82 XJ750J motor mount alignment
Discussion in 'XJ Technical Chat' started by LeClairerog, Jun 14, 2017.
  1. LeClairerog
    LeClairerog 1982 XJ 750 Maxim
    LeClaire, IA
    Here's my $10.00 question.
    The pictures attached are my front, lower, motor mounts. The left mount doesn't line up. The bolt in the right side is bent. Since the right engine guard and tailpipe are flat in spots I have a pretty good idea why they are a bit out of whack.
    My gut tells me to be careful when lifting the engine to line the mount back up with the frame. Where is the best contact point to make this happen without creating more of an issue?
    Use a bit of wood to spread the load, and jack her up anywhere on the oil pan. The jack won't be carrying the whole weight of the engine since it's in the frame. You could also use the case guard as a jacking point if you have the right saddle on your jack.
    LeClairerog likes this.
  3. LeClairerog
    LeClaire, IA
    Great! Thanks k-moe.
