81 xj550 project
Discussion in 'XJ Modifications' started by saftie, Mar 29, 2015.
  1. saftie
    New York, NY
    Ah, that's why it didn't work.
    And I was about to slowly warm up the fuel-water mixture with a propane torch to make the water evaporate.
    (Thanks for the correction though, I knew it started with a "d". Lol )
    Well, at least I'm still laughing. And the bike has her name for a good reason.
  2. saftie
    New York, NY
    Probably the only time it will get wet... Man, I love this color.
  3. saftie
    New York, NY
    Quick question: how long does it usually take to get all the air out of a new front brake setup? New Mc, new line, empty brake.
    I am using a vacuum pump, but I might be doing something wrong. I do get some liquid, but still lots of air. Currently I am doing this: fill up reservoir, apply vacuum, pull brake lever and open valve. Close valve, release brake lever. Apply vacuum again, pull lever, open valve, close valve, release lever etc. Yesterday I tried just applying vacuum without pulling and releasing brake lever. But no success either.
    Or maybe it just takes quite some time?
  4. Dexter680
    Dexter680 New Member
    South Africa
    Have you tried to just gravity bleed it for a few hours? Might be worth a shot
  5. saftie
    New York, NY
    Not yet. But I couldn't leave it over night in case the reservoir runs dry, no?
  6. hogfiddles
    Sounds like something isn't closed yet.... Still sucking in air....
  7. saftie
    New York, NY
    Left tank in my car all day which got enough sun to dry up any water.
    Spoke to the shop that did the tank. Didn't come from them. I realized that I would have noticed when handling the tank while putting petcock on.
    So either dirty gas or something inside tank came lose with the fuel.
    But fear not, I just ordered a mini camera that I can hook up to my phone...
    Depstech Micro USB Borescope Waterproof Inspection Camera for Laptops and USB OTG Compatible Android Smartphones - 11.48 ft (3.5 m) https://www.amazon.com/dp/B016RLEUIS/ref=cm_sw_r_other_apa_Yi4qxb88B3YH7
  8. hogfiddles
    That way you can SEE when you're out of gas
  9. saftie
    New York, NY
    Always good to have visual confirmation. Gonna put a permanent monitor on the handlebar :)
  10. saftie
    New York, NY
    Ordered a new petcock which is now finally holding the fuel. The other one was still leaking.
    I put some gas in before I left for the long weekend. Let's see how it looks on Monday when back home. And I'm hoping to get at least 15 mins on the bike before I have to leave for my business trip again on Wednesday.
  11. hogfiddles
    Keeping fingers crossed for you....
  12. saftie
    New York, NY
    Thanks Dave. "Tropical rainfall" forecasted for Monday. So that sucks.
  13. saftie
    New York, NY
    Tank is on and seat is installed.
    Still need to do front brake, trying the reverse thing tomorrow. Using a syringe to fill it from the bottom upwards. Oh and hooking up the brakes to the brake light.
    But should be OK for a slow ride around the block. Definitely want to do it before heading out for business tomorrow evening.
  14. saftie
    New York, NY
    Well, my test ride on Wednesday didn't go so well. Bike kept stalling and would only run with choke. Think I need to do some adjustments when back. Color tune maybe and idle screw? Had to push it back half a block because it would not stay on.
    Back next Sunday and will be off the next day. Hopefully I get it sorted. It did run fine a few weeks back and would idle by itself with no choke. But no big deal. I'll spend some time and figure out out.
  15. k-moe
    I think you're on the right track. Do a running synch as well if you can.
  16. saftie
    New York, NY
    Yes, I can and will do a running sync as well.
    Btw, any tricks on how to turn the idle screw when big hands make it difficult to really reach it?
  17. k-moe
    Bribe the neighbor-kid with pizza.
    I find it's easest to reach from the right side of the bike, while kneeling.
  18. chacal
    It's like you're praying to your carbs, that's the real secret...............
  19. hogfiddles
    Hence. "CHURCH. Of Clean"
    Lol
  20. chacal
    You got it!
  21. saftie
    New York, NY
    Back from my trip, hoping to get some bike time tomorrow.
    Since the bike only stays running on choke at the moment, how would I go about color tuning?
  22. k-moe
    You would not. If it's still only running on choke once it's warmed up, and the pilot screws are at 2 1/2 turns out, then there is still something wrong.
  23. hogfiddles
    If need be, send'em back up and I'll double-check my work, but here's a question.... Did you replace the manifold boots? I know Jayrodoh had the same thing happening, and it turned out his boots were delaminating on the inside. That solved it.......
    It doesn't make sense that it's happening now, though, after you've been riding it a little while ago......
  24. saftie
    New York, NY
    Gotcha.
    No, didn't replace them. They don't look perfect anymore but they didn't leak either last time I checked.
    Well, let's see. I'll go through everything again today and report back
  25. saftie
    New York, NY
    Just wanted to fire her up real quick but nothing happened. No cranking, but lights are on. Giving it a good charge now and will see what happens in a few hours...
  26. hogfiddles
    Could it be that some of the sandblasting sand from having the tank cleaned got caught and clogging enricher tubes And/or jets
  27. saftie
    New York, NY
    I have petcock filter as well as inline filter. So far it looks clear.
    But it should still crank, even if there was an issue with fuel.
  28. hogfiddles
    Yeah.....so many people mix up 'cranking' with 'firing'.....my bad. I should know you of all people would be using correct terms..
  29. saftie
    New York, NY
    Weird. Checked everything (wire connections are ok) and bridged the starter relay to check. It cranked.
    Tested the starter button again right after and it cranked. Still not sure what it is/was, maybe the starter relay? It was new though. Now everything is working. Strange
  30. saftie
    New York, NY
    No issues with bike after I gave it a bit more idle using the idle adjustment screw. Been riding around the block a few times. Now I just need a front brake to make it less scary :)
    Also need to fine tune a little. It's OK but I know it can do better.
  31. hogfiddles
    Very possible that the starter button has some bad contact Spot
  32. saftie
    New York, NY
    Yes, possible. I opened the starter button assembly but didn't see anything that looked wrong.
    Let's see how it behaves in the future. It was just really weird, especially how it got fixed.
  33. hogfiddles
    When that happens for me, wi wiggle the button back and forth while depressing it to see if I can get a contact. More often than not, that works.....
  34. saftie
    New York, NY
    Hmm, not much to wiggle. It's an aftermarket one that is basically just a small round button.
  35. hogfiddles
    Correct, but the back of it is an even smaller point they can fill up with dirt, corrosion, or get worn. Wiggling it can often get that momentary contact that is needed
  36. saftie
    New York, NY
    Cool, I will check that should it happen again.
  37. saftie
    New York, NY
    Finally found the time to connect brake switches to tail light but will have to take bike to a shop for front brake. That's the last thing to do (other than building side covers at some point).
    I just can't get any pressure into the system. I used this shop before a few times and he said he'd have a look.
    I'll get my inspection done right after.
  38. hogfiddles
    Is it possible that you're having trouble because of the low angle on the handlebars vs. the steeper stock angle?
    Dave
  39. saftie
    New York, NY
    Not sure.
    I did make sure reservior is full at all times.
    The old one I had (and could not find a lever for) made up for the clipon angle. The new one does not. But it should still be good.
    One thing is can try is to put the bike on the side stand to really level it and try again.
    Other than that, no idea.
    Never had issues with bleeding a system, however this is the first time I do it on a completely dry system.
  40. saftie
    New York, NY
    Finally managed to do the color tune. 1 and 2 were way lean. 3 and 4 were good.
    Bike ran well, even better than before, until it stalled on me at a stop sign. And since it wouldn't turn on again because the battery was dead, I had to push it home. Walk of shame....
    Now I'll have to check charging system just to be safe- thanks Dave for the phone call.
    I did a lot without charging battery over the last weeks (bike on and off, wiring etc), let's hope it's just that.
  41. saftie
    New York, NY
    Major Pita strikes again.
    Just tested battery with bike off and on (revving the engine pretty good).
    No change in voltage which leaves me to believe the charging system is no good.
    And nope, other than putting a new rectifier on, I haven't touched anything else.
    I'll browse the forum and/or manual later on for trouble shooting help..
  42. saftie
    New York, NY
    BTW, i have a lithium battery, in case that matters for whatever reason...
  43. saftie
    New York, NY
    But on a positive note, bike idles easier and quicker now after letting off the choke. Color tune helped there I guess.
  44. k-moe
    The voltage did not go up at all when measured at 2,500 RPM, or when measured at 4,000 RPM?
    Before you decide that the regulator is bad, have you (I forget) inspected/ cleaned/ replaced the alternator brushes and cleaned the rotor traces?
  45. saftie
    New York, NY
  46. saftie
    New York, NY
    Opened the alternator and it was dirty. I cleaned it up, brushes looked good as well. Still no increase in voltage at higher rpm.
    Didn't have much time today, hoping to spend an hour or two tonight.
    I did check the three white wires but a: not sure I set up the meter correctly (but I think so) and b: I am getting different readings than what's in manual. If I remember correctly, it says 0.5 ohm, I get 1.2 on all of them. So maybe there is an issue?
    But I have no idea what that means/if it means that. Completely dumb when it comes to electrical stuff.
  47. k-moe
    Have patience. We'll learn ya.
  48. saftie
    New York, NY
    Thanks. Good to have that support. I'll dig into it tonight, hopefully, and report back.
  49. saftie
    New York, NY
    At least I have an ambitious motorcycle.
    The way things are going Major Pita will soon be General Pita. I hope I don't have to see the day when I promote it to Predident.
  50. saftie
    New York, NY
    I read somewhere that you can check the alternator and whether it generates a magnetic field by holding a feeler gauge close to the cover and see if it gets attracted. Theory sounds good, but in practice?
