85 FJ600 Wiring diagram
Discussion in 'Other Motorcycles' started by Sly, Apr 26, 2019.
  1. Sly
    Sly New Member
    Mckenzie, TN
    Does anyone have a good wiring diagram for a 85 fj/xj 600? As far as i know the the only difference between the 2 bikes mechanically is the speedo?? So is the wiring harness the same between the 2 bikes? Is the auto-canceling turn signal system part of the flasher module?
    it is the same relay used in the XJ 700 so the answer is yes
    it is used in many bikes look at this link
    https://www.partzilla.com/product/y...?ref=2ceb8b87ce49fd3dd13af37ac4687233d29c2c89
    NOTE: all XJ700 models and XJ750-X models use a consolidated relay assembly (mounted under and to the rear of the fuel tank, on the wishbone frame triple-tube joint) which combines the turn signal flasher, the turn signal canceller relay unit, and the starter circuit cut-off relay.
