650j drive shaft question
Discussion in 'XJ Technical Chat' started by rdbhere2, Dec 27, 2008.
  1. rdbhere2
    rdbhere2 Member
    Does anyone know the exact length of a 650j drive shaft? Thanks
  2. chacal
    With or without the u-joint installed?
  3. rdbhere2
    rdbhere2 Member
    drive shaft only without u joint
  4. chacal
    11-1/4" overall length. The 1980-81 650 Maxim driveshaft is the same length, and will interchange, but the shaft thickness (diameter) is a little smaller than the '82-3 version.
    The 700/900 driveshaft is a bit longer (12-5/8") and quite a bit thicker, and requires a different u-joint.
  5. rdbhere2
    rdbhere2 Member
    Thanks chacal. My winter project is a swingarm mod and i needed the stock drive shaft length to plan ahead.
    P.S. I'll be placing an order with you in a few days, your fast shipping has spoiled me.
  6. chacal
    You're welcome! Good luck with your mods.
    I hate it when that happens......... :D
