82 Maxim 650 Wont Start
Discussion in 'XJ Technical Chat' started by Kevin Skorski, May 17, 2021.
  1. Kevin Skorski
    Kevin Skorski New Member
    Fenton, MI
    Hi,
    I have an 82 maxim that just recently wont start. I've been having battery problems, where I would need to get a jumper pack to start it. It eventually stopped starting, even with the jumper pack, so I decided to buy a new battery.
    I charged it, and the bike still wont turn over. I can hear the solenoid click and the oil light flashes when I hit the start button, but it doesn't even try to turn over. Its as if the bike was in gear. I've made sure its in neutral and the switch is in the on position. All main fuses seem to be fine as well.
    Was riding it last week with a week battery, and out of nowhere, it doesn't even try to start.
    Is it a starter issue? or some other kind of electrical issue? Only other thing I messed with when switching out the battery was changing the headlight bulb because that stopped working last summer
    Any insight would be greatly appreciated
  2. Dan Gardner
    Minneapolis, MN
    Kevin Skorski likes this.
  3. XJ550H
    clean the battery and starter cable connections on the solinoid
  4. Kevin Skorski
    Fenton, MI
    thanks! this helps a lot
  5. Jetfixer
    If battery is fully charged , and will not crank the solenoid is likely culprit you can try to jumper solenoid if this allows it to crank ...replace solenoid, they are cheap on eBay think i bought two for 20$ . I had a starter that was bi polar sometimes I tapped it with a mallet and it would work ..you might try that as well.
  6. Kevin Skorski
    Fenton, MI
    Hey thanks for the input. But the solenoid clicks when I hit the start button, which makes me think its not the solenoid. Battery has about 12.7 V and there is no other noise when I hit the start button besides the solenoid clicking
    Jetfixer likes this.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Don't be fooled by this. Get a rough old screwdriver and jam it across the solenoid terminals, quicker than asking on here and waiting for a response. It will tell you all you need to know.
  8. Jetfixer
    Clicking is the usual problem , I had a solenoid you could tap it and it sometimes worked . Finally replaced no more issue. Pulled original apart and it was full of corrosion.
  9. XJ550H
    clean the battery and starter cable on the solenoid that may be the issue if that doesn't solve it then you know you need a solenoid
  10. Kevin Skorski
    Fenton, MI
    You were absolutely right! I used a screwdriver and jumped the solenoid, and the starter cranked. Ordered a solenoid from the link below... it delivered next day and bike started right up. Thanks everyone!
    https://www.motorcycleid.com/ricks-motorsport-electrics/starter-solenoid-switch.html
