82 bobber project!
Discussion in 'XJ Modifications' started by prometheus, Jun 29, 2012.
  1. gitsum911
    gitsum911 Member
    utah
    Awesome thanxs man I just looked it up and they only had one for 299 but it looked amazing its for sure the setup I want so maybe by this next season. And congrags on the beautiful ride, what did u name her?
  2. beerhound
    beerhound Member
    Queensland Australia
  3. prometheus
    prometheus New Member
    Vancouver bc
    im not sure if my exhaust is aftermarket, off another type of bike, or oem (canadian model). but it came like that haha, from the 2 other maxims ive seen so far none of them look like mine
    heres the one i bought:
    http://www.ebay.ca/itm/380452321811?ssP ... 1423.l2649
    note: the temperature gauge wire is too short to make it to a bolt on the engine. other than that it everything works good
    and the dash indicators:
    http://www.ebay.ca/itm/230825657613?ssP ... 1423.l2649
    wiring for the indicators is very simple if u need a wiring diaghram let me kno.
  4. gitsum911
    gitsum911 Member
    utah
    Hey thanx for all the info and listing site ill get one ordered and installed
  5. volunteer865
    volunteer865 New Member
    Houston, TX
    the seller on your link says its mostly made for Honda dirtbikes. it looks sick man but im concerned with the compatibility. you have a great looking bike!
  6. prometheus
    Vancouver bc
    Im stuck working on signals, cant get them to blink. When u flip the switch they turn on and stay on until u turn it off. Just constant on. Im thinking flasher relay!?!?
  7. maverickbr77
    maverickbr77 Member
    Lowville, New York
    If you are using aftermarket signals that draw less than the stock lights the stock flasher won't work. you will need either resistors to increase the load on the flasher or a different flasher that will work with the wattage of your signals.
  8. gitsum911
    gitsum911 Member
    utah
    I'm having the same poblem with my blinkers, look into a load equalizer, there a pretty cheap fix
  9. XJLee
    XJLee Member
    Vancouver
    Dude nice job!
    And I had the same issue with my lights, resistors solved that.
  10. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Only issue I have with the resistors and load equalizers is they take away the power savings I was looking for with going to led. If your not worried and only adding them for the look the resistors are fine.
  11. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    Love the bars man, bike looks great!
