4bb Engine to 82' 750 Seca frame
Discussion in 'XJ Modifications' started by Finnish Cafe, Feb 15, 2023.
  1. Finnish Cafe
    Finnish Cafe Member
    Finland
    Few weeks ago I bought this 750 Seca whit blown engine, started wondering what would my choices be for a engine, since I'm not too familiar with Yamahas besides outboard engines, speakers and pianos. Tried to collect as much information I could and ended up choosing latest 900 engine that is supposed to be bolt on for the frame, 4bb. I was hovering over 4km Diversion engine too but decided that it would have been too severe frame modification to make space for tilted cylinders and all other surprises so I took the easy(er) way. Ordered 65tkm 91' XJ900F engine from Germany through ebay and carbs from Baboon in Netherlands. Carbs came last friday and looked to be in reasonable condition, they were from 92' model XJ900F. Just had time today to clean them, I glass blasted them gently from outside and washed 2 times with ultrasonic cleaner before disassembling and then two times disassembled. They came out pretty nice. I blowed them dry with air and applied light coat of universal oil to every part, tomorrow I will get repair kits for them and assemble. Tomorrow will also be the big day, engine is arriving. Its gonna get busy now. IMG20230215180028.jpg
    Rooster53 and Simmy like this.
  2. Finnish Cafe
    Finnish Cafe Member
    Finland
    Got the engine. It's in a bit of rustic condition, bike has probably been stored outside but nothing too crazy. Checked valve clearances first thing, they were all spot on in the middle of the values and everything i side looked clean and good as new. One of the front mounting bolts has seized in the eyelet of the engine and exhaust studs I need to change, little polishing / glass bead blasting for the casings, cylinders and head. Clutch, alternator and valve covers etc I have from 750 engine and they are in good condition. What about the exhaust primaries and collector, are they usable from 750? Tried to find their actual differences but nothing solid yet. Glass seems to be the way to go with engine casings, soda can't remove all the oxidization. IMG20230216181121.jpg
    Dave in Ireland likes this.
  3. Finnish Cafe
    Finnish Cafe Member
    Finland
    Got some work done today. Blasted engine with 10kg of glass beads, it's still not show quality but it's for the road not the show anyway. I also realized today that the valve covers in 750 and 900 engines are different, so I had to clean that badly oxidized one that came with the engine. I didn't have time or patience to polish it to mirror finish but it's good enough, I still might paint it at some point. Carbs are also all done, it's not that far from the point of mounting in frame now. (Might even happen tomorrow.) IMG20230221204354.jpg
  4. Simmy
    the 900 cams have bearing supports at each end which makes the head wider.
  5. Finnish Cafe
    Finnish Cafe Member
    Finland
    Yeah, and 750 have wider space for cams. It's kinda weird that Yamaha has made so small design changes trough years, as the diversion era 4KM engine is visually still very similar even though it has more forward tilted cylinders and probably million other changes. Maybe it just is that when you build good engine once you don't need to do it again for 30 years or so
    Dave in Ireland and Simmy like this.
  6. Finnish Cafe
    Finnish Cafe Member
    Finland
    So, engine is in the frame. Tight to squeeze it in but when it's in there it fits to every mounting point as it should. Looks big as it fills the space nicely, like it. When mounting these engines to frame it seems to be best to go in from right hand side as drive shaft is little less of a pain that way. C IMG20230223193418.jpg Changed few covers from old engine as well as stator which was in much better shape. IMG20230223184452.jpg 750 engines output shaft cover (?) Won't fit, ask me why I know. Breather case inside the cover has little extra space for bigger gear (I think). Other than that it seems to be the same. It's coming together nicely right now. 750 exhaust seems to fit 900 head, I think size of the primary pipes is same, or difference is about 1mm if any.
    Roast644 and Dave in Ireland like this.
  7. Finnish Cafe
    Finnish Cafe Member
    Finland
    Throttle cable is mounted differently in 900 engines Mikuni BS36 than 750 engines original Hitachis, so I had to build new mount from zero. I mounted piece of cut to form 20mm plastic under 2 mounting bolts of carbs 2 and 3 caps, then bolted a steel piece to that with cable mount. It's extremely tight spot, allmost everything needs to be made adjustable, here's a little video about that. https://youtube.com/shorts/PpzyYzqnH8w?feature=share
  8. Finnish Cafe
    Finnish Cafe Member
    Finland
    And then there was life. Got her running last night, new engine sounds pretty good, no weird noises and responds to throttle nicely. Something wrong with petcock though, starves when I try to keep revs up, dries out filter. Plenty to do still, air box modification for bs36 carbs, gotta find some nice silencers, short conicals maybe. Then carb syncing, front end needs some attention too. But in Finland we have some waiting to do still before riding season, gotta keep busy.
  9. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Wow, great work on that bike! And an awfully short curve to go from "I don't know anything about Yamahas" to building something like that. The chopped frame is usually is not appealing to me, but I've seen a few in this scrambler style that look great. Very nice!
  10. Finnish Cafe
    Finnish Cafe Member
    Finland
    Thanks! I have some experience with bike building but it's mostly Triumph efi triple world where I feel at home. But building experience with anything always helps, I have been building crane trucks for last 12 years, that gives pretty solid backrest for solving building problems or at least courage to try to. We also have pretty nice workshop with crane, lathe, mill, press, mig, tig and stick welders, pipe bending possibilities, hydraulic hose crimping press, tire installing machine etc. So it's easier to work with hobby stuff if there is that rare spare moment to do so.
    Roast644 likes this.
  11. Finnish Cafe
    Finnish Cafe Member
    Finland
    Airbox situation. From 32mm to 36mm carbs not only the diameter increases but the spacing for the carbs too because 36mm carbs are larger every way. Carbs 2 and 3 are close enough to work without any modifications but 1 and 4 are too close to just connect with silicon hose and there's too little space between airbox and carbs to make any sort of bent pipe between so I needed to move holes in the airbox to the very edge of the box. IMG20230302175802.jpg I opened holes big enough to put 50mm silicon hose through it, and from inside the box I inserted 25mm piece of 50mm aluminium tube to the hose to lock it in place. IMG20230302175905.jpg
    To be sure I put a zip tie over the hose but it's really tight fit anyway.
    IMG20230302194251.jpg Openings for 1 and 4 I cut to the edge of the box, then inserted hoses through the flanges I made from 1.6mm steel plate, locked hose to flange with same 25mm alu tube ring and fitted them with polyurethane compound and 4 rivets each. IMG20230302201215.jpg I also applied some poly compound over the hoses where it goes through the box, even though it was so tight fit that it was 100% sealed fit before, overkill is the way. In last pic pipes are aligned with carbs pretty nicely, I still have to cut them to right length but that should be the easy part. Also some cleaning of the urethane is due and black paint after that, that thing doesn't look too good yet. Oh, got a 12Ah Exide AGM battery today too.
  12. Finnish Cafe
    Finnish Cafe Member
    Finland
    That of course didn't work at all. There's not enough space for those pipes at all, I made the hoses longer and locked them in place with 10mm slices of that pipe outside the box so they won't back out when installing carbs. It wasn't easy but I got carbs in place and airbox mounted, don't really look forward doing that again anytime soon. ‍
  13. Finnish Cafe
    Finnish Cafe Member
    Finland
    It was carb syncing time today. I really don't know how much sync is altered with silencers as there is only 4-2 collector box in place now but I have to check it again after I get some pipes for her. I didn't have YICS plugged while syncing but eventually I got all carbs to run pretty close to the spec, 28.7-30kPa at idle.
    Also noticed that there's no charge at all, have to check that next. IMG20230305170012.jpg
    AndyH64 and Franz like this.
  14. Finnish Cafe
    Finnish Cafe Member
    Finland
    https://youtube.com/shorts/RNskq86Xr_o?feature=share She's charging now. Had to change alternator rotor, it was only thing charging related that I didn't change from old motor. Don't really know what could be wrong with it but now voltage is ok, lights on at idle 12.7V but jumps to 14.7V in about 2000rpm. Fitted headpipes and collector like they should be, except collector holding bolt in the middle. Ordered cheap Emgo Slashcuts for mufflers, if they are too loud I'll bite the bullet and order MAD exhaust's Scrambler mufflers, they would look great but cost over double. I still need to get oil cooler and rebuild front end but getting there. Petcock works now too.
  15. Finnish Cafe
    Finnish Cafe Member
    Finland
    IMG20230309185300.jpg Slip ons came today. Surprisingly they aren't stupidly loud and have pretty nice low tone and little distortion up high. Fixed oil pipe leak too and couple of oil coolers are on the way. (Needed one for Triumph too.)
    Minimutly likes this.
  16. Finnish Cafe
    Finnish Cafe Member
    Finland
    https://youtube.com/shorts/-kicwiEnq_I?feature=share took her for a spin. In over 10cm of fresh snow it wasn't long one but maiden voyage anyway. It feels like that could be really fun bike to ride when I get front suspension done and weather stops that constant nonsense with white stuff.
  17. Finnish Cafe
    Finnish Cafe Member
    Finland
    Piece of junk aluminium might find its place as a side panel, looks too heavy now but if I come up with something to lighten the look it might stay. IMG20230314191801.jpg
  18. tobar
    tobar Member
    england
    bike looks great..run it without the alu as in the previous pic
  19. Finnish Cafe
    Finnish Cafe Member
    Finland
    Thx.
    I would but there's reg/rec and fuse box etc. there, they need some protection from rain. I will cut that cover smaller so it leaves frame tubes visible and might soda blast edges to matte finish too, lwe'll see how it goes down. New oil cooler is now fitted, that in my opinion looks really nice for a chinese universal part, some hoses to do next. IMG20230321215828.jpg IMG20230321215802.jpg
    Franz likes this.
  20. Franz
    Oil cooler looks great. Are you using a different adapter plate at the crankcase?
  21. Finnish Cafe
    Finnish Cafe Member
    Finland
    No, 4bb engines original. Didn't get cooler with bike and needed one for my Triumph too so ordered 2 of these. I'll use original flange and few cm of original pipe, from there I'll go with 10L hydraulic fitting - steel braided teflon hose - 12mm banjo fittings in the cooler end.
  22. Franz
    Cool that is what I was thinking and I am using the parts from a 900S Diversion (well the oil filter bolt) so I can convert it to a spin on oil filter. I might have to get the threads cut a little more and shorten the bolt a little so that the adapted fits snugly to the crankcase.
    Finnish Cafe likes this.
  23. Finnish Cafe
    Finnish Cafe Member
    Finland
    I like the look of that original finned filter casing and will probably keep it, spin on is easier for service though but that doesn't bother me.
  24. Franz
    Yes it is a personal preference, your bike is looking great.
  25. Finnish Cafe
    Finnish Cafe Member
    Finland
    IMG20230324145641.jpg Some progress with side panel. I narrowed it by 30mm and soda blasted edges to satin matte finish, it's much better now. Still waiting for round 80mm golden Yamaha emblems to stick to the middle. Had some spare time (ok, stole it from work, got me.) today, made license plate side mount bracket, steel mount under rear shock nut and piece of soda blasted matte aluminium, bolt led to one corner for plate light and done. Simple man keeps it simple. IMG20230324145641.jpg IMG20230324182316.jpg IMG20230324184402.jpg
  26. Finnish Cafe
    Finnish Cafe Member
    Finland
    While back I ordered canvas saddle bags and rear bag for this bike without really considering if and how they would fit with chopped frame and cafe seat. Well, obviously they don't. Saddlebags maybe, with some fiddling but rear bag no way. Well, after I got wrong parts for a crane once again I had some time to spare, so I ordered luggage rack from my own one man company. Had plenty of 16x2mm hydraulic pipe laying around so that was obvious choise of material. Few bends and plenty of head scratching later it looked like attached pic that I can't get to obey and stay here but anyway
    Then some "beautiful" welding happened, it's not that fun to weld zinc coated hydraulic pipe that has zinc inside and outside but enough current gets the job done. It eventually came out pretty good, It will be secured to frame by pins for easy installation and removal so even though it's not a showroom finished thing of beauty it will mostly be covered by luggage anyway. IMG20230327183312.jpg
  27. Finnish Cafe
    Finnish Cafe Member
    Finland
    Side panels are done, front fork service done, saddlebags with quick release are done, quickly removable rear luggage rack done, rear brake light switch installed too. Oil cooler lines still on to do list but that's only major thing keeping me away from the open road besides weather. IMG20230405185753.jpg IMG20230405190937.jpg
    Franz and Huntchuks like this.
  28. Finnish Cafe
    Finnish Cafe Member
    Finland
    Got the cooler lines done too today as I had to go hydraulics store anyway. It was also sunny and +8C so there was no excuse to stay at the workshop anymore, got about 50km test ride done. She pulls like a freight train, surprisingly strong torque through the rev range and at the upper register there is certainly enough pull for a 40+ year cruiser bike, got even some accidental tire spin in 1st gear with only throttle, no clutch involved. Roads are still dirty at some points and my tires are not the grippiest ones but still, had so much fun IMG20230406175223.jpg .
  29. Finnish Cafe
    Finnish Cafe Member
    Finland
    300km test ride to my summer house in middle Finland. Not too warm yet, but Yamaha purrs like kitten. Perfect weather for ice fishing is good enough for riding a bike. Swans seem to be little lost since they have came back for summer and it's not quite here yet. 1680951664554.jpg
  30. Finnish Cafe
    Finnish Cafe Member
    Finland
    Came back from visiting family today and was greeted by view of Yamaha laying on its side. Ice had melted under center stand and she collapsed to her side. Luckily there was big snow pile under there so not much damage, right side tank emblem is little loose and carbs were flooded, gotta check better tomorrow in daylight.
    Huntchuks likes this.
