85 - XJ700 air cooled, won't stay running.
Discussion in 'XJ Technical Chat' started by Christopher R Tuttle, May 4, 2026.
  1. Christopher R Tuttle
    Christopher R Tuttle New Member
    NH
    Greetings everyone. I originally asked questions last fall and now that the warmer air is back here in New England I've begun to work on my bike again. I purchased thru here a total carb rebuild kit, including new air and fuel jets, and tore down, hot ultrasound washed components, flushed with carb cleaner ( must remember to get face out of way in future when spraying little passages, stuff tastes terrible) and put together with new pieces all 4 carbs. They look nice. I in stalled and tried to start. Freshly charged battery, new gas. Most of the time it sputters and on rare occasions it will run for 5ish seconds, then dies. My prime jet has been set at between 1.5 and 4 turns. Makes little difference.
    After 30 min of trying, found exhaust piping hot on 2/3 warm on 1, stone cold on 4. Check spark on 4, nothing. I attempted ohm reading s on 1/4 coil, wire to wire 2.4ohm. wire to plug cable, OL. Removed end cap, found corrosion. Ordered new coil packs and replacement caps. Went to perform same checks on new, got exact same readings on wire to plug cable, OL. Can both be broken or am I missing something? Put original coils back on with new plug caps, seems to try and start on 2/3 but still issue with 1/4. My next thought is to go back in system and check points. Any thoughts anyone?
    Thanks for the help.
  2. chacal
    I assume you're trying to check the secondary resistance on the ignition coils......to do so you'll check (for each individual coil) plug wire-to-plug wire ends (either with or w/o the hard plastic caps installed). The secondary circuit (plug wires) and the primary circuit (from the engine harness, and coming from the TCI actually) are not connected within the coil body, and thus there can be no reading if you try a plug wire (secondary circuit) to the either of the two wires that make up the primary circuit.
    Checking the secondary circuit may well get you an OL reading......unlike the primary circuit (2.4 ohms is about right), the secondary circuit can be 10K (10,000) ohms and up. A lot of standard ohm meters will either:
    a) not read that circuit properly, if the meter doesn't have a selector to choose particular "ohm ranges", or...
    b) may not read it at all, even if there is a selector switch (and it's set to the correct range). 10K-up ohms is a lot of resistance for a 1.5V battery to push thru, and if the batteries are weak or the meter is really not designed to read that much resistance, you get the OL reading.
    Note that the OL reading can mean EITHER an "Open Loop" (the circuit has a broken wire somewhere within it, and one end is no longer physically connected to the other end of the wire) or it can mean "Over Loaded".....meaning that the meter isn't set to the correct ohm "range", or that the meter can't push enough voltage thru that length of wire to create a determinable ohm value.
    Some meters allow you to select an ohm reading "range" such as "Ohms x 10" or "Ohms x 100", etc.....in such a case, when you measure (for example) a 11,000 ohms circuit on the "ohms x 100" setting, then the display will only show 110 ohms (which is 1/100th of the true reading of 11,000 ohms).
    https://geekyelectronics.com/how-to-measure-ohms-using-a-multimeter
    RideAlong420 likes this.
  3. Christopher R Tuttle
    NH
    Ok, now I'm stumped. I have rebuilt and taken apart my carbs at least 4x now. I have used rebuild kits from here, swapped out jets, gaskets, you name it. I have cleaned the carbs in an ultrasound bath, shot carb cleaner thru just about every opening I could find. Everything seems to be clear. I am reasonably sure it's not the carbs but....
    I am pretty certain it's not the coil packs either. I have replaced them from here and only exhaust 1 and 3 are hot. 2 and 4 are cold. It does try to start but dies soon after (duh, it only running on 2 cylinders).
    I have new BPR8ES plugs, yes the wire caps have been swapped for 0 Ohm. I have swapped both the plugs and wires (put 4 on 1 and 3 on 2). Still only get 1 and 3 warm, other 2 pipes are still cold. I've checked compression on 2 and 4, it builds to 150/60 after a few rotations. If I spray ethanol into carbs 2 and 4 it does try to fire but doesn't last long.
    Anyone have an idea? I'm stumped.
  4. Dave in Ireland
    Ireland
    Make sure you have genuine NGK plugs, there's a huge amount of fakes around, infiltrating the supply channels.
  5. Kenneth Irsik
    Kenneth Irsik New Member
    Springfield
    I am having the same problem!
    Finally got it to start and run on full choke only and cylinders 2-4 were ice cold . I used carb cleaner was able to some heat in 2-4 but not run. Same as you check coils and even bought a used coil that had ohm checked and was good and still could only get cylinders 1-3 to run. Coil 1 supply’s 1-4 and coil 2 supply’s 2-3 so 1 cylinder off each coil is running. I did swap coils around and made no difference.I just pulled the carbs and cleaned did fine some junk in them reinstalled thinking ya finally get this bike running still only running on 1-3 with full choke. Going to pull carbs again and clean. I have a friend that races bikes he was saying try up sizing the pilot jet one size and see if that makes a difference?? I did change out plugs, gas, added an inline fuel filter.
    Any help would be greatly appreciated.
    I am getting to the point of junking this thing.
