700 maxim not charging
Discussion in 'XJ Technical Chat' started by Lucas Elliott, Jul 22, 2022.
  1. Lucas Elliott
    Lucas Elliott New Member
    Maine US
    86' xj700 not charging. Has brand new battery. Tested reg/rec in forward and reverse bias both +/- and all good. Did resistance test between all 3 windings and all at .4/.5. As well as each winding to ground with all 3 O.L. anyone know what else I could check/test? I'm stumped. Connections seem to be good as well. TIA
  2. Franz
    Carbon brushes?
  3. Lucas Elliott
    Maine US
    To be honest I don't know too much about older brushed type. Like carbon buildup?
  4. Franz
    Not so much carbon buildup but the brushes need to touch the rotor and the rotor rings should be clean. If they are not touching your charging system cannot work. The brushes have wear limits but they can also lose conductivity I read if they are old. Do you have a Haynes manual for your bike?
  5. Franz
  6. Lucas Elliott
    Maine US
    I will have to check and I'll post a pic
  7. Lucas Elliott
    Maine US
  8. Lucas Elliott
    Maine US
  9. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I agree that it is probably your brushes. Had a problem with mine. So bad, that at idle, hitting the brake would some time cause it to shut off. Order from Chacal. Not a difficult job. Be sure to get a gasket since yours will be toast when you remove it.
  10. Franz
    What do the brushes look like with regards to the wear limit marks? You should change them anyway mabe the original ones if it's a very low mileage machine.
  11. Lucas Elliott
    Maine US
  12. tabaka45
    Brunswick, Georgia
    They look fine to me. However, were saturated with oil since I had a slight oil leak from the shaft seal.
  13. Franz
    Yes those brushes are in good condition.
  14. Dan Gardner
    Minneapolis, MN
    My 700's charging system was kind of struggling. I ended up cleaning the brushes and rotor and installing the correct battery. That seemed to fix it.
  15. Franz
    You can clean the slip rings with crocus cloth not sure which grade though. As fine as you can get.
