750 Maxim Clutch upgrade question's
Discussion in 'XJ Technical Chat' started by Jerrod Robinson1086, Feb 26, 2022.
  1. Jerrod Robinson1086
    Jerrod Robinson1086 Member
    Marion Ohio
    Hey Guy's, I have an 82 XJ-750 Maxim ive been tinkering on for a few years now. I put a Mack 4 into 1 on it, made some intake Modification's and Jetted it out to #130. The Bike has responded very well, but the Stock Clutch has not. I made a Cable adjustment that got it to hook up ok, but I cannot Ride it like this indefinitely. I need to upgrade the Clutch, I found a few kits from a Company called EBC on Ebay but don't wanna Buy Junk Part's. Any Advice??
  2. mlew
    mlew Well-Known Member
    Apex, NC
    EBC parts are not junk, they are one of the best in the aftermarket for brake and clutch parts.
    Buy a set of plates and a NEW set of heavy duty clutch springs . No more slippage
  3. Franz
    Plus bolts.
    Jetfixer likes this.
  4. XJ550H
    heavy duty clutch springs are the way to go if you have slippage and have done all the adjustments properly.
    if you search for it there is a company that will put together a kit for you based on and mods you have done.
    a big question is what kind of oil are you using . it has to be motorcycle jaso ma/ma2 rated oil.
    automotive oil will cause slippage.
  5. Jerrod Robinson1086
    Marion Ohio
    Valvoline 10W-40 4 Cycle. I have it where it's shifting fine now, but I can't put the Bike in Neutral with the Engine Running. And yeah I planned on upgrading everything, Spring's and at least new Factory Disc's
  6. Jerrod Robinson1086
    Marion Ohio
    Everything was fine until I replaced the Boot's on My Pod's with the Boot's that came on my Factory Airbox. It seriously woke this old Motor up.
    XJ550H likes this.
  7. Jerrod Robinson1086
    Marion Ohio
    So I decided to take a look at the Plate's Today, and found that 4 of my Steel Plates we're pretty much black. Good New's is my Bike came with a backup Motor from an 82 Seca. So I combined both Clutch's and it made a huge difference...
  8. Jerrod Robinson1086
    Marion Ohio
    I feel like it's still slipping some up above 6k when the power really starts coming on, but I can easily find Neutral again and it's Shift's World's better.
