83 Seca 900 bogs down.
Discussion in 'XJ Technical Chat' started by MrSeca, May 17, 2020.
  1. MrSeca
    MrSeca Active Member
    Oakland, CA
    Already tried everything you said. And I live in a flat neighborhood.
  2. MrSeca
    Oakland, CA
    On a different note the float height on carbs 2,3, 4 are like the 1st pic. The float height on the 1 carb is like the second pic. Is this an issue?
  3. k-moe
    Yes. Assuming that you set the bike so the carbs are level 2, 3, and 4 are low. Out of spec low.
    Setting the fuel levels
  4. bigfitz52
    I just took the time to read this whole thread. Starting with "he (PO) barely rode the bike for the last 15 years" and amongst all of the discussions of various dragons being conquered and new ones popping up, a lot of riding, etc., nowhere do I see any mention of rebuilding the brakes. Most importantly, brake LINES since they are all hydraulic, but calipers and master cylinders as well. The rear M/C has a remote reservoir, be sure to inspect that small hose as well. Hopefully you have already replaced the 37 year old brake fluid at both ends and bled everything.
    Rooster53 and MrSeca like this.
  5. MrSeca
    Oakland, CA
    Thank you Bigfitz for reviewing this post. You are correct, I have yet to change out the brake lines and it is on my list of things to do with this bike. I did, however, refurbish the calipers and they are working brilliantly.
  6. MrSeca
    Oakland, CA
    I did not set the bike which is, I assume, raising the front tire just enough so that the carbs are level? I was under the idea that if the tube is positioned at the middle of the carb body the fuel level reading in the tube will be more or less correct.
  7. k-moe
    Yes, it should be close enough to get a good idea about the float levels. If you were reading in the middle of the bowls my assessment is still correct.
    MrSeca likes this.
  8. bigfitz52
    eehhhh... the FSM's suggestion about checking float levels ON the bike depends on the bike being level side to side, and reasonably so fore and aft. And is hard to get accurate readings with.
    The only way you're gonna get accurate "wet" readings on all 4 carbs is with the rack off the bike. And if the goal is perfection, no "+/-" anything, spot on, all exactly the same; the only way to achieve it is with the rack off the bike so fine adjustments can be made.
  9. MrSeca
    Oakland, CA
    Why are one of my carburetors leaking out of the overflow tube only when the bike is in operation and the petcock is set in the ON position but doesn't leak when parked and the petcock is set to PRI?
  10. hogfiddles
    Things to check-could be:
    Too much fuel in the carb.... float level too low, or float could be stuck down
    valve out of spec causing blowback
    at least you know the petcock is working correctly!!!
  11. bigfitz52
    Sure sounds like a wonky float level to me...
  12. MrSeca
    Oakland, CA
    Float level looks good. If a possible problem could be the float level is too low how could it be coming out of the overflow tube? In any case, I'm taking apart the engine to fix a faulty starter clutch and I'll be able to check the valves and everything else for that matter.
  13. hogfiddles
    If the FLOAT is too LOW or stuck down, then valve doesn’t seal and EXCESSIVE FUEL flows into the bowl, creating a possible/likely overflow and a HIGH FUEL LEVEL. If the FLOAT is too HIGH, the valve seals too soon, causing a LOW FUEL level.
    float low = fuel high
    Float high = fuel low
    Having valves out of spec can create back/excessive pressure which can cause fuel to blow various incorrect ways.
    dfox
    MrSeca and k-moe like this.
  14. bigfitz52
    You don't have to disassemble the top end of the motor to fix the starter clutch. You do need a factory service manual, splitting the cases is not a minor task. There are a number of critical details that must be adhered to or you can wreck the motor.
    Valve clearances are a maintenance item requiring removal of only the valve cover.
    hogfiddles likes this.
  15. MrSeca
    Oakland, CA
    Would this be the correct manual?: https://www.xjcd.org/node/1301
    I also have the Haynes for the XJ900 '83-'94
  16. MrSeca
    Oakland, CA
    Hi guys. I'm working on my carburetors and I changed the slide needle on one of the slides and compared to the old slide needle it is just a slight bit longer. Is this a problem? Should I just stick with the old slide needle? Does the older slide needle look worn out to you?
  17. hogfiddles
    First time I’ve seen a brass needle. Usually they’re aluminum, as far as I recall. You’d have to measure to see if they’ve worn. Also, check the holes in the tops of the emulsion tubes, too. If they have worn to egg shapes or ovals, then you’ll consume extra fuel too
  18. chacal
    Aftermarket, possibly Dynojet. Is the shaft inscribed with a series of letters/numbers?
  19. MrSeca
    Oakland, CA
    I replied to our conversation but just to let you know here, the number stamped on the needle that came with the bike is 4HZ22. However, according to the Haynes manual it should read 4Hz26-3. The one that came with the kit says Y278
  20. MrSeca
    Oakland, CA
    Question: When I'm on the freeway and I quickly crack open the throttle, the bike bogs for a second before taking off. Am I running too rich or is this typical of liter bikes at higher speeds?
  21. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Weak.
    Someone has been at your carbs. Have a good look inside them again - post a pic of the bottoms of the slides. What about your needles - did you sort this, or are we to guess?
  22. MrSeca
    Oakland, CA
    I've been at my carbs!! LOL. I did a carb rebuild. Broke the rack and everything. Kept the original needles but changed the emulsion tubes. I ultrasonic cleaned AND chemical dipped the carbs. Replaced jets. Everything is stock. Balanced the carbs and kept the original mixture screw settings from the PO. I'm not good at tuning the mixture screws and a Colortune did not really help me.
  23. chacal
    Can you explain this in a bit more detail?
  24. MrSeca
    Oakland, CA
    When I would try the Colortune it would stay blue the entire time I would turn out the mixture screws until I was 5+ turns out and then it started turning orange. I've tried many times and I could never figure it out.
  25. Minimutly
    West Wales, uk
    I'm with you - never had success with a colortune.
    Adjust the mixture screws in to soft seat and log where they were, then one at a time adjust for fastest idle, listening fot a rhythmic or uneven misfire - rhythmic is rich, uneven is weak, then adjust to between the two. Then it's down to starting performance, listening for pops back when cold, and plug cuts.
    I'm guessing they've been out, since youve cleaned these carbs? If so you should have logged the settings? I'm sure someone will know where they need to be for an all standard setup on a 900, will get you close, or tell you if you have another issue if you're a long way away from there?
  26. MrSeca
    Oakland, CA
    I have the mixture screw settings at where the PO had them. They are currently at 1) 2 1/8 (turns out), 2) 2 1/8, 3) 2 1/4, 4) 1 3/4 Can this issue be solved simply by turning the mixture screws? Would it be worth a try to turn them all in a quarter or half a turn? I also have the original jets. I've heard that some companies get the jets wrong on the sizes even though they are labled correctly but I had this issue originally on the bike before the carb rebuild.
  27. chacal
    This situation almost 100% of the time is due to the pilot jet fuel passage (within the carb body) being partially or completely clogged......the lack of fuel flow thru the clogged passage means that adjusting the mixture screw results in no additional fuel coming thru the mixture screw, since the flow is being restricted way before the mixture screw (with a clear internal passage and clear jet, then the adjustment occurs at the mixture screw).
    This could explain the hesitation you are experiencing; you are running a bit lean (but still within the "blue" range), and quickly cracking the throttle results in no extra fuel flow thru the pilot circuit (which should occur immediately), and it takes a few moments for the vac piston to respond (and raise the main jet needle) bringing the fuel mixture back to what's needed.
    A test you could try to confirm this is to take the bike back out again, and crack the CHOKE open just a little bit.......the choke supplies fuel to the carbs thru a completely separate passage within the carbs......and the extra fuel coming in thru that circuit (which is also instantaneous in response to throttle position) will richen up the mixture sufficiently to avoid the lag in response (due to insufficient fuel flow thru the pilot fuel system, due to passage clogging) until the main fuel circuit takes over.
    Franz and k-moe like this.
  28. MrSeca
    Oakland, CA
    Chacal, I understand what you're saying but if it was the pilot jet passage being partially blocked wouldn't the bog down occur whenever I opened the throttle at any speed? It seems to only really happen at the higher speeds. If it's any indication, I also get poor gas mileage on my xj900. 35-38mpg. 40 on a good day and I'm hearing people get 45+ on these bikes.
  29. k-moe
    Chacal is correct.
    The difference in fuel flow will not always be notacable at lower speeds, especially if you're in a lower gear than the speed requires.
    Your additional fuel useage could be due to a number of factors not related to the carbs, but if the carbs aren't 100% (and your's clearly aren't) then you'll never see better fuel mieage than you are getting now.
    As for the idle mixture screws: none of them are set to the factory baseline. They are easy to change, so start there and see if you get better results.
    Baseline is 2 1/2 turns out, then slowly add 2 degrees of turn until you it the sweet spot. Most of us end up at 2 3/4 turns out, with some going to 3 turns out.
  30. chacal
    What k-moe says is absolutely correct, but again with the reminder that if screwing the mixture screws in-or-out results in no changes to the mixture "color" as seen thru a Colortune, that points to a deeper issue that must be resolved.....with your mixture screws being at 5 turns out (!) there is definitely some type of major issue in play: you simply are not getting enough fuel thru the pilot fuel circuit (for whatever reason(s); typically, it is due to plugged internal passages, but it could be any number of other issues that would restrict fuel flow thru that circuit: incorrectly size jets, plugged fuel jet, incorrectly sized AIR jet, incorrect mixture screws, etc.
    But.......the most common issue (by far) is internal clogging, those passages are tiny and any fuel residue that has set in the carbs for a period of time will gum-up (if you're lucky) or crystalize into a rock hard substance (if unlucky).
    http://www.xj4ever.com/inside your carbs.pdf
  31. Minimutly
    West Wales, uk
    I don't know where you get the 5 turns out @chacal ? Did I miss something?
    Also, please forgive me, you have your cv carb theory wrong. Slow lifting of the slide results in rich mixture, not weak. Hence my question about showing us the bottoms of the slides in case someone has enlarged the air passage.
    @MrSeca , are you certain you checked the progression holes and passages @chacal mentions? I don't see how you can perform a service on these without? And also - you didn't respond to the question I posed - you did remove the mix screws didn't you?
    Lastly, well nearly, @k-moe suggested starting with 2.5 turns out for these screws, I would agree with this, maybe even 2.75 turns.
    And, actually lastly, recheck your float levels again, if non of the above works.
  32. Minimutly
    West Wales, uk
    You see this comment "only really happen at the higher speeds." Well, if all your screws are reset, you did clean them and check fuel flow through the passages, and no- one has doctored your slides, I would get a set of standard needles, used ones if you can, provided they're good.
    Essentially, at higher speeds and loads the progression circuit does less, and the needles do more. Also, a low fuel level in the float chamber translates to more air mixing in the emulsion tube - hence a weaker mixture.
  33. k-moe
    Yes; if the idle circuit passages are entirely clean. If they are not, then they will not be able to deliver the additional fuel needed during transition as the slides lift, resulting in a weak mixture. Remember that the idle circuits provide the same function as an accelerator pump does in addition to maintaining fuel flow at idle.
  34. chacal
    Yes, MrSeca responded to my question of why his Colortune attempts weren't working:
    Well, what I was referring to is what k-moe stated:
    Pilot circuit that doesn't / isn't able to "deliver the goods" during this transition will cause a lean mixture until the slides / main fuel circuit "catches up".....which is the issue that MrSeca said he was experiencing:
    It is the "quick cracking" of the throttle where one might expect to experience issues related to a deficient pilot fuel circuit, although as many have pointed out (correctly), other factors could also cause the same problem (modified slides, incorrect needles, etc.). My recommendations were due to the fact that his pilot fuel circuit seems to have some issues, and those issues could also be the cause of the "bog" when snapping the throttle open. "Pilot" or "idle" fuel circuit is a little bit of a misnomer; it is active throughout the rpm range, although it predominates during low, slow, or steady engine speeds/loads, especially up to around 4000 rpms.
  35. Minimutly
    West Wales, uk
    Hmm, well they indeed do work during transition (hence I call them progression holes and passages), but the OP states that while at speed he has the stumble when opening the throttle - now "at speed" could mean they are still working, or, at higher speeds, doing nothing or very little. Damnit - just realised, they will allways be working to some degree, since there will allways be a vacuum, even at wot. However, it will be small amounts due to the size of the orifices.
    Anyway, I digress. The accel pump feature once off progression (and during to a degree) is taken care of by the hole in the bottom of the slides. It is callibrated to limit the speed of rise of the piston/slide. If it goes up fast you get a weak mixture.
  36. Minimutly
    West Wales, uk
    Missed your reply @chacal ...
    Re the 5 turns out, @MrSeca wasn't riding the bike with the screw 5 turns out, but yes agree there must be something wrong tomget this far out on the colortune. (And yes I had missed that...)
    Edit to question your reply, but I don't want to make an issue of it:
    This was after your post....^
  37. chacal
    Yes, he didn't indicate that he was, but.....the same thought applies. Which is why I recommend (to him anf others) when you suspect an idle circuit "clogging" issue, then one way to verify is by using the choke a little bit, since it provides an extra dose of fuel which can mask the lack of fuel thru a clogged idle circuit. Not a sure-fire diagnosis, but sometimes it's a helpful "clue", which is important when there could be multiple causes for the same observed problem........of course, this assumes that the enricher (choke) circuit is also not clogged, which can also happen, especially if the idle circuits are clogged. So really the first step is to verify that the choke circuit is operating okay, and then, use a bit of choke on the freeway cruise and see if it eliminates the crack-the-throttle / bogging issue.
  38. MrSeca
    Oakland, CA
    Thank you everybody for giving feedback. I did try Chacal's suggestion and turned on the choke/enricher while on the freeway. I still had the issue. Keep in mind, it's not a HUGE issue it just has the subtle hesitation after I crack the throttle and THEN it accelerates.
    Also keep in mind that I broke the rack and ultrasonic cleaned, chem dipped for 24 hours, and then ultrasonic cleaned again all 4 carb bodies. I'd be very surprised if pilot circuit is clogged but I could definitely be wrong.
    A couple other things: since I did the carb rebuild the bike has been harder to start and a couple of times it would just die when I pulled up to a stoplight. Wasn't doing this before. Also, when I initially start the bike to warm it up only full choke works where as before I was able to keep it idling at half choke and when I rev it a little bit it has a similar stuttery type of reaction when you start to lose fuel and have to change to reserve, however, once it warms up, the stutteriness (is that a word?) goes away. Just to check, I sprayed starter fluid around the carbs and intake boots to see if there were any leaks and none were detected.
  39. k-moe
    I hate to be brutally honest, but the first step is to strip the carb bodies and soak them in a good carb dip, then verify that the passages are clean with a cheap can of carb cleaner.
    After that the rest is gravy.
    When in doubt go back to the beginning.
    MrSeca likes this.
  40. MrSeca
    Oakland, CA
    I will adjust the air screw mixture and try that first. Thanks
  41. k-moe
    Just for confirmation, are the valve clearances in spec, and were they rechecked after changing shims?
  42. MrSeca
    Oakland, CA
    Last time I checked AND rechecked was last May.
  43. Minimutly
    West Wales, uk
    Chemically cleaning and ultrasonically cleaning doesn't guarantee the progression circuit is not blocked - you have to squirt carb cleaner down there (with eye protection - ask anyone who's done this, almost guaranteed to get you in the eye). The beauty of it is, you have 4 carbs to do it to, so you get a good comparison on flow rates.
    But anyway, I would set all screws 2.75 turns out to see, this is easy. Then recheck float levels. See if you can get some used needles? After that I'm afraid its strip rack time...
    k-moe and MrSeca like this.
  44. MrSeca
    Oakland, CA
    Well guys, I'm at the point where I'm just throwing my hands up in the air and saying WTF!!!!!. The bike has become increasingly hard to start, the plugs are all super sooty black, the 4th cylinder isn't even firing anymore even though it's getting spark and gas. I had none of these problems before the rebuild. I have no clue what I could've possibly done wrong. I had no problems putting everything back together. This is totally beyond me. Someone please help me.
  45. k-moe
    Take a break. Do other things for a few days or even weeks. Your brain is stuck in panic-mode. It happens to all of us.
    Look at her with fresh eyes and it'll all fall into place.
    MrSeca likes this.
  46. chacal
    Super-sooty plugs are an indication of either a very rich or a very lean condition:
    Why are my plugs carbon-fouled (dry, sooty black deposits)?:
    - Carbon fouling is the result of incomplete combustion----for any reason. It is most often associated with an overly rich fuel mixture (whatever the cause), but can also be caused by an overly lean fuel mixture (or poor spark, etc.) In a lean-mixture condition, most of the un-burnt mixture gets pumped out the tailpipe, but some fuel droplets remain in the cylinder and add themselves to the next intake charge. That's not a very precise way of metering the mixture, so when it's finally rich enough for a spark to ignite, that particular charge may be too rich, resulting in incomplete combustion and plug fouling. So carbon-fouled plugs can be due to rich or lean conditions.......your Colortune spark plug will tell you for sure. If you have a light blue or white-ish flame, intermittent flame, and/or intermittent flashes of yellow within an otherwise white-ish flame, then your fuel mixture is too lean.
    And by the way.........if the spark that happens to ignite this overly-rich mixture is the "wasted spark" (which occurs in each cylinder at the top of the exhaust stroke, it will occur JUST AS THE INTAKE VALVE IS OPENING ---- so the backfire pressure wave may be directed back up the intake tract!
    So this would lend credence to an overly lean condition, although overly lean conditions would typically also include:
    Typical Symptoms and Causes of a Lean Fuel-Mixture Condition:
    - Poor acceleration; the engine feels flat.
    - The engine won't respond when the throttle is snapped open, but it picks up speed as the throttle is closed. (A too-large main jet also mimics this symptom.)
    - Idle speed falls after you blip the throttle, then creeps back up.
    - The engine runs hot, knocks, pings and overheats.
    - A lean pilot fuel circuit condition can be responsible for a creeping or "hanging (high) idle", where rpm's are very slow to return to a normal idle speed, is often a sign of being set lean. Conversely, if the idle drops way low and then (maybe) slowly recovers is often a sign of an overly rich condition.
    - The engine surges or hunts when cruising at part-throttle.
    - Popping or spitting through the carb occurs when the throttle is opened. Or popping and spitting occurs through the pipe on deceleration with a closed throttle.
    - The engine runs better in warm weather, worse in cool.
    - Performance gets worse when the air filter is removed.
    - Fuel levels that are too low will cause a lean condition.
    - Pilot fuel circuit that are partially or completely clogged.
    - Fuel jets that are too small for your application.
    - Pilot mixture screws being set too far "in".
    - In cases where an overly lean fuel condition is suspected, the application of a small amount of "choke" may decrease or eliminate the symptoms.
    - Here's the main reason you don't want to run lean over an extended period of time:
    http://www.xjbikes.com/forums/threads/head-gasket-1982-maxim-650.85273/#post-504365
    A holed piston. Notice how it's right where the plug fires (the hottest point anyway, and made ultra-hotter by a lean fuel condition).
    while other overly-rich conditions would be:
    Typical Symptoms of a Rich Fuel-Mixture Condition:
    - Engine acceleration is flat and uneven and loses that "crisp" feel.
    - The engine "eight-strokes" as it loads up and skips combustion cycles.
    - The engine's idle is rough or lumpy, and the engine won't return to idle without "blipping" the throttle.
    - An overly rich pilot mixture is usually the culprit when the idle drops below normal then slowly recovers.
    - The throttle needs to be open continuously to maintain acceleration.
    - Black, sooty plugs, a sooty exhaust pipe and black smoke from the tailpipe that stinks of unburned fuel.
    - Poor fuel economy.
    - The engine works better when cold. Performance falls off as it warms up or the ambient temperature rises.
    - Engine performance improves when the air cleaner is removed.
    - Fuel levels that are too high will cause a rich condition.
    - A choke system that is slightly hung open or has leaky plunger valves. Leaky valves can be determined via a measurement of vacuum using your synch sticks (or vac gauge) --- while watching the gauge, apply a small amount of downward force on the top of the plunger valve. If it vac draw changes, the plunger isn't sealing very well. Over time a small ridge may build up on the tapered brass plunger valve surface (Hitachi carbs) that may be possible to polish out, or a deformity forms on the rubber seals (Mikuni carbs) that may be possible to reform back into shape.
    - Fuel jets that are too large for your application.
    - Pilot and main FUEL jets being reversed.
    - Pilot and main AIR jets being reversed.
    - Pilot mixture screws being set too far "out".
    - Main jet needle set at too "high" of a position (on some Mikuni models), or that has "risen up" within its head cap (on Hitachi models).
    - A simple test for an overly-rich condition is to remove the air filter element, and see if performance improves. A very dirty air filter will cause an overly rich condition, AND, even if the filter was in good condition, the great increase in airflow accomplished by removing the air filter will tend to dilute an overly rich fuel mixture, and thus allow you to focus on determining the cause of that situation.
  47. MrSeca
    Oakland, CA
    Right on. I'm starting to wonder if my cheap rebuild kit from ebay is the culprit.
  48. Franz
    What are your spark plug gaps?
  49. Franz
    Forget that must be carburation.
  50. Minimutly
    West Wales, uk
    I think someone has allready suggested this, and I suggested to get some used needles - see that chacal guy - get some bits from him. Or re-use the original jets? But still get some needles.
    MrSeca likes this.
