85 xj700x project
Discussion in 'XJ Modifications' started by Woje, Oct 26, 2015.
  1. k-moe
    If you really want to you can wire in a fusebox that is small enough to mount in the headlight. Just trace the wires to see which fuse goes to which pair of wires.
    Woje likes this.
    700N starter safety switch runs off of the stock tach
  3. Woje
    Woje Member
    48915, Lansing, MI
    Thank you I ended up just soldering fuses in with out the bezel so the entire wire harness with all lights and connectors stays in tact inside the headlight for now so when I'm able to find and can afford a stock replacement it's still bolt on ready
    Alan63 likes this.
  4. Woje
    Woje Member
    48915, Lansing, MI
  5. k-moe
    Those bags are going to get hot.
    Jetfixer likes this.
  6. hogfiddles
    And smell of exhaust too.....
  7. Woje
    Woje Member
    48915, Lansing, MI
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That's quite the paint job on your helmet! I dig it.
