Wanted 900 Seca exhaust system/collector
Discussion in 'For Sale, Trade/Swap, Wanted' started by Bob C, Oct 5, 2023.
  1. Bob C
    Bob C Member
    Upstate ny
    I am in need of the collector section for a stock Seca 900 exhaust. I will consider a complete exhaust either stock or after-market. Please let me know what you have.
  2. Novascotiamark
    Novascotiamark Member Premium Member
    Nova Scotia, Canada
    I have the header pipes and collector of a 1984 xj750rl seca. The frames and many other components are interchangable with the 83 900 seca. Not positive on the collector swap but I'm sure there would be someone on here that would know.
  3. Bob C
    Bob C Member
    Upstate ny
    B best that i know the 750 exhaust is not compatible with the 900 but thanks responding
  4. Novascotiamark
    Nova Scotia, Canada
    If you wanted to go the new route I recently put a Marving 4 into 1 on my 83 900 Seca. Went on easy, fits well and runs good. I got mine from Wemoto in the UK.
  5. Bob C
    Bob C Member
    Upstate ny
    I looked at the Marving system and it is definitely a possibility. Can you advise how loud the system is?
  6. Novascotiamark
    Nova Scotia, Canada
    I'll try to attach a video file of it running so you can get an idea of the sound. I would say it sounds similar to the old Kerker 4 into 1 of the eighties. I think there were two options for the Marving, this is the sportier exhaust of the two. I'm running pod filters and dynojet stage 3 kits in the carbs. If the link doesnt't work let me know and I'll try something else.
    https://imgur.com/bTngOLF
  7. Bob C
    Bob C Member
    Upstate ny
    Thanks. Worked well. I appreciate the help.
    Bob C.
  8. Bob C
    Bob C Member
    Upstate ny
    Hi NovaScotiaMark: I took your advise and the marving System is enroute. Thanks for the tip. One additional question if I may? Did you have to rejet the carbs when you installed the system? If you did can you advise what the final jetting was as a head start?
    Thanks: Bob C.
  9. Novascotiamark
    Nova Scotia, Canada
    Hello Bob,
    I have the dynojet stage 3 kits installed in the carbs so they are jetted with dynojet jets not the standard mikuni jets. The dynojet kit can be setup as stage 1, 2 or 3. The different stages have different jet sizes. Stage 3 is for pod filters and aftermarket 4 into one exhaust which is how mine is setup. I also have my brothers 900 setup the same way. I'll take a look to see if I still have the paper that came with the kit listing the jet sizes. I think there are some crossover charts online comparing dynojet to mikuni sizes. They sizing system on the two jet types is different so for example a 120 mikuni jet is not the same as a 120 dynojet jet.
    chacal likes this.
  10. Novascotiamark
    Nova Scotia, Canada
    If you go onto the dynojet website and search for a kit for the 1983 xj900 there is a download button that shows the installation instructions for the kit. It lists the various jet sizes and for which stage they are meant. Keep in mind that the kit is not jets only but also different profile needles, air jet adjustment, slide drill and needle spacers. All very easy to do.
  11. Bob C
    Bob C Member
    Upstate ny
    Thank you : The exhaust just arrived and will be installed shortly.
  12. hogfiddles
    Keep us posted……
  13. Paul Swallow
    Paul Swallow New Member
    Massachusetts
    Hey Mark, Just wondering if that system you got bolted up to your 1983
  14. Novascotiamark
    Nova Scotia, Canada
    I installed the kit on my 1983 xj900. Just followed the directions, pretty straight forward. I used the stage 3 combination of jets since I have the pods filters and the 4 into 1 exhaust. Bike runs very good. My brother has a 900 as well and we put the same kit on his. Also running well.
  15. Novascotiamark
    Nova Scotia, Canada
    Are you referring tho the exhaust or the dynojet kit? If it's the exhaust , yes it bolted up no prblem.
