550 oil level switch connection - help to locate?
Discussion in 'XJ Technical Chat' started by a100man, Mar 6, 2024.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    Spotted the oil level sensor cable hanging below my bike when I went to start it up , ready for Spring.
    The cable from the sensor is about 2 feet long but I couldn't find an obvious place to connect it..
    ..this maybe becasue the wire colour is white on this motor (YX or FZ 600) and should be red/black I think.
    Ultimately I think it goes to the diode block in teh haedlight bowl but I think there must be another connection before that.
    It started fine btw once I jumped it from my car.
    Cheers
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    on the XJ600, (which should be the same as the Fj600 and YX600) , there is a connector near the top of the middle frame tube around the air box area, its a bullet connector to the red/black wire
  3. a100man
    Bedford, UK
    Ta - most of the bike is an '83 550. I was looking for a white connector at first.. I think perhaps I'll have teh tank off as there was nothing obvious under the seat/airbox area. Cheers
