'81 XJ750 Seca starter won't turn off
Discussion in 'XJ Technical Chat' started by Jasonh, Feb 23, 2018.
  1. Jasonh
    Jasonh '81 XJ750 Seca
    Toronto, Ontario
    Last weekend I was trying to start my Seca. After a few intervals of running the starter (10 seconds at a time so I don't burn the starter), the starter stuck ON. Even turning off the key, etc wouldn't stop it. I had to remove the battery cable. When I re-attach, the starter kicks back on continually. I'm thinking my starter solenoid (which I just replaced last year) is stuck on. Am I right, or other suggestions ?
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Sounds likely. Also recommend cleaning the starter button contacts. You could also disconnect the smaller wires of the solenoid that go to the button and see if it still engages when the battery is hooked up. This will tell you if it's in the solenoid itself or if it is in the start circuit of the bikes wiring harness
  3. Jasonh
    Toronto, Ontario
    I cleaned starter button contacts last year, but good point on removing the solenoid wires. It keep churning, even after turning off the key so I suspect the solenoid is fried closed. :-/
  4. Chitwood
    Sounds like it to me as well
  5. Polock
    Elon Musk had that same problem once
    Frapfrap and chacal like this.
  6. XJ550H
    if the contacts are welded or stuck removing the small wires will do nothing.
    if removing the small wires stops the starter your starter button is sticking
    3ed option possibly way low on oil and solinoid grounded back through the oil level switch
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    So, should Jason toss it into outer space?
  8. Jetfixer
    I had the same thing happen on my Seca ....replaced solenoid ...no more issues
  9. XJ550H
    his solenoid is most likely the problem, but it is nice to be sure before he purchases one .
    the small wires are connected to the coil of the solenoid relay so if removing them stops the starter it should be a starter button issue
    if removing the small wires did not stop starter then his contacts are stuck closed and would need a new solenoid.
    solenoid can also be ohmed out to check it meter would tell you if contacts are stuck, and if coil is shorted or burnt open.
    starter button can be tested from connector of small solenoid wire by connecting meter to battery and starter button lead. press button look for 12 volts
  10. Polock
    no need to remove wires, turn the kill switch to off and stop the electrons
    XJ550H likes this.
  11. XJ550H
    yes if it were starter button related OP turned key off and starter kept turning
