750 to 550
Discussion in 'XJ Technical Chat' started by Zachary Austin Mealer, Sep 13, 2018.
  1. Zachary Austin Mealer
    Zachary Austin Mealer New Member
    San Diego
    Will the 550 gauges work on the 750s, if both are maxims?
    Not without wiring changes on the 750.
    What wiring changes will depend on what year 750.
    You will need to add an electric tach to the 550 gauge cluster, since the 550 tach is cable driven.
    Short answer: not easily.
  3. Zachary Austin Mealer
    San Diego
    Hmmm, I've got an 82 750 maxim. Looking for some relatively cheap gauges that aren't huge. Completely open to suggestions
    Toomanybikes likes this.
  4. Toomanybikes
    Tsawwassen bc
    Convert to xj650 maxim just no fuel gauge. 83 750 uses xj650 setup.
  5. k-moe
    Wiring will still need to be done though.
  6. k-moe
    This is the Seca link. The maxim wiring is a tad different, but I can't find the link for that.
    A wiring diagram will clue you in to the differences though.
    ATARI delete
  7. Zachary Austin Mealer
    San Diego
    I got the schematics. Now from those is it plug and play?
  8. hogfiddles
    NO
  9. Zachary Austin Mealer
    San Diego
    Sorry, pretty new to all this. How about running LEDs for blinker and head light? Do I need anything in the wiring for that?
  10. hogfiddles
    You can run LED's but realize:
    Turnsignals will need to have resistors of one sort or another to trigger the flasher
    Headlights may have ballasts---ballasts have size and create heat....your room inside the bucket is limited
