550 clutch,trans issues,rebuild clutch,still stalls
Discussion in 'XJ Technical Chat' started by Rayray65, Jan 6, 2017.
  1. Rayray65
    Rayray65 New Member
    Roch.hills mi
    Help lol it's 10' up here and propane is expensive
    OK. The others may not have read your original question, so add some detail.
    My first question to you is, what made you decide to put in a new clutch? Be as detailed and specific as you can. I'm not convinced that the clutch is the root of your problem, but we need to know more.
  3. XJ550H
    does it stall when you put it in gear?
    is your sidestand down when you put it in gear? another safety switch
    lift seat at rear of tool tray near fender is a cube relay remove it it disables the sidestand safety switch
    I do also still have concerns about the differences you mentioned in the clutch you were sold. Just bcause you got it from a dealer does not preclude it from being the wrong part. BTDT, have the parts sitting on my shelf.
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Welcome to winter.
    Let these guys give you some solid advice and wait for some slightly warmer temperatures to move in. More often than not it is best to go slowly with the troubleshooting process. Being in a hurry can create headaches.
  6. Rayray65
    Rayray65 New Member
    Roch.hills mi
    Here's the whole story,got the bike from a neighbor.had been sitting for years ,bought a battery,cleaned carbs and tank.new plugs .started runs great ,put in gear and stalled.so took clutch apart cleaned it up ,did not have boss spring ,or special friction plate.bought boss spring and new gadget.put it back together with the help of clutch 101 on you site .back to stall when I put in gear
  7. XJ550H
    that is your sidestand safety switch remove the relay and see if the problem goes away. your bike thinks the sidestand is down when you put it in gear
  8. k-moe
    Yep. You have an electrical issue, not a clutch issue.
    Also pop the rubber boot off of the swich and give the switch a good cleaning with contact cleaner to get rid of the grime that's making it sitck.
    And check the valve clearances. It's not a part of your problem, but has likely never been done.
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I concur with doctors Kmoe and Xj550, the symptoms are just what my 550 does when sidestand switch is sticking.
  10. Rayray65
    Rayray65 New Member
    Roch.hills mi
    You guys rock !!,just took the xj 550 for a rip ,kinda like snowmobileing without snow ,9' here had a blast .it was that relay for the kickstand .going to paint tank and exhaust,black out!!
  11. k-moe
    The relay is probably fine. Did you clean the switch and check for broken wires or corroded terminals?
  12. XJ550H
    as Kmoe said you should check the switch and connectors out . clean or replace if needed.
    the removal of the relay is just a test for the sidestand safety switch being bad.
