3D Scanning
Discussion in 'Hangout Lounge' started by gurgietrueshot, Mar 6, 2009.
  1. gurgietrueshot
    gurgietrueshot Member
    Kansas
  2. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    isn't technology great?
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Wow, its like Star Trek! Its absolutely amazes me that it can print the parts fully functioning without assembly
  4. Robert
    Hey Chacal, this would make creating parts super easy!
  5. Blackout550
    Blackout550 Member
    Minnesota
    My work does rapid prototyping and production using about the same technolgy. we have a bunch of 3D systems machines and a few scanners. We use it mostly for the hearing business, ear shells for hearing aids and monitors for singers. but we have done some random stuff for 3M etc.
    its awesome technology for sure. The stuff he was showing is pretty afordable. but the machines my work has are 1/4million and up, and very acurate.
  6. gurgietrueshot
    Kansas
    I wonder how that scanner would stand up against some of your equipment Blackout. That technology is advancing fast enough that that little device might be as good as some of your older equipment. I'm sure your newer stuff would blow it out of the water though.
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    That is about the coolest thing I've seen in a long time.
  8. chacal
    Yes, I saw one of those machines in action at a SEMA show about 6 years ago, pretty amazing.............but I made the mistake of leaving the booth rep my name & number, and they've called me about every 6 days since then to try and sell me one (or two, or three.......)
    I read a long time ago that the Navy actually was the pioneers in the use of this technology, that they use them on aircraft carriers (or other major ships that are away from port for extended periods and need to be self-sufficient), but rather than just being able to create plastic prototypes, they can mold/machine/produce items from a variety of materials (plastics, metal, rubber, etc.) This is useful since you don't want to carry a huge supply of excess inventory on-board for a huge variety of different common or, especially, specialized items (such as is found on a huge boat), and it's much more cost effective to carry significant supplies of base, raw materials which can then be magically created "on the fly, on-the-spot" via the use of this (and similar) technology.........
  9. Deadulus
    Deadulus Member
    Dufur, Oregon
    Len, the last ship I was on in the Navy, from '86-'90, got a prototype stereo scanner...was HUGE and they used it for making pump housings they could then make molds from. One guy also figured out how to make ships bells with it...and a few other odds and ends.
    I never got to see it work, but got to work with one of the 'blanks' for an electromechanical valve body....was a resin of some kind.
    We got a lot of nifty things the Navy was trying out, we got an automated ATM system instead of checks we went to an onboard ATM to withdraw cash from our accounts...was really cool.
  10. ktcubed
    ktcubed Member
    St. Augustine, FL
    I saw one at an FETC conference that worked more like a dot matrix printer. The part would slowly retreat from the "print head" and then be covered up by a very small amount of raw material powder. The head would then scan over it heating or injecting a glue that held the whole thing togther. They had some very intricate parts made. Of course, Jay could have just molded a reverse, used that to mold a wax version and then use a lost wax process with molten metal. (no where near as cool but much cheaper in theory and equipment).
  11. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Thats wicked awesome! All those parts we cant order anymore?? Thing of the past
  12. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Chacal,
    Are you going to get one of these to make parts to sell? If so, you rock! If not, you still rock!
  13. chacal
    Thanks Wesley. The real beauty of those machines like featured on the Leno segment is for prototyping, rather than for production (unless they are low-heat, low-strength plastic parts that you want to make!). And they are Very Expensive. So I don't see one in my future anytime soon.......but, hopefully, I can talk some of my suppliers into getting one!
  14. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I have three words - SECA side Covers! :wink:
    whip up a big batch of those and the machine would pay for itself!
  15. Blackout550
    Blackout550 Member
    Minnesota
    for larger parts that dont need to be super accurate that scanner/printer is better. The SLA Resin machines and 3D scanners we have are for smaller parts that need to be very accurate. Which makes even very small prototypes not too cheap.
    http://www.3dsystems.com/
    we have 6 of these
    http://www.3dsystems.com/products/sla/v ... er_sla.asp
    and 2 of these..but not ipro just pro
    http://www.3dsystems.com/products/sla/i ... o_9000.asp
