81 Seca 750 and 82 Maxim 750 Compatability?
Discussion in 'XJ Technical Chat' started by Danny De Leon, Aug 31, 2021.
  1. Danny De Leon
    Danny De Leon New Member
    Lancaster, Pennsylvania
    I'm currently building an 82 Maxim 750 and I ran across someone selling an 81 Seca 750. I'm thinking of buying it for parts but before I buy it I'd like to know how compatible the 2 are... any thoughts? Thanks.
  2. Jetfixer
    Actually not a lot , the Seca forks have an anti dive , the master cylinder is cable operated , the gas tank is a different shape , the insturment cluster is different, the handle bars are different, side covers tail piece, seat, tail light as well. The engine mounts are different as well , but I think it can be modified to work . Carbs are the same though ( jetting might be different) you still should buy it .
  3. Danny De Leon
    Thanks man, I appreciate it. I think I will buy it. Honestly, the price is low enough that it's worth it even if it's just for the tires lol.
    There is quite a bit that is compatable, if not exactly the same.
    For example; I have a Maxim engine cases and the necessary rubber mounts on my Seca.
    The entire front end will swap over.
    The fuel tank will swap, but you actually have a larger tank on the Maxim.
    Get the bike. It might even be worth getting it rideable instead of using it for parts.
