, Mi
    Not so fun fact.
    On US models of the XJ650 Maxim, the brake caliper doesn't come off the fork.
    So now I have to figure out how to clean, repaint and rebuild it in place.
    Roast644 likes this.
  8. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    It's a unique front caliper, but it is removable. The pivot bolt described in the book is accessed from the bottom, underneath a plastic plug that hides the bolt head.
    I've looked at those "universal" master cylinders also. No matter what bike, or how many calipers they operate, or what the bore of the original master, they spec the exact same part....it magically fits everything! And of course it doesn't, and they definitely should be avoided.
  9. Zoot_Suit
    Detroit, Mi
    Woo Hoo! :D
    Roast644 and Franz like this.
  10. Franz
    Imagine having to buy a slider and caliper as one unit :eek:.
  11. Roast644
    WASHINGTON
    Nice! That caliper on the front of the 650 is the same as the rear brake on the 1100 (I've just recently discovered them myself!) . Seems like one of the few instances that Yamaha used a common part for dual purpose. Otherwise they seemed to radically change caliper designs between models and years....for what reason I dunno.
    You'll notice that the pads are tapered in thickness. That's normal, and necessary because of the swinging whilst clamping geometry.
    Edit! Ok, same design, same pads, but not interchangeable. They are mirrored left and right. So another unique design by Yamaha.
  12. Zoot_Suit
    Detroit, Mi
    The brake caliper is cleaned and painted. :D
  13. Zoot_Suit
    Detroit, Mi
    Side covers are finished. :D
    Franz, Roast644 and chris123 like this.
  14. Roast644
    WASHINGTON
    Those look great. It looks like you painted the "Maxim" the same color? How did you prep that, or peel off the old foil type cover?
  15. Zoot_Suit
    Detroit, Mi
    I powder coated the crash bars I bought off fleabay. :D
    Fuller56 and Dan Gardner like this.
  16. Zoot_Suit
    Detroit, Mi
    Yes, I painted "MAXIM" the same color (by hand, with a 6 hair paint brush, talk about tedious!).
    I sanded to 320, then applied a self etching primer.
  17. Zoot_Suit
    Detroit, Mi
    I've rebuilt the front master cylinder, except for the sight glass. Still waiting for that to arrive. Now onto the rear drum.
  18. Zoot_Suit
    Detroit, Mi
    Scrubbed, degreased, and soda blasted, then installed new brake shoes. :D
  19. Zoot_Suit
    Detroit, Mi
    Cleaned and repainted the disc to match the body color.
  20. Zoot_Suit
    Detroit, Mi
    Luckily I wear a respirator. I've done so much spraying on this bike. o_O
  21. Zoot_Suit
    Detroit, Mi
    I'm already tired tomorrow.
  22. Zoot_Suit
    Detroit, Mi
    I'm starting to see the finish line. :D
  23. Roast644
    WASHINGTON
    You're getting a heck of a lot of work done in a short time on this thing. Enjoying seeing the progress.
  24. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    nice color choice. my son's first car, given to him from his uncle
  25. Zoot_Suit
    Detroit, Mi
    May as well with as far as I went. :D
    Roast644 and Huntchuks like this.
  26. Roast644
    WASHINGTON
    I think you made the right call here! And that's really easy to say when you have to do all the work... :)
    Are you going to sandblast?
  27. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Looks already painted.
  28. Zoot_Suit
    Detroit, Mi
    Yes, I already painted it.
    I wire wheeled any rust, and gave it a light sanding. Then rattle canned with VHT Roll Bar and Chassis paint. (Seems to be a good epoxy coating)
    It came out quite nice.
    According to the directions it cures in 30 minutes, I decided to leave it overnight.
  29. Zoot_Suit
    Detroit, Mi
    Forward progress! :D
    chris123 and Roast644 like this.
  30. Zoot_Suit
    Detroit, Mi
    Any suggestions on what to do with the rust on the underside of the fender?
    The chrome on top isn't terrible, I should be able to polish it nicely. But the underside, I'm thinking sand and paint?
  31. Simmy
    Polish the chrome and move on.
    If you’re going to ride this bike it will get covered in dirt and you can’t see it anyway.
  32. Huntchuks
    East Rochester, NY
    To prevent possible rust through , you could clean off most rust, then de-rust with something like Evapo-Rust, paint if desired, then spray with undercoating.
  33. chris123
    chris123 Active Member
    Benicia, ca
    Another vote for rust treatment and undercoat spray.
    Excellent work. Can’t imagine how many hours you must’ve put into this project.
  34. Simmy
    That fender is perfectly normal.
    I think any paint you put there will flake anyway. If you’re worried about the rust just rub oil into it. After riding I’ll bet it looks like this again anyway
  35. Zoot_Suit
    Detroit, Mi
    I think I'm going to wire wheel the rust down to the base metal, prime and paint.
    While I ponder, I'll begin on the engine.
  36. Zoot_Suit
    Detroit, Mi
    Whew!
  37. Zoot_Suit
    Detroit, Mi
    I know what I'm doing... (nervously shifts eyes left and right)
    Franz, Roast644 and Huntchuks like this.
  38. Roast644
    WASHINGTON
    3 essential tools for any build...caffeine, nicotine and blue shop towels.
    Aurel and Zoot_Suit like this.
  39. Franz
    Did you change the chain guide? Not expensive part and it will save you a lot of work in future when the old one breaks up :eek:. Heat the bolts to soften the factory loctite and fit new bolts and torque then to spec.
  40. Zoot_Suit
    Detroit, Mi
    The OEM one is in fantastic shape.
    Franz likes this.
  41. Zoot_Suit
    Detroit, Mi
    Small victories. :D
  42. Zoot_Suit
    Detroit, Mi
    No one likes crusty nuts. o_O
  43. Zoot_Suit
    Detroit, Mi
    My concern is that I'm going to be using Permatex Ultra Grey and not Yamabond 4... I hope it's a suitable equivalent.
  44. Zoot_Suit
    Detroit, Mi
    She's coming together.
  45. Zoot_Suit
    Detroit, Mi
    F#CK!
    Because neither of shop manuals that I have were clear on it, I now have tear apart the engine that I just spent all day putting together, because I have a shim on the middle gear in the wrong place... :mad:
  46. Zoot_Suit
    Detroit, Mi
    GRRRRRRR!
  47. Zoot_Suit
    Detroit, Mi
    I'm now at a standstill on the engine.
    I'll start polishing the chrome tomorrow I guess.
  48. Simmy
  49. chris123
    Benicia, ca
    Sorry to see that. At least clutch baskets are still fairly easy to get on eBay, etc.
  50. Zoot_Suit
    Detroit, Mi
    While I wait for replacement parts...
    Huntchuks likes this.
