83 Maxim
Discussion in 'XJ Technical Chat' started by Tyson M., Dec 31, 2019.
  1. Tyson M.
    Tyson M. New Member
    Wisconsin
    Saw this relatively close, thinking I could snag it for $200 or less. What do you guys think? I have two 1984 magna 700s and I'm currently restoring one. I dont think I'll have a problem with getting this maxim to run.
    Franz likes this.
  2. Franz
    Nice bike
  3. Jetfixer
    Looks like a good project. Carbs probably will require a rebuild ( only way to properly clean carbs is a full teardown and soak in carb cleaner...spray carb cleaner will not get into small passages of the carb. See church of clean) expect to spend 2 to 4 hundred to get going( battery, carb kits, tires etc) , if your new to this site ...Welcome ..on the top right of the page click on xj4ever....chacal has most parts either factory or pattern parts his service is great....keep us informed if you purchase bike. Cheers
  4. Tyson M.
    Tyson M. New Member
    Wisconsin
    I will offer him $100 to come pick it up,
    the highest I will go is $200. He said he will send me more pictures today. I'll let you guys know what happens.
  5. Timbox
    You better get that, I am close to you and have not seen that bike. As long as there is a title with the bike you will be getting a heck of a deal. I like the Seca (more upright riding) but that is a good looking bike. IMHO
  6. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Automatic transmission? BTW, I use an ultrasonic machine to clean not only carburetors but many other detail items. Works well.
    Cheers, 50gary
  7. Tyson M.
    Tyson M. New Member
    Wisconsin
    No, Facebook market place does that a lot. It wont let you change that option sometimes
  8. Tyson M.
    Tyson M. New Member
    Wisconsin
    Lol, I'm not getting it for me. Getting it for the GF and if she doesn't like it then my father will get it
  9. Timbox
    Hope that you got it and that she likes the bike.
  10. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Good deal, get it.
  11. Tyson M.
    Tyson M. New Member
    Wisconsin
    The other guy didnt answer but I found another one. Same deal, not running but has title. Last ran a year ago. He said the lowest he would do is 300, that good? I want to try and get it for 250
  12. Jetfixer
    Okay that is an XV Virago. I had an 82 ,here are a few items , make sure you have a fully charged battery, the starters are big problem with these bikes. Be aware the carb overhaul kits usually come with 122 jets...these are are wrong for 82 to 84 front cylinder if I recall was 124 and rear 134 . Do not remove or modify the intake airbox....this will make starting harder...hence starter problem. Look up Dr Virago he sells a kit that has stiffer spring and shim kit. I used to be on the Virago site not sure if it is still active. Looks like you have a good bike , these are great bikes I bought mine for 400$ and flipped it for 1500$ ...you can move to "Other bikes" on this site. Good luck.
  13. Tyson M.
    Tyson M. New Member
    Wisconsin
    I'm going to go try and see it today. Owner gave me permission to try and start it. Going to check for spark first, if it has spark I'll empty out any fuel in it and put a little bit of fresh gas in it. If that doesn't work I'll switch to starter fluid to see if I can get it to fire up. If it fires up I'm definitely taking it home. If it doesn't I still probably will lol
  14. Tyson M.
    Tyson M. New Member
    Wisconsin
    I got the bike, it seems to be having that common starter issue. Brand new starter on it and it almost wanted to turn over right away and then it started grinding. Any links to a fix?
  15. Timbox
  16. Tyson M.
    Tyson M. New Member
    Wisconsin
    Yeah just finished watching a couple of videos, taking off the crank case tomorrow and removing that spring. If the starter gear looks bad then I'm ordering a replacement for it. Gonna hope the gasket around the cover stays intact or is good enough to run for a little bit. Also noticed fuel leaking from the carbs on the left side. I believe it to be from the float bowl gasket
  17. Tyson M.
    Tyson M. New Member
    Wisconsin
    In the process of removing the left side engine cover and the damn thing just wont come off
  18. Timbox
    Get a soft mallet and start to tap on it around the cover. Making sure you have all the bolts out, look under the cover really well some of us older folks that don't have a lift might miss one of them bolts now and then. You should be able to tap it off with a soft mallet or brass hammer. Remember it is cast aluminum (I think) and it could break with too much force.
    Jetfixer likes this.
  19. Tyson M.
    Tyson M. New Member
    Wisconsin
  20. Tyson M.
    Tyson M. New Member
    Wisconsin
    Where do those washers go? I dont think they are supposed to be in there
  21. Tyson M.
    Tyson M. New Member
    Wisconsin
    Got it all put back together. Got it to run :) $300 got it to run in 3 hours
    jayrodoh and Timbox like this.
  22. Timbox
    Nice, enjoy that bike.
  23. Jetfixer
    Dr Virago sells a kit with a stiffer fork type spring, and shim for the starter , keep a fully charged battery . I. Went through 3 starters until I got this kit...the original starter burnt up , the second the post burnt off never sure why all was tight , place I bought it from sent me a third no charge, got carbs straightened out and good starter ...success.
  24. Tyson M.
    Tyson M. New Member
    Wisconsin
    Yeah that starter grind is both annoying and unsettling.
