750 carb mixing screw size
Discussion in 'XJ Technical Chat' started by mirco, Apr 24, 2017.
  1. mirco
    mirco Member
    LaGrange Ohio
    Hi All - can someone please tell the mixing screw size for a 750 Seca carb?
  2. mirco
    mirco Member
    LaGrange Ohio
    Here's a pic.
  3. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    You know what I see in that picture... ezy out... Man... chacal has the replacement mix screws as they are fine and course threaded plus he does a thread tap to fix a slightly mangled thread.
    Give him a PM, he'll get you underway.
    ... arrrgh ezy out... man I swear I have never had one work.
  4. Toomanybikes
    Tsawwassen bc
    It looks to be a milling drill bit to make a clean hole for the easy out
  5. mirco
    mirco Member
    LaGrange Ohio
    I own a machine shop - just need to know screw size please.
  6. XJ550H
    are you asking about the thread pitch ? there are course and fine pitch threads on them depending on when the carbs were manufactured.
  7. mirco
    mirco Member
    LaGrange Ohio
    Pitch and diameter.
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Mikuni or Hitachi?
    32 or 33's? - or whatever other sizes they come in?
    As XJ550H said, the pitch/ diameter varies with different carbs.
    Or take a screw out of one of the 3 remaining carbs and measure the threads . . . .
  9. mirco
    mirco Member
    LaGrange Ohio
    The owner can get me the info this evening. I was just hoping to finish the job while it was on the machine without have to setup again.
    I don't know if they're Hitachi or mikuni - no marking that I can see.
    To measure size what do I measure - intake throat at airbox side - intake bore at engine side - or slide dia?
  10. mirco
    mirco Member
    LaGrange Ohio
    If I get that info will you know the screw size?
  11. chacal
    Hitachi fine thread mix screws (this is what should be on 1982-83 XJ650 Hitachi carbs and all XJ750 Hitachi carbs):
    m6 x .50tp
    Hitachi coarse thread mix screws (should be on 1980-81 XJ650 Hitachi carbs, maybe some early 1982 XJ650 Hitachi carbs): m6 x .75tp
    P.S. those are Hitachi carbs in your image, and if they were Mikuni carbs, you'd know it, as they have the word MIKUNI cast into the side of the body (Hitachi carbs just have a small "snowflake" type figure cast into them).
    Stumplifter likes this.
  12. mirco
    mirco Member
    LaGrange Ohio
    Thanks Len! If you need anything let me know. We have expanded our business since we last worked together. I hired two good guys.
  13. mirco
    mirco Member
    LaGrange Ohio
    And three more cnc's.
    chacal likes this.
  14. mirco
    mirco Member
    LaGrange Ohio
    Surgery complete ... pieces parts accounted for. Thanks Chacal!
    k-moe and Stumplifter like this.
  15. chacal
    Good job young man!
  16. mirco
    mirco Member
    LaGrange Ohio
    Thanks Chacal! And thanks again for your help - saved me a setup.
