82 Xj750 Spark Plug hole N.1 stripped
Discussion in 'XJ Technical Chat' started by Tafshaft, May 9, 2023.
  1. Tafshaft
    Tafshaft Member
    Canada
    Was taking out my spark plugs to check if they were lean or rich and in the process of putting it back I check to see that half the threads are stripped / cross threaded.
    I bought a thread repair kit M10 x 1.25mm to repair it, not sure if this is the proper kit as I've never repaired a stripped hole before.
  2. Tafshaft
    Tafshaft Member
    Canada
    Also bought a 14mm spark plug repair tool with a rethread tap.
  3. Dan Gardner
    Minneapolis, MN
    Do you have to worry about getting debris in the cylinder when you cut new threads?
    I suppose a replacement head is the worst case scenario. But that's definitely more time and money than a repair kit!
  4. Fuller56
    Fuller56 Well-Known Member
    When you cut the new threads be sure to load the tap with thick, sticky axle grease. That will hold most of the swarf. Most, not all. What you lose won't hurt anything.
    Tafshaft and Franz like this.
  5. Tafshaft
    Tafshaft Member
    Canada
    Debris should flow out of the cylinder if I crank it without spark plug right?
    Cylinder head is costing around $200, ouch!
  6. Fuller56
    Yes, it should. The swarf that does not is soft aluminum, one of the reasons it stripped, and what does not come out on the tap or blown out is not hard enough to damage anything. Not the best to have it in there and not "harmless" but not earth shattering either. You can also blow out debris with compressed air before cranking the engine.
  7. Dan Gardner
    Minneapolis, MN
    Yes, the eBay retail price is a little steep. There are other creative options you could consider if it came down to needing a head.
