650 swap
Discussion in 'XJ Technical Chat' started by Nic, Sep 24, 2017.
  1. Nic
    Nic Member
    Philadelphia
    So I have a 82 xj650, trying to find out what parts of the 82 xj750 will fit I know someone who has one for cheap with no title.
    the motor is a simple swap
    controls are different but I belive connectors are the same just check to see if mating wires match tank swap possible see the thread on that
    if both are yics motors the tci is same.
    atari guages need atari wiring but there are a few people looking for then here
    if both are maxims rims will swap you couls convert 650 to dual disc unless it is a seca then it has dual discs
    Fuel tank interchange information
  3. k-moe
    The big questioon is, which 650 do you have?
    I'm assuming the Maxim from your avatar.
    The other biggie is which 750.
  4. Nic
    Nic Member
    Philadelphia
    650 j
  5. Nic
    Nic Member
    Philadelphia
    I want everything I can get
  6. k-moe
    If the 750 engine is fom a Maxim.
    If it's from a Seca then there are (relatively easy) modifications that need to be done to the motor mounts, unless he wants to solid-mount the engine.
  7. k-moe
    Does this mean that you really want to have a 750 instead of a 650?
    The things that I would swap are the engine, the forks (maybe), and the fuel tank. Nothing else is worth the effort IMO.
  8. Nic
    Nic Member
    Philadelphia
    Yes I was thinking engine forks and of course the front tire, question will the exhaust work with the 650 engine
  9. k-moe
    Yes it will, but if you swap engines you'll not be needing the 750 exhaust installed on the 650 engine, since it won't be on your machine anymore.
  10. Nic
    Nic Member
    Philadelphia
    Yes thanks I will ride with the 650 engine until I get the 750 in will I have to change anything else to get the engine in
  11. Nic
    Nic Member
    Philadelphia
    Thanks for your time
  12. k-moe
    That depends on whether the 750 engine is from a Maxim or a Seca.
  13. hogfiddles
    Detailed engine swap info is already in the Information Overload Hour
  14. Nic
    Nic Member
    Philadelphia
    Both are Maxim
