82 Maxim Bobber in progress
Discussion in 'XJ Modifications' started by Scizor, Nov 4, 2010.
  1. Scizor
    Scizor Member
    Prior Lake, MN
    Here are a couple pictures from the second layer
  2. padre
    padre Member
    Lawton, Oklahoma
    About the forks;
    the stock forks will occilate independently, especially at speed (over 80) without the fender in place, If you plan to ride without the front fender, take an old one and make a brace from side to side with it, in place of the stock fender> and it shouln't wobble.
  3. Scizor
    Scizor Member
    Prior Lake, MN
    Padre, I am hoping I don't need the fender mounts on the front forks with your idea... If I do, I am past that point in the build as I have removed the fender mounts and smoothed the forks to the point of no return
  4. Scizor
    Scizor Member
    Prior Lake, MN
    Piece of advice when using body filler... The warning about "use in a well ventilated area" is true! It is only about 30 degrees outside so I have my garage closed up and both the propane and kerosene heaters running to keep the garage at 65. While I had the garage opened up during the first 3 applications, I have closed the doors for the last 3. When Cheri came out to the garage she about gagged on the odors out here.
    According to her, I am in a very good mood and a little loopy... Time to open up the doors and relax inside while the garage airs out.
  5. Scizor
    Scizor Member
    Prior Lake, MN
    Here is the finished left side of the tank. Ignore the scratches in the stock paint, those are prep work. I am pretty happy with the contour of this side of the tank after a little bondo work.
  6. Scizor
    Scizor Member
    Prior Lake, MN
    There are parts that look like dents in the picture... they are perfectly smooth, once paint has been done they won't be there.
  7. vanimal
    vanimal Member
    lookin good dude! i gotta do mine somewhat soon too.
  8. Scizor
    Scizor Member
    Prior Lake, MN
    Days like today make me feel great. I watched countless videos on using body fillers and just went for it. It was a very stressful endeavor since I had never done anything like this before, but man I am impressed with what can be done with a little research and a vision.
    On a less positive note, my propane heater just took a crap on me and the hi tomorrow is only 35... I finally get a few days off in a row and something has to go wrong. I am just thankful that it isn't something with my bike, I can deal with a broken heater, I would have a stroke if it was my bike
  9. skillet
    skillet Active Member
    SW TN
    That left side looks GOOD! I've used it a lot when replacing rotted wood on homes before painting and such. This will be the first time using Bondo for what it was made :roll: , bodywork. It would be nice to have a D A sander (air driven sander used in body work), don't have one myself :( ...
    skillet
  10. Scizor
    Scizor Member
    Prior Lake, MN
    It has been WAY too long since I updated where I am on my build... I am sure my next sentence will make many of you very happy (so I am going to write it in all caps). I AM NOT GOING TO PUT THE TRACTOR SEAT ON MY BOBBER BUILD. I decided to go with a West Eagle seat which should arrive in a week or so.
    I have completed the bondo work and tonight I put on the basecoat and clear coat for the bike. There are some flaws in both, but I am not going to fix them this year (I figure no one will notice the pit on the top of my tank when I am going 70mph on the highway).
    I ordered the forward controls from West Eagle and I am looking forward to them arriving.
    As for the re-wire of my bike (moving the ignition to two ammo boxes mounted toward the back) I realized after many hours of studying my hanes manual that I can get away with only running three new wires.
    After I have rewrapped (spelling) the wiring harness, no one will be able to tell the wires were re-run.
    I am posting pictures of the front forks and tank which I finally painted and clear coated... I know there are flaws in the tank, but considering the fact I have never even tried to fix my lawnmower I am very happy with the outcome (and the flaws give me something to work on next winter when I can't ride).
    Please let me know what you think... I want honest feedback, trying to make me feel good on a first try won't help me the next time around.
    I plan on mounting the rear tire tomorrow and doing a pre-pre-electrical run... Just need to shake the foggy feeling I have from painting the bike (and yes, I wore a respirator while painting.
      File size:
      102.9 KB
      2,924
      File size:
      112.6 KB
      2,924
      File size:
      129.5 KB
      2,924
      File size:
      116.4 KB
      2,924
  11. slobzer
    slobzer New Member
    Anaheim, CA
    tank looks good man, i did the same thing, luckily one of my neighbors is really good with bondo and gave me some tips
  12. skillet
    SW TN
    (No expert here :roll: ) Kinda hard to tell about paint from pics but looks pretty good. Like you said, first time doing this, don't expect "perfect". I know, I know, I do (on something I do) and usually get my heart broke :( . GOOD LUCK on the "pre-pre-electrical run"...
    skillet
    BTW I'm one of those that is glad you went with another seat :wink:
  13. slobzer
    slobzer New Member
    Anaheim, CA
    what kind of tool did you use to grind down the front fender mounts?
  14. Scizor
    Scizor Member
    Prior Lake, MN
    After putting the tractor seat on the bike with everything mocked up, I realized how wacky it looked... Thank goodness for the comments on the forum or I may have been crazy enough to put that seat on my bike (on a side note, I bought a '49 Ford 8N tractor that didn't have a seat so everything worked out for the best with the whole seat situation).
    As for the pre-pre-electrical run, I am fairly confident that it will go well. Since I only have to reroute the ignition wires from the front there shouldn't be too much head scratching with that. Now relocating the fuse box, ignition unit, coils, etc. to the ammo boxes will be more of a challenge.
    I just ordered my pod filters (much to the dismay of a few people on the forum) and should have those installed by the end of the week. If all goes well with the first mock up, I plan on taking the bike into the local Yamaha shop (got lucky and met the owner of the shop on New Years Eve so I am confident I won't get completely screwed) to have them oil her up and get her tuned in, although I won't have a seat yet.
    I realized last week that I hadn't even thought about the rear fender. I have already removed any fender mounts for the stock, and I really thought I was SOL. I will be able to mount the brake light and turn signals into the ammo boxes, and have started to fabricate a licence plate mount to go just above the rear tire. My thought is that I will either fab a new rear fender, or find someone to fabricate it for me during the summer.
    Once I have it mocked up later this week, I will post more pictures
  15. Scizor
    Scizor Member
    Prior Lake, MN
    slobzer- I used a few tools to remove the front fender mounts. Since the medal is soft, I used a cutting wheel to remove 95% of the mount. After that I took my time grinding the remaining bulk down with a grinding wheel (to be honest, using the grinding wheel on the front forks was the most nerve racking part of this rebuild so far). I had never really used a grinding wheel before, so I was very afraid I would mess the forks up beyond repair (luckily I didn't). Tool wise, I didn't own many before starting this project. I picked up a Craftsman Evolv grinder and have used the heck out of it, and it hasn't disappointed me (hell at $35 on sale I could have used it 3 times and would have been happy).
    After the grinding wheel there were hours of filing. Finally I was able to move to sandpaper and I finished them off with steel wool.
    I found the hardest part was slowing down and taking my time, I really wanted to be done with filing/sanding but if I rushed it the forks would be irregular.
    I would say that taking the fender mounts off the front forks is a solid 6 pack project. Grind, File, Sand for a bit... then reach for the beer.
  16. soupkitchen86
    soupkitchen86 New Member
    Lets see some pictures of what the bike looks like right now. Are you going to take the rear springs out and mod the frame or leave the rear stock?
  17. Scizor
    Scizor Member
    Prior Lake, MN
    I am going to leave the frame stock. I have basic knowledge of welding, but I don't want to risk my hide with spotty work. I will get pictures up tomorrow after I get the forks and wheels on.
  18. Scizor
    Scizor Member
    Prior Lake, MN
    Here is where she is after reassembling the front and rear wheels, the tank (just for looks), the carbs, forks, pretty much everything that can be mocked up before the 2nd tear down. Let me know what you think. I get the forward controls tomorrow and will post pictures once they are installed.
    This is starting to get exciting, after many months of looking at a bunch of parts, being able to look at something that looks like a bike is a great feeling.
  19. skillet
    SW TN
    GETTING THERE! Kinda at the point you are (waiting on Spring for painting, propane for the shop is just out of the budget). Trying to figure out just what I want to do with the rear portion where you cut yours. Maybe a U shaped piece of tubing (at an angle) joining the left and right sides. Add tabs for fender mounting (???). Indecision SUCKS :lol: ...
    skillet
  20. Scizor
    Scizor Member
    Prior Lake, MN
    There has been SIGNIFICANT progress made since my last post! Here is what I have been able to get done...
    The clutch, throttle, and choke cables have all been run. Finally finished drilling out the broken off exhaust manifold post, tapped a new hole, and installed the new post. Forward controls from TCBros. Choppers have been installed (though not painted). Brackets for the ammo boxes have been fabricated, and the ammo boxes mounted (they contain the battery, and 90% of the electrical components). Handlebar grips and respective controls have been installed. New turn signals and slim line brake light purchased (only the turn signals have been mounted). Fabricated the mounts for the new seat (once again from TCBros. Choppers), welded mounts and installed new seat. and I am about 70% done with the relocation of the wiring on the bike.
    Below are the pictures I have taken so far. I still have to do some clean up of the wiring, but for the most part the bike in the picture is how it will look when finished (although the ammo boxes will be repainted).
    Please let me know what you think. I can see the finish line, and I am going balls to the wall right now to finish my baby.
    On a side note, I am moving from North Liberty, IA to Prior Lake, MN in exactly 1 week. My plan was to have my local Yamaha shop jet my carbs and do a final tune up on the bike before I moved, but that won't fit into my timeline. If anyone in Minnesota has any motorcycle shop recommendations, they are greatly appreciated... also I know 0 (ZERO) motorcycle riders in Minnesota and would like to find other people who share my passion.
    Thank you everyone for your input, I hope you enjoy my project!
    Respectfully,
    Matt S.
      File size:
      170.1 KB
      3,184
      File size:
      170.9 KB
      3,184
      File size:
      133.4 KB
      3,184
      File size:
      163.5 KB
      3,184
      File size:
      173.5 KB
      3,184
      File size:
      164.2 KB
      3,184
      File size:
      170.4 KB
      3,184
