81 xj650 shifter issue
Discussion in 'XJ Technical Chat' started by Davit Apikyan, Sep 3, 2018.
Tags:
  1. Davit Apikyan
    Davit Apikyan New Member
    CA
    Hey guys new to the forums and I am a new owner of a xj650, so 2 days ago I bought a xj650 1981 and it had this shifter issue, like when you are riding it sometimes it goes into the next gear and sometimes it doesnt like you have to tap the shifter to make it go into the next. The guy I got it from said its like a 40 dollar spring, he called it the return spring for the shifter. Can you guys please help me out thanks.
  2. hogfiddles
    Never listen to what a previous owner/seller tells you unless it some from here.
    It could be a clutch return spring, BUT
    It could be the chain guide
    It could be the shift dogs, it could be the clutch
    Etc......
    We'll help you troubleshoot
  3. Davit Apikyan
    CA
    ok so it did end up being the shifter return spring and it started working, I have been riding it to school and back for the last two days and its good.
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    David,
    I know...don't fix what's not broken but you might want to pull the cover and insure the spring is good. Just saying.
    Gary H.
  5. Polock
    rarely do things fix themselves, it's just not broke as bad as it was before
  6. rocs82650
    Middle Tennessee
    Exactly.
    Gary H.
  7. Davit Apikyan
    CA
    HAHA i did replace the part with a good one thats why it started working.
    But now there is a new issue nothing works on the bike the bike shut off as i was riding it and I tried to start it and it wont start absolutely nothing is turning on not even the horn. I connected jumpers to the battery and i checked the voltage of the battery and its 12.6 which is good. I am sort of lost
  8. rocs82650
    Middle Tennessee
    Is the bike in neutral?
    What is the voltage w/o the cables?
    Gary H.
  9. Davit Apikyan
    CA
    without the cables it was 12.6 and yea it was in neutral
  10. rocs82650
    Middle Tennessee
    Take a old screwdriver and jump across the two post on the solenoid (it's to the left when facing the battery).
    Gary H.
  11. Davit Apikyan
    CA
    yea I will do that tomorrow but its just weird that nothing is working not even the horn, or lights.
  12. rocs82650
    Middle Tennessee
    It could be a few things.Process of elimination is in effect. Is the fuse box stock? Also tomorrow check for 12v to and through the box.
    Gary H.
  13. Davit Apikyan
    CA
    yea its stock and everything seemed to be good but i will check for voltage and all that tomorrow. thank you so much for your help
  14. rocs82650
    Middle Tennessee
    It's what we're all here for :).
    Gary H.
  15. Polock
    put the old spring back in :)
