30% of the way there...
Discussion in 'Hangout Lounge' started by Zoot_Suit, Jan 5, 2024.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Some Evapo-Rust should clean up the rest and get it ready for coating.
  2. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    Clutch is back together. Finally!
    Franz and chris123 like this.
  3. Zoot_Suit
    Detroit, Mi
    I should be able to finish the engine assembly today. :D
    Roast644 and chris123 like this.
  4. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Slow down! You're making us all look bad! Haha seriously, nice work. Going to be a nice bike.
    Dan Gardner likes this.
  5. Zoot_Suit
    Detroit, Mi
    I've only been working on this since last August... :eek::D
    However, here's a handy little slowdown...
  6. Franz
    I put the engine on it's side when I am fitting them. Stuff a rag in the case opening too.
  7. Franz
    Don't say that :eek: I want to see the bike finished :p.
    Roast644 likes this.
  8. Zoot_Suit
    Detroit, Mi
    Yeah, I very quickly stuffed a rag in the hole after I fished the clip out.
    I should be putting it in the frame in two weeks.
    Oblivion and Huntchuks like this.
  9. Zoot_Suit
    Detroit, Mi
  10. chris123
    chris123 Active Member
    Benicia, ca
    Sasquatchan and Zoot_Suit like this.
  11. Zoot_Suit
    Detroit, Mi
    In the past 2 days, I've spent over 12 hours polishing chrome.
    chris123 likes this.
  12. Zoot_Suit
    Detroit, Mi
    I have to rebuild the forks, order new tires and turn signals, then she's ready for reassembly! :D
  13. Zoot_Suit
    Detroit, Mi
    Oops! I went too far...
  14. Zoot_Suit
    Detroit, Mi
  15. Zoot_Suit
    Detroit, Mi
    Amazing what stopping for a second to think can accomplish.
  16. Zoot_Suit
    Detroit, Mi
    Wow!
    Fuller56 and chris123 like this.
  17. Roast644
    WASHINGTON
    Hey @Zoot_Suit , I've got a pair of shocks that I want to try this same thing...did you disassemble the at all? Or just dunk the whole thing in Evaporust? Yours turned out great.
  18. Zoot_Suit
    Detroit, Mi
    I unbolted the shocks, didn't even clean them off, and put them in the Evapo-rust. I was amazed at how great it worked.
  19. Zoot_Suit
    Detroit, Mi
    No rest for the wicked...
  20. Zoot_Suit
    Detroit, Mi
  21. Zoot_Suit
    Detroit, Mi
    Her new shoes have arrived!
  22. Zoot_Suit
    Detroit, Mi
    WHEW!
    chris123 and Roast644 like this.
  23. Roast644
    WASHINGTON
    Nice. Avoided the Sawzall at least! When you painted your wheels, did you mask the edges of all the spokes, or did you clean the paint off after? Or is that powder coat?
  24. Zoot_Suit
    Detroit, Mi
    I masked the spokes and the edge of the rim.
    It took me an hour just to get the bead to seat on that tire. It just wouldn't pop no matter what I did. But it finally yielded to my stubbornness. :D
    I wasn't able to seat the front wheel because I have to pick up a new valve stem tomorrow.
  25. Zoot_Suit
    Detroit, Mi
    Okay, I did it to prove I can do it. Now I'll never have to prove it again. :eek:
  26. 7.62
    7.62 New Member
    California
    Zoot_Suit, depending on how many bikes you have and how much you ride it would be worth the investment to get a tire machine with a MC wheel attachment.
    Now that I'm pushing 60, using a tire machine has been much easier on my knees and back than when I'd wrestle on the concrete with tire irons.
    I recently put new rubber on my sons 650 Maxim, and from breaking the bead to seating the new tire it was less than 5 minutes per wheel, and I did it all while standing.
    When I was young I didn't think twice about tackling any wheel using tire irons. Not so much now, that's for sure.
    Zoot_Suit likes this.
  27. Zoot_Suit
    Detroit, Mi
    I am beat!
  28. Zoot_Suit
    Detroit, Mi
  29. Dan Gardner
    Minneapolis, MN
    Somebody around here has an extra swing arm bolt. I will look.
  30. Zoot_Suit
    Detroit, Mi
    The problem is, I need it back together within the next 72 hours.
  31. Roast644
    WASHINGTON
    I suspect I've got one also if you need it. Although your internal threads might be more of a concern. Maybe hit the bolt with a thread file and see if you can ease it back in to fix the internal part.
  32. Franz
    Use a thread chaser on the frame threads that you can wind in with a socket. A bolt the right size with flutes cut in it .
  33. Zoot_Suit
    Detroit, Mi
    I spent some time with some files, a Dremel, and wire wheels, then froze the bolt, and heated the frame and got it in. There some mild galling of the threads, but it's together.
  34. Zoot_Suit
    Detroit, Mi
    It seems the exhaust system is trying to get me to start drinking.
  35. Zoot_Suit
    Detroit, Mi
    Got it! Finally!
    Roast644 and Dan Gardner like this.
  36. Zoot_Suit
    Detroit, Mi
    I think I need to change my shorts... :Do_O
    Franz and Simmy like this.
  37. Zoot_Suit
    Detroit, Mi
    Okay, I backed the idle screw all the way out, and the only way it'll run is full throttle.
    I've checked the throttle and it's not binding anywhere.
    I'm stumped. Any suggestions?
  38. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    All the way out? its there for a reason. Screw it in till it just touches, then in a whole turn. your choke and throttle cables are correct way around?
  39. Zoot_Suit
    Detroit, Mi
    Yes, the cables are correct. The idle screw is where it should be.
    I suspect it is something with the butterflies from when I bench sync'd them. They're probably too far open. I'm going to readjust them and see how it goes.
  40. Zoot_Suit
    Detroit, Mi
    Hmmm...
    Timbox likes this.
  41. chris123
    Benicia, ca
    I’d check to make sure all the enrichment jets in your bowl are clear. If not I bet your pilot jets are the problem
  42. Zoot_Suit
    Detroit, Mi
    The carburetors have been rebuilt, they're like brand new.
  43. Zoot_Suit
    Detroit, Mi
    Is there a carburetor guru out there that knows the solution? It'll only fire up after I've poured fuel directly into the airbox. Then It'll only run full throttle. The RPM variance you hear is from me flipping the kill switch on and off.
  44. Minimutly
    West Wales, uk
    If they were like new you wouldn't be having this problem.....
    Take them out, strip and inspect. This is where you'll find your answer.
  45. Zoot_Suit
    Detroit, Mi
    I've removed the rebuilt carbs, and everything seems perfect. So I pulled the intake boots...
  46. Zoot_Suit
    Detroit, Mi
    She'll start if I spoon feed her, but then will only run as long as I keep the revs above 5K. I pulled the fuel line and cranked it over, and she was spitting fuel, and the bowls have fuel in them... Hmmm
  47. Zoot_Suit
    Detroit, Mi
    Let's see if it'll work...
  48. Roast644
    WASHINGTON
    It's a really pretty bike! Bummer that it's fighting you now, but you'll get it. Hold off on that chipper! Are you certain the enrichment jets in the bowls are clean? Did you get the Old Faithful geyser with carb spray to come out the top when sprayed in the bottom?
  49. Zoot_Suit
    Detroit, Mi
  50. Huntchuks
    East Rochester, NY
