82 xj750 maxim no dash/headlights
Discussion in 'XJ Technical Chat' started by Winsleydale, May 12, 2019.
  1. Winsleydale
    Winsleydale New Member
    Metro Detroit
    Hi all,
    I've been really enjoying the bike since I got it running, but I've run into a new issue.
    The other day I took it on the freeway for the first time and after that, my speedo quit.
    I took the Atari apart to clean and lube the mechanism, and replaced the dash bulbs and warning lights with LEDs while I was in there.
    After putting everything together, making sure all wires and connectors matched, I have no headlight, no fog light, and no gauge lights. The signals and signal indicators, tail and brake light, and neutral indicator all work.
    The headlight worked prior to this, and in fact it worked while everything was apart (plugged everything in before reassembly to check proper polarity on the LEDs) as well, and I know I didn't miss any connections...
    Is there any component shared by all of these failed circuits??
    Thanks,
    Ryan
