Wanted 550 Seca engine
Discussion in 'For Sale, Trade/Swap, Wanted' started by JEFF MARTIN, Jun 11, 2020.
  1. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Hi all -
    I just picked up my first Seca, after wanting on since 1982. The transmission seems to be stuck in gear and I'm concerned that the engine may be shot. Anyone got a 550 Seca engine available that they could part with?
    Jeff Martin
    Buffalo, NY
  2. hogfiddles
    Any xj550 engine will work. Why do you say the transmission is stuck in gear?
  3. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Hi -
    Thanks for writing!
    Well, I can't move the shift lever, and the chain has been taken off the rear sprocket, I assume so it can be rolled around. I'm hoping, if I can re-engage the chain and rock the bike a little, I can get it to shift. I bought it last Friday and I'm picking it up tomorrow.
    Isn't there a horsepower or gearing difference between the seca and maxim? I guessed they're physically the same, just wasnt sure if there was a performance difference.
    Thanks.
    Jeff
  4. dkavanagh
    Rochester, NY
    The Seca has a hotter cam. AFAIK, that's the only difference.
  5. mechanicalmadness2
    mechanicalmadness2 Member
    Buffalo
    What part of Buffalo are you in? I might be able to take a swing by and take a look at your bike. I do have an extra engine that needs some love(just valves as far as i know), but I’m probably going to hold on to it for a bit.
  6. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    I'm in Cheektowaga, near the Galleria.
  7. mechanicalmadness2
    Buffalo
    Ha! Hello neighbor.
  8. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    No kiddin'! You in Cheektowaga as well?
  9. mechanicalmadness2
    Buffalo
    Yes sir. Like 2 minutes from the galleria.
  10. hogfiddles
  11. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Ok, so a bit more lift, letting the engine breathe better. That would pick up the performance a bit!
  12. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Here it is, all cleaned up . . .
  13. dkavanagh
    Rochester, NY
    Nice! I was smiling till I saw the chain! Seriously, looking good though!
  14. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Thanks very much. The bike in your profile pic is very nice!
  15. Franz
    Is your drive chain locking the engine sprocket against the case?
  16. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    I'm not sure. I havent taken the primary cover off the engine yet. I will look.
  17. hogfiddles
    Now you gotta find the side covers.... hope you already have the battery side one, otherwise you’re gonna be in for a shock! Not to mention finding the correct mufflers—-
  18. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    I have the side covers. Looking for the mufflers.
  19. Fuller56
    Fuller56 Well-Known Member
    What are the chances the engine/transmission are "locked up" due to the cam chain tensioner coming apart and jamming the trans? I have not experienced that but have read about it here. Fixing that would eliminate the want for the replacement engine. Just asking......
    John
  20. hogfiddles
    I may have n extra left muffler, but I need a right side muffler—-lol
  21. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Hi John -
    Good question. I'm not that deeply into it yet, but that's a great suggestion.
  22. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Really! Are you thinking of letting that left muffler go?
  23. hogfiddles
    Maaaaybeeee...... I’d really like to trade for an extra Right, but send me a private conversation.
    I MIGHT have an extra 550 engine, too... I’ll hafta check to see if I still have that. I don’t recall if it’s still here or not.
    I’m just a few hrs East of you..... below Utica
    dfox
  24. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    Yes sir. That was exactly the problem!
  25. JEFF MARTIN
    JEFF MARTIN Member
    Cheektowaga, NY
    So, it appears I actually dont need an engine, so y'all can call off the search. Thanks for responding and offering advice.
    Now, I'm looking for the rubber grommets that hold the side covers on.
  26. Franz
    Chacal will have them. You can contact him at info@XJ4ever.
    hogfiddles likes this.
