'82 XJ750J Possible Cam Chain (and Owner) Issues
Discussion in 'XJ Technical Chat' started by markd15, Feb 16, 2017.
  1. markd15
    markd15 Member
    Illinois, United States
    Would the starter motor from an 83 XJ900 Seca or an 82 XJ650 Turbo work in an 82 XJ750J?
    Scratch that. http://xjbikes.com/forums/threads/xj750-starter-motor.43727/ This thread says the 900 will work.
    Just ordered a starter for $26 shipped. Hopefully it works out as that price is perfect. I'm assuming it would be a good idea to order a starter rebuild kit and just rebuild this unit straight away.
    If the windings are good you can jut throw a rebuild kit into it. Less than $30. Any used starter will need a eebuild kit anyway, so if that dosen't work you won't be out any money. Just swap the kit over to the replaement starter (if you end up needing one).
  3. markd15
    markd15 Member
    What I meant is every bar on the commutator is shorted to every other bar. I checked this with the rotor outside of the motor using a continuity tester. With the motor assembled, checking from the positive post to the casing shows 0ohms. I don't think a rebuilt kit is going to fix a fused rotor, but I'll order one for the new starter.
    OK, that'll kill the starter. It can be repaired, but not worth it since you found another already. It is worth keeping around in case you need it though. re-cutting a commutator is fiddly, but not difficult.
  5. markd15
    markd15 Member
    I may try to do that some time. It would be nice to have some spare parts lying around.
    Do you have any good sources for the process of fixing a commutator?
  6. Polock
  7. markd15
    markd15 Member
    That's basically what I've already done but with 500 grit. I was going to move to a higher grit after fixing the short. The only difference is I also scraped a bunch of graphite gunk out from between the bars. Even then the commutator is still completely shorted out.
    Beyond resurfacing the copper, is there anything I can do to possibly isolate the windings again?
  8. Polock
    don't you find it odd that all the coils got shorted all at the same time? i think when you're measuring them, maybe you see .01 ohms and call it 0. not all meters can even measure .01 ohms.
    scrape the carbon from between the copper pads a bit and try it
  9. markd15
    markd15 Member
    As far as I know, the individual bars of a commutator should only be connected to certain other bars on the same commutator. What I know from tests is that I have 0 ohms (or rather 0.3 ohms: the resistance produced by touching my meter's leads together) between any given bar and every other bar. I also know that the motor has failed to perform its standard function and will not turn over whether powered by the motorcycle's battery or a battery charger outputting ~6 amps max at 12 volts, plenty to spin the motor outside of the engine.
    However, I do find it very strange that the entire commutator would short out all at once, but I have scraped the material out from between the bars and sanded the commutator. The motor still does not turn, even if rotated to different positions.
    I don't want to give up on this motor, but I think it's reasonable to say that something dramatic happened which damaged at least the commutator.
    If you have any specific testing procedures I would be more than happy to try them. Saving the motor would be a great help to this project. I'm going to try cleaning the commutator again, being as thorough as I can, just to rule that out.
  10. markd15
    markd15 Member
    I'd like to apologise for being presumptuous in my last post. I took the motor apart again and thoroughly sanded the commutator down to perfect copper. This time however, I also sanded off the faces of the brushes.
    After reassembling I jammed the entire motor against the terminals of my old battery and, after throwing some nice sparks, the motor jumped! I held it more firmly against the battery and I got it to spin continuously! Clearly it needs a rebuild and I'm not going to cancel that new motor order, instead I'll likely rebuild the new motor and use it and keep the old one for parts.
    For anyone who sees this in the future, large starter motors have essentially zero resistance on their windings and every commutator bar is actually connected. Only on small DC motors will there be a noticable increase in resistance across the different bars of the commutator.
    Although I will be replacing this motor, at least now I can continue diagnosing the engine until next weekend when the motor should arrive. I'm pretty busy during the week, so expect my next update on Tuesday.
  11. markd15
    markd15 Member
    Surprise update!
    So I stuck the starter motor back on the bike and I just couldn't resist trying it out.
    Unfortunately my nephew was asleep on the other side of the garage wall so I couldn't actually let the engine run. The sound of it would wake him up and I would never hear the end of it from my sister.
    Anyway, I decided to just turn the engine over a couple times, just a quick push of the starter and no more. I hit the button, the motor went over one turn and instantly fired up! Good thing I had my hand on the key so I could turn it off right away, but for those few revolutions it sounded like it was firing pretty consistently.
    Obviously I need to actually let it run in order to tell if it sounds OK, but it was the easiest startup all week. To anyone else reading this thread who hasn't already, rebuild your starter motor! It made that engine fly over more easily than I think I've ever heard it go after just cleaning up the commutator and brushes. Obviously you should replace the brushes entirely, but you get the point. A clean rebuilt starter is a happy starter.
    I did find that one of the spark plug connectors (a peculiarly aftermarket looking one) had double the resistance of all the others. You'll never guess which cylinder it was on (hint: it was the dead one). I ordered a replacement for that one.
  12. markd15
    markd15 Member
    Super surprise update!
    I fixed the running problems!
    After cleaning the starter I was able to get it running today, but only barely. It still sounded like crap, but I noticed something. It would run poorly, but if I revved it just a bit it would suddenly run really nicely for a few seconds then drop back to running poorly. I don't mean it would slowly shift from running poorly to well and back again, like would happen with a fuel/air issue. It was more like a light-switch going on and off: suddenly running well, suddenly running like crap.
    I killed the engine and felt the headers. Its important to remember that cylinder 4 was dead, but I had swapped the 1 and 4 plugs before this test. Now I found that cylinder 1 was cold!
    I yanked the bad plug out and measured it with a meter and I got a resistance reading from the stud to the threads in the megohm range. Of course any reading at all here is a sure sign of a failed (or extremely dirty) plug. I also checked number 4 but it was fine.
    Fortunately I don't throw things away. I went and got one of the original spark-plugs from before I replaced them which still tested as an open circuit and installed it in the number 1 spot, started the engine, and...
    It ran like crap.
    Feeling dejected I started putting my tools away, when I glanced at the engine and noticed something. Remember when I tested the number 4 spark-plug? Yeah, I never plugged the cable back in.
    When I started the bike this time it ran perfectly. Just as I remembered it running. No obvious tractor or knocking sounds, no hissing or popping, just the smooth sound of an XJ750 engine.
    Once I receive my parts I'll be replacing the starter motor with a rebuilt one and replacing the high resistance plug cap with a new NGK one. After all that, I think I'll go on a nice long ride and try to forget about this week.
    Thanks for everyone's help. I hope this will be my last major update.
  13. markd15
    markd15 Member
    So I got to put some miles on the bike today riding to class. I actually made two trips (I really need to get into the habit of checking if my classes are canceled before driving all the way to campus).
    My first trip (both were 42 miles over two rides each) went just fine. Everything worked well and I had no issues worth mentioning.
    After I got home I received my new spark plug cap and installed it on cylinder 4. Before, the cap resistances were 4.8k, 4.6k, 4.6k 9.8k for cylinders 1 through 4 respectively. Now cylinder 4 is 5.1k with the brand new NGK cap.
    My second trip went nearly as well as the first with two notable differences: first, the bike feels a little snappier. It's especially noticeable under heavy acceleration and heavy throttle use at high speeds. It's just a small improvement though, possibly imagined
    The second difference, and one that I find mildly concerning, is that there is a strong buzz or vibration in the engine now. While it's pretty unnoticeable at most running/cruising rpms, it becomes painfully apparent above 6k rpm. The bike has always buzzed a little bit here and I believe that's normal, but after installing the new cap it's much worse. It feels like holding a poorly balanced high speed power tool and It just about shakes my feet off the pegs (ok that might be an exaggeration, but it's bad, trust me).
    Is this buzz concerning or just a nuisance? Should I bite the bullet and just replace the other 3 caps? Would that fix the vibration?
  14. k-moe
    The vibration is probably related to the new plug cap, but not in the way that you are thinking. Now you have all four cylinders firing as intended, so now what was a fairly smooth engine, is buzzy. Why? The carbs need to be synchronized to take into account that cylinder #4 is working properly again.
    Stumplifter likes this.
  15. markd15
    markd15 Member
    You're probably right.
    I'll try to get to work on that as soon as I have the right tools for it. In the mean time, would it hurt the engine to continue running it in this condition? Or would it just hurt my fuel economy?
  16. k-moe
    The extra bit of vibration won't hurt a thing, not even your fuel economy (not by much anyway).
  17. markd15
    markd15 Member
    Good to know.
