30% of the way there...
Discussion in 'Hangout Lounge' started by Zoot_Suit, Jan 5, 2024.
  1. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    Okay... why doesn't it work?
    The speedometer is good. It spins right up when I grab the end of the cable and spin it by hand. And I've replaced EVERYTHING else from the speedometer down.
  2. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Forgot to install the piece that drives the gear?
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I think he is referring to his previous post where the speed indicated seemed to be too fast for the RPM's.
  4. Zoot_Suit
    Detroit, Mi
    False alarm!
    I JUST replaced that piece, I was spinning it by hand, but I must not have spun it enough revolutions for it to engage with the speedometer gear. Once I got going down the road, it clicked in and started working.
    ...like they all work. The GPS said 70 MPH, the speedometer said 74 MPH.
    But it works!
    ...finally. :D
    I'll worry about the turn signals over the winter. I'm just going to replace all of the lighting with LED. Anyone have some good aftermarket lighting suggestions?
  5. Zoot_Suit
    Detroit, Mi
    The chest buffeting is the lesser of the two evils.
  6. Dave in Ireland
    Ireland
    Safer for the licence that way. In most places it's illegal for a speedo to under-read, so the makers err the other way.
  7. Zoot_Suit
    Detroit, Mi
    Just took a rip up the interstate without the windshield and the helmet buffeting was gone... the chest buffeting was back, but I'll have to live with it.
    What's weird, is I've never experienced these issues on the other nine bikes I've owned over the decades. But that was a long time ago and the memory may not be what it was. :eek:
  8. Zoot_Suit
    Detroit, Mi
    Wish me (good) luck. :D
  9. Zoot_Suit
    Detroit, Mi
    I installed the rear lights, and they worked... briefly. Until I started working on the front lights. Now both right and left side blink at the same time. From what I understand, I simply have to remove the bulb from the indicator in the instrument cluster.
    I'll finish it up tomorrow. But they do look good. :D
  10. Zoot_Suit
    Detroit, Mi
    Now to see how long they last.
  11. Zoot_Suit
    Detroit, Mi
    This new fuse box works great as long as you don't try to hook up the power leads for the indicator LED's on it. It'll blow all the fuses. And it seems to only work when wired backwards. Oh well, it's up and running.
    Dave in Ireland and Huntchuks like this.
  12. Zoot_Suit
    Detroit, Mi
    Welp.... looks like I'll be replacing that POS fuse box, for some strange reason has a parasitic draw and is draining the battery.
    I'll have to go back to the old school glass fuses.
    ...makes me miss kick starters...
  13. minimuttly
    minimuttly Active Member
    UK
    So you'll need to explain how a fuse box - sorry, POS fuse box, is capable of creating its own current drain?
  14. Fuller56
    Fuller56 Well-Known Member
    Is that an actual fuse panel or a new style that uses circuit breakers and works electronically instead of fuses? As @minimuttly questioned how would a fuse panel cause a parasitic draw? The simple, replacement blade fuse type panels work wonderfully.
  15. Zoot_Suit
    Detroit, Mi
    It was this one...
  16. Huntchuks
    East Rochester, NY
    Cool looking device. The only current draw SHOULD be for the LED's.
    Zoot_Suit likes this.
  17. Zoot_Suit
    Detroit, Mi
    Yeah, "should" be... ah, it was worth a shot. I already ordered a replacement OEM style box, it'll be here next week.
  18. Zoot_Suit
    Detroit, Mi
    I replaced that POS fuse box with a new OEM style box. However, it doesn't seem to be charging. That other box either toasted my battery or the voltage regulator...
    I had to use a jump box to get it started, did laps for about 20 minutes, but the battery didn't charge.
  19. Zoot_Suit
    Detroit, Mi
    I've replaced the "new and improved" electronic blade style fuse box with an OEM style glass fuse box and discovered the electronic box fried my new AGM battery. So I have replaced that with a new gel battery, and it all works now.
    ...what a headache. Now I just have to source (for spares) the glass fuses. No one seems to stock these particular fuses, I believe they're a "type II"...? All the glass fuses that everyone stocks are either too long, or too short.
    However, the good news is, I've finally finished it all just in time to winterize the bike and put it away until May of 2025 when we defrost from our frozen tundra.
  20. Zoot_Suit
    Detroit, Mi
    I tested out the chin bar mount for my camera.
    It gives a better (higher) view and smoother video over my chest mount, but because I wear a modular helmet (HJC C91) the strap interferes with the button to raise the chin bar.
    So, chin bar vs chest mount... eh, six of one, half a dozen of the other.
  21. Zoot_Suit
    Detroit, Mi
  22. Zoot_Suit
    Detroit, Mi
    The first half of the video was Friday evening, 70°, sunny, perfect riding weather. The second half was the following morning, 38°, foggy, wet, frosty... I couldn't see squat. :eek:
  23. Zoot_Suit
    Detroit, Mi
    Last night's ride home from work.
    I tried a half helmet... how on earth can anyone think these are a good idea?
    The wind grabbed it and buffeted it all around, and the wind noise was deafening. At highway speeds you couldn't even hear yourself scream, let alone hear the bike.
    I'll be sticking with my full face / modular helmet. It slips through the air and is quiet.
  24. Zoot_Suit
    Detroit, Mi
  25. Zoot_Suit
    Detroit, Mi
    Minor temporary change.
  26. Zoot_Suit
    Detroit, Mi
  27. Zoot_Suit
    Detroit, Mi
  28. Zoot_Suit
    Detroit, Mi
  29. Zoot_Suit
    Detroit, Mi
    Winter is coming...
  30. Zoot_Suit
    Detroit, Mi
    At least the weather forecasters said it's not going to stick to the roads, just the grassy areas. o_O
  31. Zoot_Suit
    Detroit, Mi
    I'm 99% of the way there. :D
    chacal likes this.
  32. Zoot_Suit
    Detroit, Mi
    The bags aren't rubbing on the shocks anymore. :D
    Rooster53 likes this.
  33. Zoot_Suit
    Detroit, Mi
    I was honestly just going to do a little burnout... oops. :D
    They were holding up signs that read "Spin it bitch!"... well, I tried to spin the wheel around the axle, but instead I spun the bike around the axle.
    By back almost touched pavement and the headlight was aiming at the sky.:cool:
    I might have it on video... from two different angles...
    Dave in Ireland likes this.
  34. chacal
    Oh brother..........
    That'll get the adrenaline flowing!
  35. Zoot_Suit
    Detroit, Mi
    Flowing like a river. :D
  36. Zoot_Suit
    Detroit, Mi
    If I'm getting into her guts, she'll only get about 15mpg, in stop and go city riding, about 20mpg, average riding, about 26mpg, and highway riding, about 34mpg.
  37. Zoot_Suit
    Detroit, Mi
    Winter is coming...
    How my day went...
    It should be here by the end of the week. :cool:
    Huntchuks likes this.
