84 xj900f
Discussion in 'XJ Technical Chat' started by Christian Snow, Sep 1, 2019.
Tags:
  1. Christian Snow
    Christian Snow New Member
    Blackpool
    Hello I've just bought myself a xj900 and guess what it runs but only on full choke I'm guessing the carbs have been played with it was a restoration project from a old guy but it was cheap ..... any help ?
    runs on choke is pointing to clogged pilot jet circuit.
    that is the pilot jets and mixture screws this is the circuit that runs the bike at idle up to 2 to 3k rpm when the main jets kick in
    Franz likes this.
  3. Christian Snow
    Blackpool
    Cheers looks like I will have to strip the carbs
  4. Christian Snow
    Blackpool
    Well i took everything apart and cleaned everything and now i have fuel coming out of the breather pipes
  5. Franz
    Did you set the float heights? I think this can happen if the float height is set too high. Setting float height too low causes a lean condition.
  6. Christian Snow
    Blackpool
    Didn't touch the floats all I did was remove all the covers took all the jets out and cleaned them in including the diaphragms
  7. k-moe
    Christian Snow likes this.
  8. XJ550H
