81 XJ550 maxim - white/blue smoke out of pipes
Discussion in 'XJ Technical Chat' started by MJCXJ550, Jan 20, 2018.
  1. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    Bike sat for years and I just got the carbs totally rebuilt including throttle shaft seales, fuel inlet T & connector tube seals. It runs good now but getting white exhaust at the end of the pipes and then turns to blue exhaust like it is burning oil. Just drained the oil and it smelled like there might be gas in it. The magnetic tip on the drain plug had some fine metal on it but not much. Letting it drain really good and then will put fresh oil in.
    What do you think the smoke is from- gas in the oil, rings/cylinder bad, lifters needing reset??
    It didn’t burn oil before and it only has 6600 miles on it.
    white would be moisture in the exhust.Blue, oil could be leaking on the valve seals or head gasket.
    rings could be stuck may free up or you may need to treat it with acetone/atf mixture for a few days.
    Do a compression test
    was it old oil to start with?
  3. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    The oil was changed before it was stored so it had been in there for several years. I will check compression.
    +1 on it being stuck rings, or hardened valve guide seals. Since it starts, just run it for now, and keep an eye on oil consumption. The rings should free up. If not, then do a soak with a tablespoon or two of a 50/50 mix of acetone and automatic transmission fluid down the spark plug holes.
    hogfiddles likes this.
  5. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    Compression is #1-118, #2-110, #3-116, #4-118
  6. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Did you check the fuel levels after the carbs were rebuilt?
  7. XJ550H
    spec
    Minimum: 100 psi
    Standard: 121 psi
    Maximum: 135 psi
    Max. variance between lowest and highest: 14 psi
    so your numbers are good
    also time to check your valve clearances. comp may improve if you need to change shims
    look to see if your spark plugs have oil on them
  8. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    Plug 1&2 were tan and 3&4 was black/wet looking.
    I will move on to the valve clearances now.
  9. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    I set them to dry height specs.
  10. XJ550H
    this is how to set and check fuel levels
    Setting the fuel levels
    3&4 black and wet may be oil post a photo of them
