'82 XJ650 Maxim Clutch basket help.
Discussion in 'XJ Technical Chat' started by Edward I Simmons, Jul 5, 2020.
  1. Edward I Simmons
    Edward I Simmons New Member
    Oregon
    So I grenaded my clutch yesterday and I wanted to know how deep i'm going to have to go to fix it. I bought a complete clutch assembly since both parts of the clutch basket are destroyed. Will I have to split the cases to replace the whole clutch basket or is there a way for me to do it on the bike?
    Any help is greatly appreciated.
    I'll post some pictures of the damage in a reply.
  2. Edward I Simmons
    Oregon
    IMG_20200705_073215163.jpg IMG_20200705_073203150_HDR.jpg IMG_20200705_073158736.jpg IMG_20200705_060702449.jpg IMG_20200705_060659762.jpg
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    How did that even happen??
  4. Franz
    You don't have to split the cases to replace the clutch.
  5. Edward I Simmons
    Oregon
    I'm not sure
  6. Edward I Simmons
    Oregon
    Okay but what about the part of the basket that's in the first picture? I have no idea how to get that out.
  7. Franz
    That big washer is in the wrong place. It should be behind the clutch basket. Take the washer off and there is a big nut behind it. That needs removed and you will need a tool to lock the basket while slackening the nut.
  8. Franz
    This nut.
  9. Edward I Simmons
    Oregon
    Yes I took that but off and that allowed me to remove the inner basket. (Sitting on the ground in my second picture) the other part of the basket that's attached to that large gear is what I also need to replace.
  10. Edward I Simmons
    Oregon
    Behind that large washer is a bearing.
  11. Franz
    My mistake Edward. I will try and get you instructions from the manual. Too many things going on.
  12. Edward I Simmons
    Oregon
    Update. I can't get my transmission to spin at all so I think my problems got a lot bigger.
  13. XJ550H
    could be chain guide let go jaming the trans gears.
  14. Edward I Simmons
    Oregon
    I've never split the cases before but it looks like I'm going to learn how.
