700x efi conversion
Discussion in 'XJ Technical Chat' started by Troy Mccall, May 9, 2020.
  1. Troy Mccall
    Troy Mccall New Member
    florida
    I
    dont have the experience to go tampering with other coils so ig the stock ones will do ....that said could i use the throttle bodies from a gsxr600 ive seen talk about it before
  2. Troy Mccall
    florida
    @SQLGuy by the way are there any other ecu options by any chance
  3. SQLGuy
    SQLGuy Well-Known Member
    Maybe you could use the GSXR ECU?
    Ecotrons makes small engine FI stuff, but only one or two cylinder. Not sure if the ECU they use for the EX250 could be adapted for four cylinder use. Their software is horrible, though, so I wouldn't really recommend it.
  4. Troy Mccall
    florida
    Ill look into the gsxr ecu then wander if theres an difference in firing order
  5. SQLGuy
    Why would firing order matter? You just wire it so it fires correctly. If Suzuki isn't doing sequential injection, then it problem doesn't matter anyway... pretty sure every transverse four is going to have 1/4 up at the same time that 2/3 are down.
    The bigger concern is more likely how Suzuki's sensors - especially their crank position sensor - can be mounted to your engine.
    There's also the question of whether they're using Kettering coils or CDI...
  6. Troy Mccall
    florida
  7. SQLGuy
    No. You would also need to figure out all the other sensors, and the air box, and the fuel pump, and whatever Suzuki uses for a "choke", and maybe an O2 sensor, and then there's the question of how well the GSXR tune will work on an XJ700X, and whether it can be modified.
  8. Troy Mccall
    florida
    Other then the cps the o2 collant temp and mas air flow what else would i need
  9. SQLGuy
    The fuel pump is probably going to be the most complicated piece to fit.
    I doubt Suzuki is using a MAF. They are probably running speed density or Alpha N. If it were a MAF it would be easier, since that would likely self-tune to a large extent.
    There's also IAT (inlet air temperature).
  10. SQLGuy
    After reading around a bit, it looks like the GSXR 600 uses sequential fuel injection, so you would also need a cam position sensor.
  11. Troy Mccall
    florida
    Oof so that takes the gsxr ecu out because i have no idea how i would make that work i wander if any other bike has similarly sized throttle bodies
  12. SQLGuy
    I'm not sure I understand your conclusion. You were confident you could attach the crank position sensor setup of a GXSR to your XJ, but not the cam position sensor? And why does that mean you couldn't use GSXR throttle bodies? They don't have to be used with GXSR ECU. They don't even have to be fired sequentially. If they're batch fired, though, idle will probably be richer and rougher.
  13. Troy Mccall
    florida
    Oh ...well i guess its still worth a shot ill look into other parts for this Frankenstein bike im building then but the reason i said something about the throttle bodies is because i want to see if any other bikes have cheaper throttle bodies
  14. SQLGuy
