550 Maxim suddenly popping fuses
Discussion in 'XJ Technical Chat' started by Jeremy Trice, May 5, 2025.
  1. Jeremy Trice
    Jeremy Trice New Member
    Mississippi
    Well I started my bike for a few minutes. Cut it off then when I tried to start it again it fired then just died. Ignition Fuse was blown so I replaced it and could literally watch them pop as I hit the start button! Also pooped the main fuse! Start button seems touchy and sometimes doesn’t seem to connect right when you press it. Could it be the start button? Any assistance would be appreciated. Thanks!!
  2. Jeremy Trice
    Mississippi
    I checked the start button and everything looks ok. I’ve noticed it’s popping the ignition fuse and it’s just as the bike is about to start. It’s like it’s sending a surge. It’s been fine until I replaced all my fuses. I put an automotive style fuse block on it years ago.
  3. Timbox
    Guessing, you either have a bad starter solenoid or you have a wire that has rubber all the insulation off. That wire would run from starter button under the tank to the solenoid. Will the fuse blow even with the ignition off?
    Roast644 and Jeremy Trice like this.
  4. Simmy
    check the wiring where it rubs the frame when the bars are turned L to R.
    I've seen this to cause blown fuses.
    Jeremy Trice likes this.
  5. Jeremy Trice
    Mississippi
    No it only blows after I hit the start button and the engine turns over for a few seconds. Then just as it starts to fire up it pops.
    Timbox likes this.
  6. Jeremy Trice
    Mississippi
    Well I unhooked the connector for the left side handle bar controls and it stopped blowing the ignition fuse. Also the guage lights started working again. They had stopped working after I got the wires in the headlight bucket hooked back up. Had some trouble getting the turn signals hooked back up and working as someone has been in there before and did a lot of splicing on and such. Even though I had the turn signals and things working there is evidently something hooked up wrong. Will have to revisit the headlight bucket I reckon
  7. Timbox
    Would be great to see some pics of that left handle bar control, next time you get in there. Those little contacts are interesting to solder, takes a bit to get them correct.
    Good troubleshooting and way to stick with it.
  8. Rooster53
    Normally there is no ignition power routed to the left handlebar control, so either some creative wiring has been done or the head or signal fuse was the one blowing along with the main.
    Since you mentioned you had to start it then most likely it would have been the Head fuse as the headlight relay routes power to the left control after startup
    It is quite easy to pinch a wire when closing the controls resulting in as short to ground
    chacal likes this.
