85/ to 86 X
Discussion in 'XJ Technical Chat' started by Joe34, May 24, 2020.
  1. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Will a 85 x motor hook up to 86 x wiring.
  2. hogfiddles
    To an extent..... the X has extra wires for the fan, thermostat, temp related switches, temp gauge—-
    Otherwise, lights, controls, etc.... are the same
  3. Simmy
    Joe I think there were a couple cosmetic changes, gas tank badge I think. I don’t believe there were any mechanical or electrical differences.
  4. xHondaHack
    Orange CT
    Yes it will Joe.
    On the engine, the difference on the '86 is in the pickup coil plate on the left side of the crank, and Yamaha eliminated the timing pointer. ( I discovered that when doing a valve clearance check on one). All the wiring connections are the same so you can swap them either way.
    As Simmy mentioned, all the other changes were cosmetic.
    Tony
    Joe34 likes this.
  5. hogfiddles
    I read it wrong— I just saw the heading and thought it meant airhead to X.. ignore my previous post.
    dfox
    Joe34 likes this.
