750 Seca to run with 650 Carbs?
Discussion in 'XJ Technical Chat' started by Secacsm89, Jul 24, 2024.
  1. Secacsm89
    Secacsm89 Member
    My 32 mm carbs are thoroughly rebuilt and benched tested. The engine will only run at high RPMs , Can't adjust idle speed, using stock air-box. Note carbs are 650-32mm. w/124 main jets. Also, adjusting the carb idle star knob between the carbs has no affect.
