82' xj750 maxim repairs.
Discussion in 'XJ Technical Chat' started by Bix, Jul 11, 2019.
  1. Bix
    Bix Member
    Victoria BC
    I picked up this "new to me" 1982 xj750 off marketplace the other day, no battery, no starter and 60k km, but i bump started it in the driveway and it ran fine, and idle well also. Put it in the truck and brought it home. Besides it needing a battery and a starter.. it also didn't have the gauge cluster hooked up, rpm needle was broke, turn signals were taped on the front fork, the rear turn signals were falling off.. you know all the typical things.. seat was just sitting there...
    The previous owner before me had installed the stock bars but upside down.. making the turning radius of this bike tripple id bet...
    For now ive stripped the old bars, risers, ect.. off the tripple tree and thanks to a thread on here i ordered up some 1981 virago risers and ill use those for a full bar. Tanks off to get some work done to it, had a few bad dents, also took the batt box fairings off too. Did an oil change, filter change, going to go through the wiring and fix some unnecessary crimped connections, that seem to be everywhere...
    Had some tail end turn signals dropped off so ive got those mocked for now. Thinking about how to close up these holes on the fender, if its worth tacking some steel in the holes or just getting a different rear fender. The risers are in the mail, bars are in the mail ect...
    This is my first xj750 and my first project bike. My other build (4x4) is at a halt due to not having a garage , but the bike fits fine in my basement so thats a win! Im also very happy this forum uses the same format as my other project forum, and the how to video section is an awesome addition!
    This is how i picked it up the other day, also the advertised photo.
  2. Bix
    Bix Member
    Victoria BC
    Also took some photos of the starter taken apart, ive never rebuilt one but it looks like it shouldnt be too hard. Just some brushes and o rings and a crazy good cleaning might do it... Ill do some research, i think i saw a video in the how to section if i decide to tackle it myself.
  3. XJ550H
    not much of a fender on the front of it
    and a big wtf on the handle bars
    City of Seven Hills
    It's easy to get the starter clocked wrong upon reassembly. Do that and it will turn in the wrong direction.
    Replacing your starter motor brushes w/ pics
  5. Bix
    Bix Member
    Victoria BC
    i know right. the bars are ridiculous... its definitely a few peoples aborted projects in one... bars should be here next week, along with the risers.
  6. Bix
    Bix Member
    Victoria BC
    i dropped it off at a shop for a quote, if its not too bad ill probably just have them do it and get a warranty. Id like to get out and ride for the rest of the season asap.
  7. Bix
    Bix Member
    Victoria BC
    still havent gotten the starter quote but will shortly this week, I fixed the two big dents the P.O put in the tank so those bars to fit better upside down... and some other minor stuff with the tank. Cleaned the valve body and it all seemed good. Im no body man in anyway but it came out alot better than it was so thats all that matters to me.
    IMG_20190711_091536.jpg IMG_20190711_091540.jpg IMG_20190711_110807.jpg IMG_20190711_160340.jpg IMG_20190712_121412.jpg
    All the turn signals were electrical taped on the bike and shot , replaced them with LEDs not really thinking much of it, and now im looking for a relay because my turn signals stay solid, potentially one i can ground the third prong to the bike , as ive read it keeps the auto cancelling portion alive, but ive tested mine and i dont think id trust them anyway. I read if i wanted to loose that feature i could just use a 2 prong flasher relay. The one someone suggested in that thread was a bussman 552, is that because its a good brand, or are 12v flasher relays really that different from one to the other ( serious question as i dont know much about relay specifics ).
    Ordered a tail light and im sure ill have some wiring to mess with to make it work but thats just the way she goes..
    Excited for time this winter to eliminate the cluster and all of that birds nest of plastic up front and free of some space, and get the harness all tucked into the frame more.
    Waiting on parts still, also this factory seat is all broken, loose , and held on with hopes and dreams....Probably going to order a cheaper simple seat and just make a bracket for it, tacked to the frame for now, so i can atleast get out riding before winter comes..
    how the bike sits now.
  8. k-moe
    City of Seven Hills
    The Yamha system is a bit propretary, so the type of signal relay you use is really important. Grounding the third leg of the OEM relay does nothing of value, and the only way to retain the auto-cancel with LED lights is to use two relays. A two-prong relay has to be of the correct type internally or the system won't work at all, which is why the Bussman 552 is suggested (there are other relays that work, it's jut that one happens to be commonly available).
    Link to the 2-relay solution.
    Bix likes this.
  9. k-moe
    City of Seven Hills
    I'd like to add that you could just install load resistors, but that defeats the main advantage od LED lights.
  10. Bix
    Bix Member
    Victoria BC
    Thanks for the help and link. I purchased a 2 prong LED flasher relay ( with a built in resistor ) at the local store because i couldnt find a bussman552 at the parts store, I installed it, now i get one flash and then nothing. I dont have my front signals hooked up yet so im hoping that has something to do with it but they will be delivered today. Once installed later on, if they still flash once and stop, i will order the bussman 552 relay, they are only a couple bucks on rock auto and shipping isnt bad.
    One of the next things on the list was a working horn, i tested power at the horns with a test light, good. tested the switch wire good, narrowed it down to the switch, once i took it out i figured itd be the problem. Simple cleaning the switch contacts and the ground solved the problem.
    The clutch switch was broken in the handlebar lever slot. Switch works, but tabs are broken off... so when you pull the lever it shoots out of the housing.. I will order another one of these , but for now i just cut the wires after the connector so i dont loose it, and married them for now with heat shrink, so the bike should start while im waiting on parts like that.
  11. k-moe
    City of Seven Hills
    You won't need the clutch switch unless you want to start it while in gear. It's safer to just leave it unplugged (in the headlight bucket). The new switch comes prewired, and juat plugs into the harness.
    Bix likes this.
  12. Bix
    Bix Member
    Victoria BC
    Installed front turn signals and got lucky with the relay. Works, has proper timing for the flash, and the auto cancel for turning left works but not right... thinking it a switch issue now. Either way, that gets one thing off the list for now.
  13. k-moe
    City of Seven Hills
    That shouldn't be affected by the switch position. Without the factory relay, or the 2-relay modification, the auto cancel shouldn't work at all. It can't interrupt the non-OEM relay to make it stop flashing.
    Bix likes this.
  14. Bix
    Bix Member
    Victoria BC
    I got the virago risers installed, new bar installed and all the accessories that go on. in the future i will get the brake line shortened since there is quite some slack before it gets down to the prop valve. When i go the bike, turn signals didnt work nor did brake lights or running lights for the rear brake. I got the turn signals wired, front brake lever works and signals brake light, rear brake was a mess of wires and the spring on the brake switch was gone so the pedal didnt activate anything anyway. Got all that sorted but one thing that i havent figured out yet is something is going on with the brake light. When i didnt have the front brake switch plugged in , I had a rear running light, and brake light from the pedal, seemed great. Now that the front is hooked up i have no running light but front brake lever switch works and rear lever switch works but no running light.. Im gonna dive into the wiring diagram and some threads and hopefully find an answer.
    I did throw some fresh fuel in the tank after the reinstall and ripped it around the block, Clutch seems good, and it runs pretty good aswell. Good enough that itll definitely get through the last couple months of riding season.
    I ordered some bar end mirrors, and a brown simple seat since the stock one has all the mounts broken off of it and the frame has been no more mounting points either...
    New air filter on the way to the store.
    Going to order a rear brake shoe kit and replace those. Doesnt look like anyones opened it up recently...
    also id like to locate a proper rear fender, this one is just bubblegum welded in there...
    The bike as it sits now.
    biggs500 likes this.
  15. Timbox
    Timbox Well-Known Member
    Looking good!
    Bix likes this.
  16. Bix
    Bix Member
    Victoria BC
    Took the bike on its first real voyage the other day, put about 250 miles on in a day of riding our coastal highway. Didnt notice any major issues except the noise of the " cam chain " or whatever it may be. Ive tried to read all the forums on here about " noises " and until i open some things up, and inspect, i know i wont really know for sure what the noise is.
    It started everytime and seemed to run good, didnt really push it above 7-8K rpm as im still a bit weary of the workmanship that was done before me, because i dont know much history, and it seems safer to assume towards the worst of it than the best of it.
    I did loose my keys on the highway once... I found them when i went back but obviously the tumbler or something in the lock cylinder is gone because the key just comes right out as its running. I have seen some new lock cylinders online and i was wondering if anyone has relocated it. Seems like itd be easy enough? I ask because i want to eliminate the atari system hanging off my bars , and then the lock really stands out. Im not sure where the starter relay is but i imagine id possibly have to move that as well depending on location.
    Its not leaking any fluids, clutch seems okay.. Im still going to take a peak inside and see if it could use some new friction plates and compression springs. Its got 60k km on it and without much history im going to assume the worst even though it does seem to have been worked on by someone quite a bit at somepoint.
    The starter did click a second or two a couple times once or twice, It was just rebuilt but that doesnt mean they didnt make a mistake. Also could be electrical in terms of the solenoid and ground wire connection possibly?
    One thing i was wondering is how stiff should the front brake lever be? it stops really well but its quite a bit stiffer than my other yz450f's.
    rear brake pad was in good shape but i ordered a new one anyway because i dont know how old it could be..
    I read somewhere about the final drive fluid being 80-90w gear oil? is that what is still best for it?
    also put some exhaust wrap on it as i had a couple rolls gifted to me.. not sure if i like it or not though.
    Some pictures of it now and on the trip
  17. Bix
    Bix Member
    Victoria BC
    It also has a small lag in first gear when the throttle is applied, sometimes.. Im assuming its going to be something carb related so a rebuild kit and new air box boots/clamps from xj4ever will be added to the list of things to order.
    Timbox likes this.
  18. Bix
    Bix Member
    Victoria BC
    made some progress this weekend between adulting and also putting some hours into the new E150 campervan. Got the carbs off the bike, once i started looking at them closely i couldnt stand it anymore, plus i had the tank off because my petcock was leaking anyway.. so the MAW ( might-as-well ) set in and off they came. Rebuild kit should be here this week sometime, so i figured id get some prep work done. Got the " freshly cleaned, haha " carbs off the bike.
    IMG_20190811_105423.jpg IMG_20190811_111723.jpg IMG_20190811_112544.jpg IMG_20190811_112548.jpg IMG_20190811_113036.jpg IMG_20190811_114931.jpg IMG_20190811_115300.jpg IMG_20190811_122314.jpg IMG_20190811_122323.jpg IMG_20190811_123344.jpg IMG_20190811_123443.jpg IMG_20190811_134618.jpg MVIMG_20190811_134622.jpg
    They were clearly very gunked up. Not done cleaning by all means but threw in the towel for today. I have all the jets soaking in carb cleaner in the float bowls. Nothing seems scored or junked but the gaskets, someone also threw in an oddball needle valve. I will be replacing them all with the rebuild kit i purchased anyway, as well as the main jets but ill clean and save the old ones.
  19. Timbox
    Those are not too bad at all, but don't let that fool ya, those emulation tubes could be nasty. Make sure you get that little jet in the bowl all cleaned out. Bred tie works well with compressed air. Great pics keep it up!
    Bix likes this.
  20. Bix
    Bix Member
    Victoria BC
    Yea they aren't as bad as some of the videos I've watched that's for sure, so that's a good thing. I did blow air through them and carb cleaner so far. Also wondering what kinda material I can use to get the discoloration off the diaphragm bodies or if it's fine to have that color on them?
    As for the emulation tubes. Im going to take some wire off my wire brush, and go through every hole before assembling again.
