84 xj 750 stalling need help ergently
Discussion in 'XJ Technical Chat' started by Jay1123, Mar 6, 2017.
  1. Jay1123
    Jay1123 New Member
    Kitchener ON
    My bike starts but when I start moving in first gear it completely dies. And the battery will not take even the littlest charge. Completely dead. I need my bike to get to work. Someone please help
  2. Toomanybikes
    Tsawwassen bc
    Electronic ign will cut out if voltage is low
    Check battery bolts and ground wire on frame.
  3. k-moe
    How long have you had the bike, and what maintenance has been done while you've owned it?
    A battery that takes no charge is a battery that needs to be replaced. The big question is did it die of natural causes, or did the charging system kill it?
    Replace the battery.
    Also check the voltage at the battery posts when the bike is idling, when it is at 2,500 RPM, and when it is above 3,000 RPM. Report back.
  4. Toomanybikes
    Tsawwassen bc
    Or side stand switch is stuck
  5. Jay1123
    Jay1123 New Member
    Kitchener ON
    It starts with a boost and revs fine .I put it in gear and start moving in first gear it completely dies.
  6. Jay1123
    Jay1123 New Member
    Kitchener ON
    Will the bike start moving in first gear before it dies
  7. Jay1123
    Jay1123 New Member
    Kitchener ON
    As far as I know the battery was new when the bike was put away a year ago.
    Hasn't been started in long time
  8. k-moe
    So you are depending on a long laid-up motorcycle to get to work?
    This will not go well for you.
    Unless this has been your daily rider for a long time you need to do a thorough recomissioning for it to be safe and reliable.
    TECH TOPIC: The Real Costs of Maintenance
    The Information Overload Hour
    If it has been your daily rider for a long time, and you haven't kept up on the required maintenance, it still needs to be recommissioned.
    Stumplifter likes this.
  9. Toomanybikes
    Tsawwassen bc
    Invest in a Battery Tender
  10. Jetfixer
    REPLACE battery first thing if it is a wet battery and a Walmart special get a new battery.
  11. k-moe
    No. If the stand switch is at fault the bike will die as soon as the clutch is released.
  12. chacal
    Well, technically, depending on how "tight" the cable is adjusted, and how much "slop" there is in the switch, then he could get some movement (clutch engagement) before the circuit opens and kills the TCI.
  13. XJ550H
    remove the sidestand safety switch RELAY to bypass the sidestand safety switch . this will confirm it as the culprit.
  14. jayrodoh
    jayrodoh YimYam
    Cleveland
    Doesn't the side stand switch work in conjunction with the neutral switch? If side stand was faulty it would shut ignition down as soon as shifted out of neutral. The clutch switch would only come into play if starting out of neutral.
    Rooster53 likes this.
  15. k-moe
    Generally I have the clutch lever pulled to the bar when I shift out of neutral.
    You can start the bike in neutral with the Sidestand down. Lift the stand, pull the clutch, shift into first and the bike will stay running even with a faulty Sidestand switch. Let the clutch out and the ignition is cut unless the Sidestand switch is closed.
    Chacal's comment makes sense.
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    Interesting, I didn't know that. I do know an 82 650 will shutdown as soon as you shift out of neutral if the sidestand is down or switch is faulty/hungup.
  17. k-moe
    Hmm... I might be remembering wrong. It's been a while since I've had a sidestand problem.
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    I don't know the wiring on that bike nor have I had one so you may be right. Just seemed odd to me based on the bikes I have now.
    No worries, I'm getting the age where I need my kids to help with the iPhone. I remember when I was young and couldn't understand why my parents could never program the VCR.
  19. k-moe
    What worries me is that it's been so long since I was on my XJ that I had to think about how I get the dang thing to move.
    jayrodoh and Rooster53 like this.
  20. Richard Koethke
    Richard Koethke New Member
    Kelso, WA
    I am having a Similar problem. Bike starts and runs fine in neutral. As soon as I shift to 1 or 2, the bike dies immediately. The 83 XJ750 has a new battery, but no other upgrades yet. I rode it yesterday, and today, no bueno. Any ideas?
  21. k-moe
    Unplug the sidestand relay, and/or clean the sidestand switch by peeling back the rubber boot, and sprayng contact cleaner into the plunger as you move it in and out.
  22. XJ550H
    Sidestand (kickstand) relay (blue): behind the left frame side cover, on the plastic regulator-rectifier mounting plate.
  23. Richard Koethke
    Kelso, WA
    That did the trick. Thanks guys
  24. k-moe
    Would you mind clarifying for future readers?
    Was it the relay or was the switch dirty?
  25. Richard Koethke
    Kelso, WA
    The kickstand part was sticking. I just tried some WD and it worked after that.
    XJ550H likes this.
  26. k-moe
    Cool. WD-40 won't hang around for long. Follow up with a dry-fillm lubricant, or silicone spray. Make cleaning the switch part of your annual maintainance.
  27. Richard Koethke
    Kelso, WA
    Good advice. Thank you.
  28. Superjoe
    Superjoe New Member
    Pa.
    Make sure the put the kickstand up before putting the bike in gear . It will shut the engine off when trying to let the clutch out of the kickstand is down.
  29. k-moe
    This was solved over a year ago.
  30. Superjoe
    Superjoe New Member
    Pa.
    Ok I wasn't sure. Thank you
